RPCH16K220FTP
RPCH16K220FTP
    KAMAYA(釜屋电机)
    贴片电阻 0603
RPCH16K220FTP 数据手册
No.: Date: RPCH-K-HTS-0001 /2 2017.4.21 Data sheet Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE Style: RPCH16,20,32,35 AEC-Q200 qualified RoHS COMPLIANCE ITEM Halogen and Antimony Free Note: ・Stock conditions Temperature: +5°C ∼ +35°C Relative humidity: 25% ∼ 75% The period of guarantee: Within 2 year from shipmen t by the company. Solderability shall be satisfied. ・Product specification contained in this data sheet are subject to change at any time without notice ・If you have any questions or a Purchasing Specification for any quality Agreement is necessary, please contact our sales staff. Hokkaido Research Center Approval by: T. Sannomiya Drawing by: M. Shibuya No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 1/10 1. Scope 1.1 This data sheet covers the detail requirements for fixed thick film chip resistors; rectangular type & high power ⋅ anti surge, style of RPCH16,20,32,35. 1.2 Applicable documents JIS C 5201−1: 2011, JIS C 5201−8: 2014, JIS C 5201−8−1: 2014 IEC60115−1: 2008, IEC60115−8: 2009, IEC60115−8−1: 2014 EIAJ RC−2134C−2010 2. Classification Type designation shall be the following form. (Example) RPCH 32 123 J TP K 1 2 3 4 5 6 Style 1 Fixed thick film chip resistors; rectangular type & & high power ⋅ anti surge 2 Rated dissipation and / or dimension 3 Temperature coefficient of resistance K ±100×10−6/ °C Standard −(Dash) Style 4 Rated resistance 123 E24 Series, 3 digit, Ex. 123--> 12kΩ, 1000 E96 Series, 4 digit, Ex. 1000-->100Ω 1022--> 10.2kΩ 5 Tolerance on rated resistance D ±0.5% F ±1% J ±5% 6 Packaging form B TP TE Bulk (loose package) Paper taping Embossed taping Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 2/10 3. Rating 3.1 The ratings shall be in accordance with Table−1. Table−1 Rated dissipation (W) Style RPCH16 K Standard K Standard K Standard K Standard K Standard K Standard K Standard K Standard 0.33 RPCH20 0.5 RPCH32 0.66 RPCH35 0.75 Style RPCH16 RPCH20 RPCH32 RPCH35 Rated resistance range (Ω) Temperature coefficient of resistance (10-6 / °C) ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 10∼1M 1.0∼9.76 10∼1M 1.0∼9.1 10∼1M 1.0∼9.76 10∼1M 1.0∼9.1 10∼1M 1.0∼9.76 10∼1M 1.0∼9.1 10∼1M 1.0∼9.76 10∼1M 1.0∼9.1 Limiting element voltage (V) 150 Isolation voltage (V) 150 200 500 3.2 Climatic category 55/155/56 Tolerance on rated resistance E24, 96 D(±0.5%), F(±1%) E24 J(±5%) E24, 96 D(±0.5%), F(±1%) E24 J(±5%) E24, 96 D(±0.5%), F(±1%) E24 J(±5%) E24, 96 D(±0.5%), F(±1%) E24 J(±5%) Category temperature range(°C) −55~+155 Lower category temperature Upper category temperature Duration of the damp heat, steady state test 3.3 Stability class 5% Preferred number series for resistors − 55 °C +155 °C 56days Limits for change of resistance: −for long−term tests ±(5%+0.1Ω) −for short−term tests ±(1%+0.05Ω) 3.4 Derating The derated values of dissipation at temperature in excess of 70 °C shall be as indicated by the following curve. 100 Percentage of the rated dissipation Area of recommended operation (%) 0 −55 70 155 Ambient temperature (°C) Figure–1 Derating curve Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 3/10 3.5 Rated voltage d.c.or a.c.r.m.s.voltage calculated from the square root of the product of the rated resistance and the rated dissipation. E: Rated voltage (V) E = P · R P: Rated dissipation (W) R: Rated resistance (Ω) Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical resistance value. At high value of resistance, the rated voltage may not be applicable. 4. Packaging form The standard packaging form shall be in accordance with Table−2. Table−2 Symbol B TP TE Packaging form Bulk (loose package) Paper taping Embossed taping 8mm width, 4mm pitches 8mm width, 4mm pitches Standard packaging quantity / units 1,000 pcs. 5,000 pcs. 4,000 pcs. Application RPCH16,20,32,35 RPCH16,20,32 RPCH35 W 5. Dimensions 5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3. L c d d H c Figure−2 Table−3 +0.15 -0.05 H 0.45±0.10 c 0.3±0.2 Unit: mm d 0.3±0.1 2.0±0.1 1.25±0.10 0.55±0.10 0.3±0.2 0.4±0.2 RPCH32 3.1±0.1 1.6±0.15 0.55±0.10 0.4±0.25 0.5±0.25 RPCH35 3.1±0.15 2.5±0.15 0.55±0.15 0.4±0.25 0.5±0.25 Style RPCH16 L 1.6±0.1 RPCH20 W 0.8 5.2 Net weight (Reference) Style Net weight(mg) RPCH16 2 RPCH20 5 RPCH32 9 RPCH35 16 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 4/10 6. Marking Resistor The Rated resistance shall be marked in 3 digits (E24) or 4 digits (E96) and marked on over coat side. • E24 series: 3 digits, E96 series: 4 digits In case of the resistance value that E96 overlaps with E24, It is marked by either. The Rated resistance of RPCH16 should not be marked in 4 digits(E96) Marking example Contents Application 3 E24(RPCH16,20,32,35) 123 12×10 [Ω] → 12 [kΩ] E24(RPCH 16,20,32,35) 2R2 2. 