6I48000F20UCG
6I48000F20UCG
    SJK(晶科鑫)
    SMD5032_2P
    无源晶振 48MHz ±20ppm 20pF -40℃~+85℃
6I48000F20UCG 数据手册
SMD Crystal Units Size: 5.0×3.2×1.20 mm 6I Series SMD Crystal Units Features ● 5032 size miniature and lightweight SMD crystal units with low profile of 1.2mm ● Frequency range from 8MHz to 64MHz ● 2 pads SMD glass crystal units ● Excellent heat resistance, high precision ● Application for PDA, GPS, Smart factory, AV equipment, PC, Server, and etc. ● Contain Pb in sealed glass exempted by RoHs directive Standard Specification Item /Type Frequency Range Frequency Tolerance (at 25℃) Frequency stability Over Operating Temperature 6I (6I Series SMD Crystal Units) 8~64 MHz ±30ppm, or specify Operating Temperature Range Shunt Capacitance (C 0 ) -20~+70℃, or specify 5pF Max. Drive Level Load Capacitance Aging (at 25℃) Storage Temperature Range Packing Unit 1~200μW Max. (100μW Typ.) 10pF, 16pF, 20pF, or specify ±3ppm /year Max. -40~+85℃ 1000pcs./Reel ±30ppm, or specify Equivalent Series Resistance Fundamental 8~10 MHz 10~12 MHz 150Ω Max. 100Ω Max. 12~40 MHz 40~64 MHz 50Ω Max. 100Ω Max. Dimensions [mm] SJK 27. 000 2 Top View 1.2±0.15 1.7 2 2 1.7 2.0 2.4 Buttom View 2 Top View Crystal Connection Side View 1 1 2.4 1 3.2±0.15 5.0±0.15 Top View Suggested Layout
6I48000F20UCG 价格&库存
很抱歉,暂时无法提供与“6I48000F20UCG”相匹配的价格&库存,您可以联系我们找货
6I48000F20UCG
  • 5+1.61301
  • 50+1.27772
  • 150+1.13400
  • 1000+0.95468
  • 2000+0.87485
  • 5000+0.82699
库存:95
