TR Series Thin Film Chip Resistor
Product Specifications
Document No. S-10-12-03-05
Released Date 2019/12/30
Page No.
1/9
■ Thin Film Chip Resistor Product Specifications — TR Series
Top view
Bottom view
■ Applications
█ Features
— Consumer electronics
— Tolerance to ±0.1 %
— Computer
— Low TCR to ±10 ppm/℃
— Telecom
— Halogen free and lead free
— Measuring instrument
— RoHS compliant
— Printing equipment
— Converter
■ Parts Number Explanation
Example:
TR
1206
B
10K0
P
05
25
Z
Product
Type
Size
(Inch)
Tolerance
Resistance
Package
Quantity
(PCS)
TCR
(ppm/℃)
Optional
TR Series
Thin Film
Chip
Resistor
0402
0603
0805
1206
1210
2010
2512
B:±0.1%
C:±0.25%
D:±0.5%
4 digits
EX.
2R49 = 2.49 Ω
10R0 = 10 Ω
100R = 100 Ω
2K20 = 2.2 KΩ
332K = 332 KΩ
1M00 = 1 MΩ
P : Paper Taping
(0603~1210)
Q : Paper Taping
(0402)
E : Embossed
Taping
B : Bulk
F:±1.0%
04:4000
05:5000
10:10000
20:20000
40:40000
50:50000
10:±10
15:±15
25:±25
50:±50
Z : default
code
Page No.
2/9
■ Standard Electrical Specifications
項目 Item
型別 Type
TR0402
TR0603
TR0805
TR1206
TR1210
額定功率
Rated
Power
at 70℃
0.063W
0.1W
0.125W
阻值範圍
最大工作電壓
Max Working Max Overload
Voltage
Voltage
25V
75V
150V
TR2512
50V
150V
300V
0.25W
0.25W
200V
TR2010
最大過負載電壓
400V
0.5W
0.75W
● For non-standard parts, please contact our sales dept.
● Operating Temperature Range :−55℃〜+155℃.
Resistance Range
溫度係數
T.C.R.
(PPM/℃)
±10
±15
±25
±50
±10
±15
±25
±50
±10
±15
±25
±50
±10
±15
±25
±50
±10
±15
±25
±50
±10
±15
±25
±50
±10
±15
±25
±50
B (±0.1%)
C (±0.25%)
D (±0.5%)
F (±1%)
10Ω ~ 68KΩ
4.7Ω ~ 220KΩ
2.49Ω ~ 220KΩ
10Ω ~ 332KΩ
4.7Ω ~ 680KΩ
2.49Ω ~ 680KΩ
10Ω ~ 680KΩ
4.7Ω ~ 1MΩ
2.49Ω ~ 1MΩ
10Ω ~ 1MΩ
4.7Ω ~ 1.5MΩ
2.49Ω ~ 1.5MΩ
10Ω ~ 100KΩ
4.7Ω ~ 100KΩ
2.49Ω ~ 100KΩ
10Ω ~ 100KΩ
4.7Ω ~ 100KΩ
2.49Ω ~ 100KΩ
10Ω ~ 100KΩ
4.7Ω ~ 100KΩ
2.49Ω ~ 100KΩ
Page No.
3/9
■ Construction
①
Alumina
Substrate
④
Bottom Inner
Electrode
⑦
②
Resistive
Layer
⑤
Protective
Overcoat
⑧ Nickel Barrier
③
Top Inner
Electrode
⑥ Marking
⑨
Side Inner
Electrode
Solder
coating (Sn)
■ Dimensions
Unit : mm
TYPE
L
W
H
l1
l2
TR0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.15 ± 0.10
0.20 ± 0.10
TR0603
1.60 ± 0.20
0.80 ± 0.15
0.40 ± 0.10
0.20 ± 0.15
0.30 ± 0.10
TR0805
2.00 ± 0.20
1.25 ± 0.15
0.50 ± 0.15
0.20 ± 0.15
0.40 ± 0.15
TR1206
3.05 ± 0.10
1.60 ± 0.20
0.55 ± 0.15
0.30 ± 0.20
0.50 ± 0.20
TR1210
3.05 ± 0.10
2.50 ± 0.20
0.55 ± 0.15
0.30 ± 0.20
0.50 ± 0.20
TR2010
5.00 ± 0.20
2.50 ± 0.20
0.55 ± 0.10
0.30 ± 0.15
0.60 ± 0.20
TR2512
6.30 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.40 ± 0.20
0.60 ± 0.20
Page No.
