LV101M6R3C055ETR
LV101M6R3C055ETR
    CAPXON(台湾丰宾)
    SMD,D5xL5.5mm
    贴片铝电解电容 SMD
LV101M6R3C055ETR 数据手册
LV series LV Series Features SMD ◆ 85℃ standard, case diameter φ4~φ10mm ◆ Reflow soldering is available ◆ Available for high density mounting ◆ For detail specifications, please refer to Engineering Bulletin No. E130 ◆ RoHS Compliant Specifications Item Operating Temperature Range Rated Voltage Range Capacitance Range Capacitance Tolerance Performance Characteristics -40~ +85℃ 4~50 VDC 0.1 to 1500μF ±20%(120Hz,+20℃) I≦0.01 CV or 3 (μA) After 2 minutes, whichever is greater measured with rated working voltage applied Leakage Current (+20℃,max.) Rated voltage(VDC) D.F.(%) φ4~6.3 max φ8~10 Dissipation Factor (tanδ,at 20℃,120Hz) 4 42 45 6.3 30 34 10 22 26 16 18 20 25 16 16 35 14 14 50 14 14 4 7 15 6.3 4 8 10 3 8 16 2 4 25 2 4 35 2 3 50 2 3 Impedance ratio max Low Temperature Characteristics (at 120Hz) Load Life Shelf Life Rated voltage(VDC) Z-25℃ Z+20℃ Z-40℃ Z+20℃ Test conditions Duration time :2000 Hrs Ambient temperature :+85℃ Applied voltage :Rated DC working voltage After test requirement at +20℃: Capacitance change :Within ±25% of the initial value Dissipation factor :Not more than 200% of specified value Leakage current :Not more than the specified value Test conditions Duration time :1000 Hrs Ambient temperature :+85℃ Applied voltage :None After test requirement at +20℃ : Same limits as Load life. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. The capacitors shall be kept on the hot plate maintained at 250℃for 30 seconds. After removing form the hot plate and restored at room temperature, they meet the characteristic requirements listed under. Resistance to soldering heat Leakage current Capacitance change Less than specified value Within ±10% of initial value tanδ Less than specified value Multiplier for Ripple Current vs. Frequency CAP(μF) Frequency(Hz) 0.1≦CAP≦100μF 100<CAP≦1500μF 60(50) 0.8 0.8 120 1.0 1.0 500 1.20 1.10 1K 1.30 1.15 ≧10K 1.50 1.20 Diagram of Dimensions:(unit:mm) φD 4 5 6.3 6.3 8 8 10 Cathode 57 L A B C 5.5 4.3 4.3 4.9 5.5 5.3 5.3 5.9 5.5 6.6 6.6 7.2 7.7 6.6 6.6 7.2 6.5 8.3 8.3 9.0 10.5 8.3 8.3 9.0 10.5 10.3 10.3 11.0 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 P 1.0 1.4 2.2 2.2 2.3 3.1 4.5 LV series Case Size φDxL(mm) WV (SV) Cap(μF) 0.1 0.22 0.33 0.47 1 2.2 3.3 4.7 10 Size 4 (5) Ripple 22 33 47 4X5.5 28 100 4X5.5 34 220 6.3X5.5 61 6.3X7.7 8X6.5 8X6.5 8X10.5 8X10.5 8X10.5 10X10.5 10X10.5 10X10.5 135 145 220 220 242 285 370 410 470 330 470 560 680 1000 1200 1500 6.3 (8) Size Ripple 10 (13) Size Ripple 4X5.5 4X5.5 5X5.5 4X5.5 5X5.5 21 33 37 41 43 5X5.5 16 (20) Size Ripple 4X5.5 23 4X5.5 37 5X5.5 45 52 5X5.5 6.3X5.5 50 60 25 (32) Size Ripple 4X5.5 4X5.5 5X5.5 6.3X5.5 5X5.5 6.3X5.5 18 27 40 40 46 54 6.3X5.5 60 6.3X7.7 8X6.5 35 (44) Size Ripple 4X5.5 4X5.5 5X5.5 6.3X5.5 18 29 45 48 6.3X5.5 58 150 160 6.3X5.5 8X6.5 6.3X7.7 8X10.5 65 115 250 280 8X10.5 300 10X10.5 400 10X10.5 460 4X5.5 29 4X5.5 5X5.5 4X5.5 5X5.5 33 37 40 46 5X5.5 70 6.3X5.5 76 6.3X5.5 100 6.3X7.7 8X6.5 6.3X7.7 8X6.5 141 150 197 210 6.3X7.7 8X6.5 170 190 6.3X7.7 8X10.5 185 290 8X10.5 330 8X10.5 330 10X10.5 450 8X10.5 380 8X10.5 420 10X10.5 480 10X10.5 460 8X10.5 8X10.5 10X10.5 10X10.5 10X10.5 410 460 500 510 530 10X10.5 10X10.5 10X10.5 450 480 510 10X10.5 500 50 (63) Size Ripple 4X5.5 1.0 4X5.5 2.0 4X5.5 2.8 4X5.5 4.0 4X5.5 8.4 4X5.5 14 4X5.5 17 4X5.5 22 6.3X5.5 35 6.3X7.7 75 8X6.5 80 6.3X7.7 188 8X6.5 200 6.3X7.7 225 8X6.5 240 8X10.5 300 10X10.5 450 Ripple Current ( mA, rms ) at 85℃ 120Hz 58
LV101M6R3C055ETR 价格&库存
很抱歉,暂时无法提供与“LV101M6R3C055ETR”相匹配的价格&库存,您可以联系我们找货
