XYCCCLNANF-26M
XYCCCLNANF-26M
    TAITIEN(泰艺)
    SMD2520_4P
    无源晶振 26MHz ±20ppm 10pF -40℃~+85℃
XYCCCLNANF-26M 数据手册
1 Crystal Units RoHS compliance Crystal Units XY 2.5x2.0x0.55mm typ 12MHz up to 60MHz Type Feature A small surface mount type crystal unit,especially suited for small-sizing requirements. Ultra compact and thin.(2.5×2.0×0.55mm typ.) Tight Tolerance 10 ppm available. RoHS Compliant Application:Bluetooth ;Mobile phone;W-LAN;Office Automation;Audio & Video. Meets the requirements for re-flow profiling using lead-free solder. Specifications Type Item Frequency Range Oscillator Mode Load Capacitance Drive Level Frequency Tolerance Series Resistance Operating Temperature Range Storage Temperature Range Packing Unit XY-Type 12~13MHz 13~16MHz 16~20MHz 20~30MHz 30~60MHz Fundamental Series,8pF,10pF,12pF 10μW(100μW max.) -6 ±10×10 ,±20×10-6,±30×10-6,±50×10 -6 (at 25°C) 200 Ω max. 100 Ω max. 80 Ω max. 60 Ω max. 40 Ω max. -10~+60°C, -20~+70°C, -40~+85°C -40~+85°C 3000pcs./reel(Ø180) Outline Drawing 2.5 Internal connections (TOP VIEW) #3 #1 #2 2.0 #4 0.55max *#2 and #4 are connected with metal cap. Of top. Reference land pattern #1 Q.C #2 PASS 1.4 1.0 0.55 1.25 1.15 1.6 1.75 Frequency Stability Vs. Temperature Range ±15 √√√ Available(case by case) Contact:www.chinatact.com × + √ Standard ±10 × -10 ~ +60 -20 ~ +70 -40 ~ +85 ±5 √√ PPm + × × Temp.(°C) T1106A #3 #4 0.73 Sales@chinatact.com Not Available Oscillation Circuit of Fundamental Mode RF R C1 Crys tal C2 CL= C1*C2 C1+C2 +3~5pf 15
XYCCCLNANF-26M 价格&库存
很抱歉,暂时无法提供与“XYCCCLNANF-26M”相匹配的价格&库存,您可以联系我们找货