2 [Ω] 5623 E96(RPCH 20,32,35) 562 ×103 [Ω] → 562 [kΩ] 12R7 E96(RPCH 20,32,35) 12.7 [Ω] 7. Performance 7.1 The standard condition for tests shall be in accordance with Sub−clause 4.2, JIS C 5201−1: 2011. 7.2 The performance shall be satisfied in Table−4. Table−4(1) No. Test items Performance requirements Condition of test (JIS C 5201−1) 1 Visual examination As in 4.4.1 Sub−clause 4.4.1 The marking shall be legible, as Checked by visual examination. checked by visual examination. 2 Dimension Sub−clause 4.4.2 As specified in Table−3 of this specification. Resistance As in 4.5.2 Sub−clause 4.5 The resistance value shall correspond with the rated resistance taking into account the specified tolerance. 3 Voltage proof Sub−clause 4.7 No breakdown or flash over Method: 4.6.1.4 Test voltage: Alternating voltage with a peak value of 1.42 times the insulation voltage. Duration: 60 s ± 5 s Insulation resistance R≥1GΩ Test voltage: Insulation voltage Duration: 1 min. 4 Solderability As in 4.17.4.5 Sub−clause 4.17 The terminations shall be covered Without ageing Flux: The resistors shall be immersed in a with a smooth and bright solder coating. non−activated soldering flux for 2s. Bath temperature: 235 °C ± 5 °C Immersion time: 2 s ± 0.5 s Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: No 5 6 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 5/10 Table−4(2) Performance requirements Condition of test (JIS C 5201−1) Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Sub−clause 4.13 Overload The applied voltage shall be 2.5 times the rated (in the mounted state) voltage or twice the limiting element voltage, whichever is the less severe. Duration: 2 s No visible damage Visual examination ∆R ≤ ± (1%+0.05Ω) Resistance Solvent resistance of the Sub−clause 4.30 Legible marking marking Solvent: 2−propanol Solvent temperature: 23 °C ± 5 °C Method 1 Rubbing material: cotton wool Without recovery Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Bound strength of the end Sub−clause 4.33 face plating Bent value: 3 mm Test items Final measurements 7 Page: /2 Resistance to soldering heat Component resistance Resistance Sub−clause 4.33.6 Visual examination Sub−clause 4.18 Solder temperature: 260 °C ± 5 °C Immersion time: 10 s ± 0.5 s Visual examination Resistance solvent Sub−clause 4.29 Solvent: 2−propanol Solvent temperature: 23 °C ± 5 °C Method 2 Recovery: 48 h Visual examination Resistance ∆R ≤ ± (1%+0.05Ω) No visible damage As in 4.18.3.4 No sign of damage such as cracks. ∆R ≤ ± (1%+0.05Ω) No visible damage ∆R ≤ ± (1%+0.05Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: No 8 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Test items Mounting Adhesion Rapid change temperature 9 Climatic sequence −Dry heat −Damp heat, cycle (12+12hour cycle) First cycle −Cold −Damp heat, cycle (12+12hour cycle) Remaining cycle −D.C. load 10 Mounting Endurance at 70 °C Table−4(3) Condition of test (JIS C 5201−1) Sub−clause 4.31 Substrate material: Epoxide woven glass Sub−clause 4.32 Force: 5 N Duration: 10 s ± 1 s Visual examination Sub−clause 4.19 Lower category temperature:−55 °C Upper category temperature:+155 °C Duration of exposure at each temperature: 30 min. Number of cycles: 5 cycles. Visual examination Resistance Sub−clause 4.23 Sub−clause 4.23.2 Test temperature: +155 °C Duration: 16 h Sub−clause 4.23.3 Test method: 2 Test temperature: 55 °C [Severity(2)] Sub−clause 4.23.4 Test temperature −55 °C Duration: 2h Sub−clause 4.23.6 Test method: 2 Test temperature: 55 °C [Severity (2)] Number of cycles: 5 cycles Sub−clause 4.23.7 The applied voltage shall be the rated voltage or the limiting element voltage whichever is the smaller. Duration: 1 min. Visual examination Resistance Sub−clause 4.31 Substrate material: Epoxide woven glass Sub−clause 4.25.1 Ambient temperature: 70 °C ± 2 °C Duration: 1000 h The voltage shall be applied in cycles of 1.5 h on and 0.5 h. The applied voltage shall be the rated voltage or the limiting element voltage