4/9
■ Performance Characteristics
Power Derating Curve
The Operating Temperature Range: -55°C ~+155°C.
Power rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at
ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating
Curve.
DERATING CURVE
100
Power Ratio(%)
80
60
40
155℃
60
70
80 100 120 140 160
Ambient Temperature (℃)
Rated Voltage
Resistance Range: ≧1Ω
Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous
working voltage at commercial-line frequency and wave form corresponding to the power rating, as
determined formula as following:
V = √𝐏 × 𝐑
V = Rated voltage (V)
P = Rated power (W)
R = Nominal resistance (Ω)
Page No.
5/9
■ Reliability Tests and Requirements
Test Item
Test Method
Procedure
Requirements
Temperature
Coefficient of
Resistance
(T.C.R)
JIS C 5201-1
clause 4.8
At +25℃/-55℃ and +25℃/+125℃.
Refer to Standard Electrical
Specifications
Short Time
Overload
JIS C 5201-1
clause 4.13
2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
±(0.5%+0.05Ω)
No Visual damage
Insulation
Resistance
JIS C 5201-1
clause 4.6
100V for 1 minute.
≧10GΩ
Solderability
JIS C 5201-1
clause 4.17
245±5°C for 3±0.5secs.
>95% Coverage
No Visual damage
Resistance to
Soldering Heat
JIS-C5201-1
clause 4.18
260±5℃ for 10 seconds.
±(0.5%+0.05Ω)
No Visual damage
Leaching
JIS-C5201-1
clause 4.18
260±5℃ for 30 seconds.
>95% Coverage
No Visual damage
Temperature
Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃, 300 cycles
±(0.5%+0.05Ω)
No Visual damage
High Temperature
Exposure
JIS-C5201-1
4.25
155±5℃ for 1000 +48/-0 hours.
±(0.5%+0.05Ω)
Resistance to
Solvent
JIS C 5201-1
clause 4.29
The tested resistor be immersed into isopropyl
alcohol of
20~25℃ for 60 secs.
Then the resistor is left in the room for 48 hrs.
±(0.5%+0.05Ω)
No Visual damage
Load Life in
Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. , Rated power or Max.
working current whichever is less for 1000 hrs with
1.5 hrs〝ON〞and 0.5 hr〝OFF〞.
±(0.5%+0.05Ω)
Load Life
(Endurance)
JIS C 5201-1
clause 4.25
70±2℃, Rated power, or Max. working current
whichever is less for 1000 hrs with 1.5 hrs〝ON〞and ±(0.5%+0.05Ω)
0.5 hr〝OFF〞.
Terminal Bending
Strength
JIS C 5201-1
clause 4.33
Bending once for 5 seconds
D: 0402、0603、0805=5mm
1206、1210 =3mm
2010、2512 = 2mm
±(0.5%+0.05Ω)
No Visual damage
Page No.
6/9
■ Recommended Customer Soldering Parameters
Wave solder Temperature condition
Solder reflow Temperature condition
Rework temperature(hot air equipment):350℃, 3~5seconds
Recommended reflow methods
IR, vapor phase oven, hot air oven
If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
■ Recommend Land Pattern Design
Unit: mm
Type
0402
0603
0805
1206
1210
2010
2512
A
0.60
0.80
1.30
2.20
2.00
3.80
4.90
B
1.60
2.40
2.90
4.20
4.40
6.60
8.10
C
0.70
1.00
1.40
1.70
2.70
2.70
3.40
Item
Page No.
