250ARHA681M08A6
250ARHA681M08A6
    APAQ(钰邦)
    插件,D8xL16mm
    贴片铝电解电容 AEC_D8X16MM_TM
250ARHA681M08A6 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor ARHA Series High Voltage  Rated Voltage:25~50Vdc    Endurance 5000hrs at 105℃ Suitable for AC-DC、DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Rated Voltage Range Capacitance Tolerance Category Temperature Range -55 to 105℃ 25 to 50Vdc Rated Capacitance Range 47 to 1500 (μF) Surge Voltage Rated voltage x1.15(at 105°C) Dissipation Factor 0.12max.(at 20°C 120Hz) Shall not exceed values shown in standard ratings. Leakage Current ±20% (M) 105℃, 5000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, no voltage applied Appearance No significant damage Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Series Date code Polarity marking (-) Capacitance Voltage Product Specifications are subject to change without notice. SIZE Code øD±0.5 max L α ød±0.05 F±0.4 08X8 08A2 08A6 08B0 10A2 10A6 10B0 8.0 8.0 8.0 8.0 10.0 10.0 10.0 8.0 11.5 16.0 20.0 11.5 16.0 20.0 1.0 1.5 1.5 1.5 1.5 1.5 1.5 0.6 0.6 0.6 0.6 0.6 0.6 0.6 3.5 3.5 3.5 3.5 5.0 5.0 5.0 AP-CON Aluminum Solid Electrolytic Capacitor ARHA Series High Voltage WV/Vdc Cap Size (SV) (μF) Code 220 330 470 560 560 25 (28.8) 680 680 820 1000 1500 68 100 150 220 220 35 330 (40.3) 330 470 470 560 680 47 68 120 50 150 (57.5) 180 220 390 08A2 08A2 08A2 10A2 08A6 08A6 10A2 08B0 10A6 10B0 08X8 08X8 08A2 08A2 10A2 08A6 10A2 08B0 10A6 10A6 10B0 08A2 08A2 08A2 08A6 10A2 10A2 10B0 Leakage ESR Current (mΩmax/20%, (μA) 100k to300kHz) 1,100 1,650 2,350 2,800 2,800 1,496 1,496 4,100 5,000 7,500 476 700 1,050 1,540 1,540 2,310 2,310 3,290 3,290 3,920 4,760 470 680 1,200 1,500 1,800 2,200 3,900 16 16 16 14 16 14 14 13 14 13 28 23 25 25 24 23 24 20 25 23 20 28 28 28 28 28 28 23 Product Specifications are subject to change without notice. Rated Ripple Current (mArms/ 105℃ /100kHz) 4,650 4,650 4,650 5,100 4,650 4,650 5,100 5,100 5,200 5,300 2,800 2,800 3,000 2,890 3,400 3,800 3,400 4,400 4,000 4,200 4,800 2,620 2,620 2,620 2,620 3,100 3,100 3,800 Part No. 250ARHA221M08A2 250ARHA331M08A2 250ARHA471M08A2 250ARHA561M10A2 250ARHA561M08A6 250ARHA681M08A6 250ARHA681M10A2 250ARHA821M08B0 250ARHA102M10A6 250ARHA152M10B0 350ARHA680M08X8 350ARHA101M08X8 350ARHA151M08A2 350ARHA221M08A2 350ARHA221M10A2 350ARHA331M08A6 350ARHA331M10A2 350ARHA471M08B0 350ARHA471M10A6 350ARHA561M10A6 350ARHA681M10B0 500ARHA470M08A2 500ARHA680M08A2 500ARHA121M08A2 500ARHA151M08A6 500ARHA181M10A2 500ARHA221M10A2 500ARHA391M10B0 Rev.A
250ARHA681M08A6 价格&库存
很抱歉,暂时无法提供与“250ARHA681M08A6”相匹配的价格&库存,您可以联系我们找货
