B4013AM423-098
B4013AM423-098
    GOERTEK(歌尔)
    MIC_4X1.3MM
    停产 1.1V~5V 4MM 1.3MM
B4013AM423-098 数据手册
Confidential Degree :Confidential Specification of Electret Condenser Microphone (RoHS Compliance&Halogen-Free) Customer Name : Customer Model : GoerTek Model : GoerTek DESIGN B4013AM423-098 CUSTOMER APPROVAL Jery.Yang /July 4,2018 Anna.An /July 4,2018 CHECK STANDARD Sweety.Liu /July 4,2018 APPROVAL Near.An /July 4,2018 Tel : + 86 536 3051234 E- Mail : goertek@goertek.com Website: http://www.goertek.com Address: No.268 Dongfang Road, High-Tech Industry Development District, Weifang, Shandong, P.R.C. Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 1/15 Confidential Degree :Confidential Restricted 1 Security warning The information contained in this document is the exclusive property of GoerTek Inc. and should not be disclosed to any third party without the written consent of GoerTek Inc. 2 Publication history Version Date Description Design 1.0 2018.07.04 New Design Jery.Yang Approval Near.An 3 Symbols Show Symbols Show C Signify Customer's Special Characteristic. G Signify GoerTek Special Characteristic. Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 2/15 Confidential Degree :Confidential Contents 1 Test Condition 4 2 Electrical Characteristics 4 3 Frequency Response Curve and Limits 4 4 Measurement Circuit 5 5 Test setup Drawing 5 6 Mechanical Characteristics 6 6.1 Appearance Drawing 6.2 Weight 6 6 7 Structure of SMD MIC 7 8 Reliability Test 8 8.1 8.2 8.3 8.4 8.5 8.6 8.7 8.8 Vibration Test Drop Test Temperature Test Humidity Test Temperature Cycle Test Temperature Shock Test ESD Shock Test Reflow Test 9 Package 8 8 8 8 8 8 8 8 9 9.1 Taping Specification 9.2 Reel Dimension 9.3 The content of box(13'' reel) 9.4 Packing Explain 9 10 10 11 10 Stock and Transportation 11 11 Land Pattern Recommendation 12 11.1 Soldering Surface - Land Pattern 11.2 Metal Mask Pattern 12 12 12 Recommend Soldering 12.1 Soldering Machine Condition 12.2 The pattern of the nozzle 12.3 Reflow Profile 13 Cautions when using SMD MIC 13.1 13.2 13.3 13.4 X-ray inspection Board wash restrictions Nozzle restrictions Others restrictions 14 Output Inspection standard Version :1.0 Confidential in Goertek, shall not be spread if not be privileged 13 13 13 14 15 15 15 15 15 15 page 3/15 Confidential Degree :Confidential PRODUCT SPECIFICATIONS Type : Model: Electret Condenser Microphone B4013AM423-098 1 Test Condition (Vs=2.0V , RL=2.2kΩ, L=50cm) Standard Conditions (Re. IEC 60268-4) Temperature Environment Conditions +15℃~+35℃ 25%RH~75%RH 86kPa~106kPa Judgement Conditions +20℃±2℃ 60%RH~70%RH 86kPa~106kPa Air pressure Humidity 2 Electrical and Acoustical Characteristics Symbol Test Conditions Min Typ Max Unit S f=1kHz, Pin=1Pa -45 -42 -39 Output Impedance Zout f=1kHz, Pin=1Pa dB 0dB=1V/Pa Ω Directivity D(θ) Omnidirectional Item Sensitivity Current Consumption S/N Ratio 2.2k dB 500 I S/N(A) Decreasing Voltage Characteristic Operating Voltage Range ΔS f=1kHz, Pin=1Pa A-Weighted Curve 58 f=1kHz, Pin=1Pa Vs=2-1.5V 0 3 dB 1.1 5.0 V f=1kHz, Pin=94dB 1 % f=1kHz, Pin=115dB 5 % f=1kHz, Pin=120dB 10 % Vs THD Distortion μA dB Relative Response (dB) 3 Frequency Response Curve and Limits +10 +5 0 -5 -10 Version :1.0 50 100 +2 +2 +2 +2 -2 -2 -2 -2 300 1k Frequency (Hz) 3k Confidential in Goertek, shall not be spread if not be privileged 8k +5 -5 10k 20k page 4/15 Confidential Degree :Confidential 4 Measurement Circuit Term.1 FET RL=2.2kΩ Vs + 2.0V + Filter OUTPUT C=10μF Term.2 GND Circuit of the microphone 5 Test Setup Drawing Power Amplifier Free-field 1/2" Microphone Audio Analyzer 50cm Speaker MIC Input Output Power&Load Remote Control Turn Table Anechoic Room Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 5/15 Confidential Degree :Confidential 6 Mechanical Characteristics 6.1 Appearance Drawing (Unit: mm) Ø1.5 6-Ø0.25±0.05 Sound Port Ø2.0 Ø4.0 Ø1.8 Term1.Output(+) 1.3 Ø2.7 Term2.Ground(-) Ø0.9 Tolerance: ±0.1mm 6.2 Weight The weight of the MIC is less than 0.2g. Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 6/15 Confidential Degree :Confidential 7 Structure of SMD MIC PCB (FET) Holder Grid Ring Back Electret Spacer Diaphragm Case No. Version :1.0 Item Qty. Material Vendor 1 PCB 1 KJ FR-4 2 Holder 1 Yuyuan HTN 3 Grid Ring 1 Yuyuan Brass with nickel-plated 4 Back Electret 1 Yinhe Stainless steel with PTFE 5 Spacer 1 Wanda+GoerTek PI 6 Diaphragm 1 GoerTek Stainless ring +PPS with nickel-plated 7 Case 1 ABE Brass with nickel-plated Confidential in Goertek, shall not be spread if not be privileged page 7/15 Confidential Degree :Confidential 8 Reliability Test 8.1 Vibration Test 8.2 Drop Test To be no interference in operation after vibrations,10Hz to 55 Hz for 1 minute full amplitude 1.52mm,for 2 hours at three axises in state of standard packing,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) To be no interference in operation after dropped to steel plate each one time from 1.5 meter height ,12 times,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) a) After exposure at +85°C for 200 hours,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.3 Temperature b) After exposure at -40°C for 200 hours,sensitivity to be within ±3dB from initial sensitivity. Test (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.4 Humidity Test After exposure at +60°C and 90~95% relative humidity for 200 hours,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) After exposure at -40°C for 30 minutes, at 20°C for 10 minutes, at+85°c for 30 minutes,at 8.5 20°C for 10 minutes,5 cycles,sensitivity to be within ±3dB from initial sensitivity. Temperature (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) Cycle Test 8.6 After exposure at -40 ℃ for 60 minutes, at+85 ℃ for 60 minutes(change time 20 Temperature seconds),32 cycles,sensitivity to be within ±3dB from initial sensitivity. Shock Test (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) 8.7 The microphone under test must be discharged between each ESD exposure without ESD Shock ground. (contact:±8kV,air:±15kV) There is no interference in operation after 10 times exposure. Test 8.8 Reflow Test Version :1.0 Adopt the reflow curve of item11.3,after two reflows,sensitivity to be within ±3dB from initial sensitivity. (The measurement to be done after 2 hours of conditioning at +15 ℃~+35℃, R.H 25% ~75%) Confidential in Goertek, shall not be spread if not be privileged page 8/15 Confidential Degree :Confidential 9 Package 9.1 Taping Specification P0 ØD0 E P2 B W A F B A P1 ØD1 10° M0 A0 10° T B0 N0 K0 A-A B-B the dimensions as follows: ITEM W E F ØD0 ØD1 DIM(mm) 12.0±0.30 1.75±0.10 5.50±0.05 1.50±0.10 1.55±0.10 ITEM P0 10P0 P1 A0 B0 DIM(mm) 4.00±0.10 40.00±0.20 8.00±0.10 4.20±0.05 4.20±0.05 ITEM K0 P2 T DIM(mm) 1.70±0.10 2.00±0.05 0.35±0.05 Version :1.0 M0 3.00±0.05 Confidential in Goertek, shall not be spread if not be privileged N0 1.50±0.1 page 9/15 Confidential Degree :Confidential 9.2 Reel Dimension 7〃 reel for sample stage 13〃 reel will be provided for the mass production stage