MHCI05018-R68M-R8A
MHCI05018-R68M-R8A
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
MHCI05018-R68M-R8A 数据手册
Form No.: QF-1274 Edition: 2 RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 各廠家 Customer: : Customer P/N: Drawing No: : Quantity: : 0 Pcs. Chilisin P/N: : Date : 2018/11/13 MHCI05018-1R0M-R8A SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 東莞奇力新電子( 東莞奇力新電子(東莞廠) 東莞廠)有限公司 奇力新電子股份有限公司 Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL +86-769-8773-0251~3 FAX +86-769-8773-0232 E-mail cect@chilisin.com Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com http //www.chilisin.com : : : : : : : 奇力新電子( 奇力新電子(越南廠) 越南廠)有限公司 奇力新電子( 奇力新電子(湖南廠) 湖南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel 84-316 255 688 Fax 84-316 255 689 E-mail sales@chilisin.com : : Drawn by 陳瑞揚 ryan.chen : HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel 86-745-867-5882 E-mail cect@chilisin.com : : Checked by ling 溫美玲 Approved by 陳瑞揚 ryan.chen YG18B00763 MHCI05018 Series Specification 1 Scope: This specification applies to large current and low loss SMD shielding power inductor. 2 Part Numbering: 3 Rating: Operating Temperature: -55℃ ~ 125℃(Including self - temperature rise) Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max. 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35 ) Ordinary Humidity(25 to 85% RH) ℃ In case of doubt 20 to 30 50 to 80 %RH ℃ MHCI05018 Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Inductance (uH) Part No. Tolerance (±%) Test Freq. Irms(A) Typ. Isat(A) Typ. RDC(mΩ) Max. Marking MHCI05018-R47M-R8A 0.47 20 100kHz,0.5V 10.5 15.5 9(7.7typ) R47 MHCI05018-1R0M-R8A 1 20 100kHz,0.5V 8 9 17(15typ) 1R0 MHCI05018-2R2M-R8A 2.2 20 100kHz,0.5V 5 6.5 35(30typ) 2R2 MHCI05018-3R3M-R8A 3.3 20 100kHz,0.5V 4.5 5 58(52typ) 3R3 MHCI05018-4R7M-R8A 4.7 20 100kHz,0.5V 3.5 4 85(78typ) 4R7 MHCI05018-6R8M-R8A 6.8 20 100kHz,0.5V 2.8 3.4 120(107typ) 6R8 MHCI05018-100M-R8A 10 20 100kHz,0.5V 2.5 3 155(140typ) 100 ` Note: ℃~125℃(Including self - temperature rise) 1.Operating temperature range -55 2.Isat for Inductance drop 30% from its value without current. ℃ temperature rise from 25℃ ambient. 3.Irms for a 40 4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 5.Absolute maximum voltage 30VDC MHCI05018 Series Specification 8 MHCI05018 Series 8.1 Construction: 8.2 Material List: MHCI05018 Series Specification 9 Packaging: 9.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity 9.3 Reel Dimensions MHCI05018 Series Specification 9 Packaging: 9.4 Tape Dimensions in mm 10 Recommended Land Pattern: 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. MHCI05018 Series Specification 12 Graph: MHCI05018-1R0M-R8A
MHCI05018-R68M-R8A 价格&库存
很抱歉,暂时无法提供与“MHCI05018-R68M-R8A”相匹配的价格&库存,您可以联系我们找货
MHCI05018-R68M-R8A
  • 1+0.79380
  • 10+0.41904
  • 30+0.18684
  • 100+0.15768
  • 500+0.14472
  • 1000+0.13716
库存:901