whichever is the smaller. Examination at 48 h , 500 h and 1000 h: Visual examination Resistance Page: /2 6/10 Performance requirements No visible damage No visible damage ∆R ≤ ±(1%+0.05Ω) No visible damage ∆R ≤ ± (5%+0.1Ω) No visible damage ∆R ≤ ± (5%+0.1Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: No 11 12 13 FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 7/10 Table−4(4) Performance requirements Condition of test (JIS C 5201−1) Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Variation of resistance with Sub−clause 4.8 As in Table−1 temperature −55 °C / +20 °C +20 °C / +155°C Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Damp heat, steady state Sub−clause 4.24 Ambient temperature: 40 °C ± 2 °C Relative humidity : 93 +2 −3 % a) 1st group: without voltage applied. b) 2nd group: The d. c. voltage shall be applied continuously. The voltage shall be accordance with Sub−clause 4.24.2.1 b). without polarizing voltage [4.24.2.1, c)] No visible damage Visual examination Legible marking ∆R ≤ ± (5%+0.1Ω) Resistance Test items Dimensions (detail) Sub−clause 4.4.3 As in Table−3 Mounting Sub−clause 4.31 Substrate material: Epoxide woven glass Endurance at upper category Sub−clause 4.25.3 temperature Ambient temperature:155 °C ± 2 °C Duration: 1000 h Examination at 48 h, 500 h and 1000 h: Visual examination Resistance No visible damage ∆R ≤ ± (5%+0.1Ω) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 8/10 8. Taping 8.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010 8.2 Taping dimensions 8.2.1 Taping dimensions shall be in accordance with Figure−3 and Table−5. Unit: mm 4±0.1 t φ1.5 Sprocket hole 1 +0.1 0 2±0.05 1.75±0.1 B 8±0.2 A t Carrier cavity 2 4±0.1 3.5±0.05 Direction of unreeling Style RPCH16 RPCH20 RPCH32 Figure−3 Table−5 A B 1.15±0.15 1.9±0.2 1.65±0.15 2.5±0.2 2.00±0.15 3.6±0.2 t1 0.6±0.1 0.8±0.1 0.8±0.1 Unit: mm t2 0.8max. 1.0max. 1.0max. 8.2.2 Embossed taping dimensions shall be in accordance with Figure−4 and Table−6. Unit: mm 0.3 max. 2±0.05 Sprocket hole φ1.5+0.1 0 1.75±0.1 4±0.1 Carrier cavity t1 W B E A Direction of unreeling 4±0.1 Figure−4 Table−6 Style RPCH35 A 2.85±0.20 B 3.5±0.2 W 8.0±0.3 E 3.5±0.05 Unit: mm t1 1.0±0.2 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 9/10 1). The cover tapes shall not cover the sprocket holes. 2). Tapes in adjacent layers shall not stick together in the packing. 3). Components shall not stick to the carrier tape or to the cover tape. 4). Pitch tolerance over any 10 pitches ±0.2mm. 5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the following RPCH16,20,32:Figure−4,RPCH35:Figure-5. 6). When the tape is bent with the minimum radius for 25 mm, the tape shall not be damaged and the components shall maintain their position and orientation in the tape. 7). In no case shall there be two or more consecutive components missing. The maximum number of missing components shall be one or 0.1%, whichever is greater. 8). The resistors shall be faced to upward at the over coating side in the carrier cavity. Top cover tape Carrier tape 165°to180° Peel−off ( About 300mm/ min) Direction of unreeling Figure−5 Top cover tape Carrier tape 165°to180° Peel−off (About 300mm/ min) Direction of unreeling Figure−6 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21 No: RPCH−K−HTS−0001 Title: FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35 Page: /2 10/10 8.3 Reel dimension Reel dimensions shall be in accordance with the following Figure−7 and Table−7. Plastic reel (Based on EIAJ ET−7200C) Unit: mm 0     +1 φ60      0 φ13±0.2 2±0.5 φ180 −1.5 Marking A φ21±0.8 Marking B A B Figure−7 Table−7 Unit: mm A B Note Style 11.4±1.0 Injection molding RPCH16,20,32,35 9 +1.0 0 13±1.0 Vacuum forming Note: Marking label shall be marked on a place of Marking A or two place of marking A and B. 8.4 Leader and trailer tape. (Example) 400mm min. 100mm min. 160mm min. End Start Trailer Leader Direction of unreeling Figure−8 9. Marking on package The label of a minimum package shall be legibly marked with follows. 9.1 Marking A (1) Classification (Style, Temperature coefficient of resistance, Rated resistance, Tolerance on rated resistance, Packaging form) (2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark 9.2 Marking B (KAMAYA control label) (5) Others Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21
RPCH16K220FTP 价格&库存
很抱歉,暂时无法提供与“RPCH16K220FTP”相匹配的价格&库存,您可以联系我们找货
