CETC0530-3R3M-B
CETC0530-3R3M-B
    CETC(中电科技集团)
    IND_5.8X5.43MM_SM
    3.3UH ±20%
CETC0530-3R3M-B 数据手册
COMPOSITE FORMING SMD INDUCTORS CETC0530B TYPE ■Features RoHS compliant* and halogen free** lowest DCR/uH,in this package size. High saturation current Frequency range up to 3.0MHZ. Ultra low buzz noise,due to composite construction. ■Applications Notebook/Desktop/Server applications. low profile,high current power supplies. Battery powered devices. DC/DC converters. ■Product identification CETC XXXX - XXX M - B ① ② ③ ④ ⑤ ① Product Code ② Size: L×W (mm) ③ Inductance Value ④ Tolerance: J±5%, K±10%, L±15% , M±20%, P± 25%, N±30% ■Product Dimensions [unit: mm ⑤ Category ■Recommended Layout [unit: mm] 型号 A B C D E F G H CETC 0530 5.45± 0.35 5.18± 0.25 3.0Max 2.2 ± 0.3 1.2 ± 0.3 5.99 2.5 2.5 ■ Specification table CETC0530-B series 100KHz 0.25V P/N D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 0530-R20 M-B 0.2 3.7 4.10 15 30 CETC 0530-R47 M-B 0.47 6.7 7.1 12 18 CETC 0530-R68 M-B 0.68 8 8.8 10 15 CETC 0530-1R0 M-B 1.0 11.5 12.65 10 12 CETC 0530-1R5 M-B 1.5 20 25 8 10 CETC 0530-2R2 M-B 2.2 25 29 6 9 CETC 0530-3R3 M-B 3.3 32 38 5 7 CETC 0530-4R7 M-B 4.7 49 54 4.5 6 CETC 0530-6R8 M-B 6.8 60 70 3.5 5 CETC 0530-100 M-B 10 110 121 3 4.5 CETC 0530-150 M-B 15 140 154 2.5 3 • All test data is referenced to 25°C ambient • DC current (Idc) that will cause an approximate △ T of 40℃ • DC current (Isat) that will cause Lo to drop approximately 20% • Operating temperature Range: –40°C to +125°C • The part temperature (ambient + temp rise) should not exceed125℃ under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ■Packaging 1)Reel dimensions 2) Tape packaging dimensions 3) Tape Direction 4) Peel force of top cover tape The peel speed shall be about 300 mm/minute The peel force of top cover tape shall be between 0.1 to 1.3N 165~185° Carrier tape Numbers of taping: 1500 pieces / reel. 0.1~0.7N ■ Reminders Please pay sufficient attention to the warnings for safe designing when using these products. ※ The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity:10 to 75% RHor less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. ※ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). ※ Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperaturedoes not exceed 150°C. ※ Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. ※ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermaldesign. ※ Do not expose the products to magnets or magnetic fields. ※ Do not use for a purpose outside of the contents regulated in the delivery specifications. http://www.ecthf.com
CETC0530-3R3M-B 价格&库存
很抱歉,暂时无法提供与“CETC0530-3R3M-B”相匹配的价格&库存,您可以联系我们找货
