Form No.: QF-1274
Edition: 2
RoHS & Halogen Free & REACH Compliance.
SPECIFICATION FOR APPROVAL
各廠家
Customer:
Customer P/N:
Drawing No:
Quantity:
Pcs.
Chilisin P/N:
Date :
2018/11/13
MHCI05015-100M-R8A
SPECIFICATION
ACCEPTED BY:
COMPONENT
ENGINEER
ELECTRICAL
ENGINEER
MECHANICAL
ENGINEER
APPROVED
REJECTED
東莞奇力新電子(
東莞奇力新電子(東莞廠)
東莞廠)有限公司
奇力新電子股份有限公司
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei Administration Area,
Qingxi Town, Dongguan City, Guangdong,China
TEL +86-769-8773-0251~3
FAX +86-769-8773-0232
E-mail cect@chilisin.com
Chilisin Electronics Corp
No. 29, Alley 301, Tehhsin Rd.,
Hukou,Hsinchu 303, Taiwan
TEL +886-3- 599-2646
FAX +886-3- 599-9176
E-mail sales@chilisin.com
http //www.chilisin.com
奇力新電子(
奇力新電子(越南廠)
越南廠)有限公司
奇力新電子(
奇力新電子(湖南廠)
湖南廠)有限公司
Chilisin Electronics (Vietnam) Limited
No 143 - 145, Road No 10, VSIP Hai Phong,
Lap Le Commune, Thuy Nguyen Dist,
Haiphong City, Vietnam
Tel 84-316 255 688 Fax 84-316 255
689
Drawn by
陳瑞揚 ryan.chen
HuNan Chilisin Electronics Technology Co., Ltd
No. 8, Shaziao Liangshuijing Town, Yuanling
County, Huaihua City, Hunan Province 419601,
China
Tel 86-745-867-5882
Checked by
ling
溫美玲
Approved by
陳瑞揚 ryan.chen
YG18B00761
MHCI05015 Series Specification
1 Scope: This specification applies to large current and low loss SMD shielding power
inductor.
2 Part Numbering:
3 Rating:
Operating Temperature: -55℃ ~ 125℃(Including self - temperature rise)
Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max.
4 Marking:
5 Standard Testing Condition
Temperature
Humidity
Unless otherwise specified
Ordinary Temperature(15 to 35 )
Ordinary Humidity(25 to 85% RH)
In case of doubt
20 to 30
50 to 80 %RH
6 Configuration and Dimensions:
7 Electrical Characteristics:
Inductance
(uH)
Tolerance
Test Freq.
Irms(A)
Typ.
Isat(A)
Typ.
RDC(mΩ)
Max.
Marking
MHCI05015-1R0M-R8A
1
100kHz,0.5V
6.5
9
23(20typ)
1R0
MHCI05015-2R2M-R8A
2.2
100kHz,0.5V
3.3
6
64(58typ)
2R2
MHCI05015-4R7M-R8A
4.7
100kHz,0.5V
3
4
106(95typ)
4R7
MHCI05015-100M-R8A
10
100kHz,0.5V
2
3
170(153typ)
100
Part No.
Note:
℃~125℃(Including self - temperature rise)
1.Operating temperature range -55
2.Isat for Inductance drop 30% from its value without current.
℃ temperature rise from 25℃ ambient.
3.Irms for a 40
4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions.
Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size
and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature
should be verified in the end application.
5.Absolute maximum voltage 30VDC
8 MHCI05015 Series
8.1 Construction:
8.2 Material List:
9 Packaging:
9.1 Packaging -Cover Tape
The force for tearing off cover tape is 10 to 130 grams in the arrow direction.
9.2 Packaging Quantity
9.3 Reel Dimensions
9 Packaging:
9.4 Tape Dimensions in mm
10 Recommended Land Pattern:
11 Note:
1. Please make sure that your product has been evaluated and confirmed against your specifications
when our product is mounted to your product.
2. Do not knock nor drop.
3. All the items and parameters in this product specification have been prescribed on the premise that
our product is used for the purpose,under the condition and in the environment agreed upon between
you and us. You are requested not to use our product deviating from such agreement.
4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
5. The moisture sensitivity level (MSL) of products is classified as level 1.
12 Graph: MHCI05015-100M-R8A
MHCI05015B-1R0M-R8A 价格&库存
很抱歉,暂时无法提供与“MHCI05015B-1R0M-R8A”相匹配的价格&库存,您可以联系我们找货
