VEC3R0506QG
VEC3R0506QG
    VINATECH
    插件,P=7.5mm
    超级电容器 径向
VEC3R0506QG 数据手册
EDLC 3.0V 50F FEATURES Electric double layer capacitor Higher power density with ultra low ESR Semi-permanent, quick charge and discharge than batteries Suitable for short-term peak power assistance application UL and ISO/TS certificated, RoHS compliant Radial design with lead terminal type 2015-12-01 DIMENSIONS Dimensions in mm L ± 1.5 d ± 0.1 40.0 Φ0.8 D +1.0 Max Φ18.0 Dimens P ± 0.5 7.5 This drawing is not to be scaled. SPECIFICATIONS Rated Voltage, VR Rated Capacitance AC ESR 1kHz (V) (F) (mΩ) (mΩ) (A) (㎃) (J) (mm) (g) VEC 3R0 506 QG 3.0 50. 12.50 * Maximum Current: 1 second discharge to ½ ·V R 19.00 38. 0.150 225.0 18.0 x 40.0 12.5 Part Number DC IR Maximum Current Leakage Current Stored Energy Dimension DxL Weight * Leakage Current: After 72hours at VR and 25℃ 2015-12-01 09:05:41 Item Characteristics Rated Voltage(VR) 3.0V Capacitance Tolerance -10 ~ 30% Remarks |Δcap| ≤ 30% of initial value at 25℃ Operating Temperature (Tmin ~ Tmax) -40 ~ +65℃ Storage Temperature -40 ~ 70℃ |ΔESR| ≤ 100% of specified value at 25℃ After 1,000 hours application of VR at Tmax |Δcap| ≤ 30% of initial value at 25℃ Cycle Life 500,000 cycles |ΔESR| ≤ 100% of specified value at 25℃ Cycles from VR to ½ ·VR under constant current at 25℃ |Δcap| ≤ 10% of initial value at 25℃ Shelf Life 2 years |ΔESR| ≤ 50% of specified value at 25℃ Without electrical charge under Tmax Tel: +82-31-455-3064 E-mail: hycap@vina.co.kr Web: www.vina.co.kr Design and specifications are subjected to change without notice. version 9.1 on November 23, 2015
VEC3R0506QG 价格&库存
很抱歉,暂时无法提供与“VEC3R0506QG”相匹配的价格&库存,您可以联系我们找货
