LV series
LV Series
Features
SMD
◆ 85℃ standard, case diameter φ4~φ10mm
◆ Reflow soldering is available
◆ Available for high density mounting
◆ For detail specifications, please refer to Engineering Bulletin No. E130
◆ RoHS Compliant
Specifications
Item
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Performance Characteristics
-40~ +85℃
4~50 VDC
0.1 to 1500μF
±20%(120Hz,+20℃)
I≦0.01 CV or 3 (μA)
After 2 minutes, whichever is greater measured with rated working voltage applied
Leakage Current (+20℃,max.)
Rated voltage(VDC)
D.F.(%)
φ4~6.3
max
φ8~10
Dissipation Factor
(tanδ,at 20℃,120Hz)
4
42
45
6.3
30
34
10
22
26
16
18
16
16
35
14
14
50
14
14
4
7
15
6.3
4
8
10
3
8
16
2
4
25
2
4
35
2
3
50
2
3
Impedance ratio max
Low Temperature Characteristics
(at 120Hz)
Load Life
Shelf Life
Rated voltage(VDC)
Z-25℃ Z+20℃
Z-40℃ Z+20℃
Test conditions
Duration time
:2000 Hrs
Ambient temperature
:+85℃
Applied voltage
:Rated DC working voltage
After test requirement at +20℃:
Capacitance change
:Within ±25% of the initial value
Dissipation factor
:Not more than 200% of specified value
Leakage current
:Not more than the specified value
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+85℃
Applied voltage
:None
After test requirement at +20℃ : Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
The capacitors shall be kept on the hot plate maintained at 250℃for 30 seconds. After removing form the
hot plate and restored at room temperature, they meet the characteristic requirements listed under.
Resistance to soldering heat
Leakage current
Capacitance change
Less than specified value
Within ±10% of initial value
tanδ
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz)
0.1≦CAP≦100μF
100<CAP≦1500μF
60(50)
0.8
0.8
120
1.0
1.0
500
1.20
1.10
1K
1.30
1.15
≧10K
1.50
1.20
Diagram of Dimensions:(unit:mm)
φD
4
5
6.3
6.3
8
8
10
Cathode
57
L
A
B
C
5.5 4.3 4.3 4.9
5.5 5.3 5.3 5.9
5.5 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.5 8.3 8.3 9.0
10.5 8.3 8.3 9.0
10.5 10.3 10.3 11.0
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
P
1.0
1.4
2.2
2.2
2.3
3.1
4.5
LV series
Case Size
φDxL(mm)
WV (SV)
Cap(μF)
0.1
0.22
0.33
0.47
1
2.2
3.3
4.7
10
Size
4
(5)
Ripple
22
33
47
4X5.5
28
100
4X5.5
34
220
6.3X5.5
61
6.3X7.7
8X6.5
8X6.5
8X10.5
8X10.5
8X10.5
10X10.5
10X10.5
10X10.5
135
145
220
220
242
285
370
410
470
330
470
560
680
1000
1200
1500
6.3
(8)
Size
Ripple
10
(13)
Size
Ripple
4X5.5
4X5.5
5X5.5
4X5.5
5X5.5
21
33
37
41
43
5X5.5
16
(20)
Size
Ripple
4X5.5
23
4X5.5
37
5X5.5
45
52
5X5.5
6.3X5.5
50
60
25
(32)
Size
Ripple
4X5.5
4X5.5
5X5.5
6.3X5.5
5X5.5
6.3X5.5
18
27
40
40
46
54
6.3X5.5
60
6.3X7.7
8X6.5
35
(44)
Size
Ripple
4X5.5
4X5.5
5X5.5
6.3X5.5
18
29
45
48
6.3X5.5
58
150
160
6.3X5.5
8X6.5
6.3X7.7
8X10.5
65
115
250
280
8X10.5
300
10X10.5
400
10X10.5
460
4X5.5
29
4X5.5
5X5.5
4X5.5
5X5.5
33
37
40
46
5X5.5
70
6.3X5.5
76
6.3X5.5
100
6.3X7.7
8X6.5
6.3X7.7
8X6.5
141
150
197
210
6.3X7.7
8X6.5
170
190
6.3X7.7
8X10.5
185
290
8X10.5
330
8X10.5
330
10X10.5
450
8X10.5
380
8X10.5
420
10X10.5
480
10X10.5
460
8X10.5
8X10.5
10X10.5
10X10.5
10X10.5
410
460
500
510
530
10X10.5
10X10.5
10X10.5
450
480
510
10X10.5
500
50
(63)
Size
Ripple
4X5.5
1.0
4X5.5
2.0
4X5.5
2.8
4X5.5
4.0
4X5.5
8.4
4X5.5
14
4X5.5
17
4X5.5
22
6.3X5.5
35
6.3X7.7
75
8X6.5
80
6.3X7.7
188
8X6.5
200
6.3X7.7
225
8X6.5
240
8X10.5
300
10X10.5
450
Ripple Current ( mA, rms ) at 85℃ 120Hz
58
很抱歉,暂时无法提供与“LV221M010F065ETR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71583
- 50+0.57057
- 150+0.49799
- 1000+0.44356
- 2000+0.39993
- 5000+0.37822