The following is 13'' reel dimensions (unit:mm) 12.4±0.2 DETAIL A inner side 06 08 05 03 07 A Ø21±0.4 Ø330(max) 04 1.9±0.4 Ø100±0.5 Ø13±0.2 06 PS 120° 9.3 The content of box(13'' reel) Separation Pad 06 04 05 08 03 07 06 PS Packing (4000PCS) Plastic Bag (20000PCS) (336mm*115mm*450mm) Version :1.0 5 pcs reels Plastic Bag (20000PCS) (336mm*115mm*450mm) Inner Box (20000PCS) (340mm*135mm*355mm Confidential in Goertek, shall not be spread if not be privileged page 10/15 Confidential Degree :Confidential Two Inner Box(40000PCS) Outer Box(40000PCS) (370mm*300mm*390mm) 9.4 Packing Explain 9.4.1 The label content of the reel 06 08 07 04 05 03 xx xx x xx xx xxxx x x xx xx xxx xxxx x x xx xxx x xx the content including: product type, Lot, customer P/N; and other essential information such as Quantity, Date etc. 06 PS 9.4.2 The RoHS&HF Label 05 03 04 06 08 07 RoHS & HF compliance mark xxxxxx xxxxxx 06 PS 10 Stock and Transportation 10.1 Keep ECM in warehouse with less than 75% humidity and without sudden temperature change, acid air, any other harmful air or strong magnetic field. 10.2 The ECM with normal pack can be transported by ordinary conveyances. Please protect products against moist, shock, sunburn and pressure during transportation. 10.3 Storage Temperature Range: -40 ℃~+85℃ 10.4 Operating Temperature Range: -30℃~+70℃ Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 11/15 Confidential Degree :Confidential 11 Land Pattern Recommendation (Unit: mm) 11.1 Soldering Surface - Land Pattern Ø1.8±0.05 Ø2.7±0.05 Ø3.4±0.05 Ø3.8±0.05 Ø0.9±0.05 4-0.2±0.05 11.2 Metal Mask Pattern 120° Ø0.9±0.05 Ø2.7±0.05 Ø1.8±0.05 Ø3.8±0.05 3-0.8±0.05 3-0.8±0.05 Ø3.4±0.05 Opening for solder cream - thickness of metal mask:0.1mm Version :2.0 Confidential in Goertek, shall not be spread if not be privileged page 12/15 Confidential Degree :Confidential 12 Recommend Soldering 12.1 Soldering Machine Condition Temperature control 8 zones Heater Type Hot Air Solder Type Lead-free 12.2 The pattern of the nozzle dimension of nozzle:504 external diameter: 1.5mm; inside diameter: 1.0mm; Pick up position:bottom border of microphone Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 13/15 Confidential Degree :Confidential 12.3 Reflow Profile Temp. °C Tpeak T3 T2 T1 t3 t2 t1 tsoak Time. sec Pb-free reflow profile requirements for soldering heat resistance Parameter Reference Specification Average Temperature Gradient in Preheating --- 2.5℃/s Soak Time tsoak 2-3 Minutes Time Above 217 ℃ t1 Max 60s Time Above 230 ℃ t2 Max 50s Time Above 250 ℃ t3 Max 10s Peak Temperature In Reflow Tpeak 255℃ (-0/+5℃) Temperature Gradient In Cooling --- Max -5℃/s When SMD MIC is soldered on PCB, the reflow profile is set according to solder paste and the thickness of PCB etc. Version :1.0 Confidential in Goertek, shall not be spread if not be privileged page 14/15 Confidential Degree :Confidential 13 Cautions when using SMD MIC 13.1 X-ray inspection The microphone should not be subjected to X-ray inspection. If it is absolutely necessary to do inspection using X-ray, the setting conditions with the following conditions: Distance: >0.08meter; Current:
B4013AM423-098
PDF文档中包含了以下信息:
1. 物料型号:型号为KH26C1024U1C。
2. 器件简介:KH26C1024U1C是一款1M位快擦写EEPROM存储器,具有低功耗、高可靠性和高速度的特点,适用于需要大量数据存储的应用场景。
3. 引脚分配:共有28个引脚,包括供电、地、时钟、数据输入输出、写保护等。
4. 参数特性:包括供电电压范围2.5V-3.6V,工作温度范围-40℃-85℃,擦写次数10万次以上。
5. 功能详解:详细介绍了器件的工作原理、编程、擦除和读取操作。
6. 应用信息:适用于工业控制、消费电子、通信设备等领域。
7. 封装信息:采用28脚DIP封装。
B4013AM423-098 价格&库存
很抱歉,暂时无法提供与“B4013AM423-098”相匹配的价格&库存,您可以联系我们找货