7/9
■ Marking
0402: no marking
01C
1002
0603: 3 digits code
0805~2512: 4 digits code
No marking on 0402 type
3 digits code for 0603 type
Standard E96 Values and 0603 Resistance Codes
R-Value 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174
Code
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
22
23
24
R-Value 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309
Code
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
R-Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549
Code
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
R-Value 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976
Code
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
E96 Multiplier Code
Code
A
B
Multiplier
C
1
10
10
10
D
2
E
3
F
4
10
G
5
10
H
6
10
X
7
10
Y
-1
10
Z
-2
10
-3
10
10
1. 0603 3 digits coding formula for E96 values as following:
CODING
XX
FORMULA
2
Example: 10.2KΩ = 102 x 10 Ω = 02C
X
Multiplier Code
02
C
-1
33.2Ω = 332 x 10 Ω = 51X
Resistance Code
51
X
EX.: 1Ω=01Y ; 7.5Ω=85Y ; 11Ω=05X ; 130Ω=12A ; 2KΩ= 30B ; 10KΩ=01C ; 150KΩ=18D
E24
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
2. 0603 3 digits for E24 values
Examples:
Resistance
3 digits code
4.7Ω
4R7
33Ω
330
470Ω
471
5.6KΩ
562
62KΩ 680KΩ
623
684
("R"= decimal point)
3. 0603 E192 values are no marking.
4 digits code for 0805 ~ 2512 type
First 3 digits are the significant figures, the 4th digit is the multiplier. "R"= decimal point.
Examples:
Resistance
1Ω
5.6Ω
10Ω
22.6Ω
100Ω
1.1KΩ
4 digits code
1R00
5R60
10R0
22R6
1000
1101
10KΩ 332KΩ
1MΩ
1002
1004
3323
75
82
91
Page No.
8/9
■ Packaging Information
Reel Dimensions
TYPE
0402
0402
0603/0805/1206/
1210
0603/0805
/1206
2010/2512
60±1.0
100±1.0
W
11.5±2.0
11.5±2.0
Unit: mm t
ψM
178±2.0
330±2.0
21±1.0
60±1.0
11.5±2.0
178±2.0
21±1.0
21±1.0
21±1.0
100±1.0
100±1.0
60±1.0
11.5±2.0
11.5±2.0
16.0±2.0
254±2.0
330±2.0
178±2.0
A
2.0±0.5
2.0±0.5
ψB
ψC
ψD
7”
13”
SIZE
10K/Reel
40K/50K Reel
13.5±1.0
13.5±1.0
21±1.0
21±1.0
7”
5K/Reel
2.0±0.5
13.5±1.0
10”
13”
7”
10K/Reel
20K/Reel
4K/Reel
2.0±0.5
2.0±0.5
2.0±0.5
13.5±1.0
13.5±1.0
13.5±1.0
Paper Tape Dimensions
Paper
Carrier
Unit: mm
Type
W
E
F
G
H
T
0402
0.70±0.10 1.20±0.10
8.0±0.20
1.75±0.10
3.5±0.05
4.0±0.10
2.0±0.05
0.45±0.10
0603
1.05±0.20 1.80±0.20
8.0±0.20
1.75±0.10
3.5±0.05
4.0±0.10
2.0±0.05
0.60±0.10
0805
1.55±0.20 2.30±0.20
8.0±0.20
1.75±0.10
3.5±0.05
4.0±0.10
2.0±0.05
0.75±0.10
1206
1.90±0.20 3.50±0.20
8.0±0.20
1.75±0.10
3.5±0.05
4.0±0.10
2.0±0.05
0.75±0.10
1210
2.85±0.20 3.50±0.20
8.0±0.20
1.75±0.10
3.5±0.05
4.0±0.10
2.0±0.05
0.75±0.10
A
B
ψD
P
2.0±0.10
4.0±0.10
Plastic Embossed Tape Dimensions
Unit: mm
Type
A
B
W
E
F
G
H
T
ψD
ΨD1
T1
2010
2.80±0.20 5.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10
1.50±0.10 0.85±0.15
2512
3.40±0.20 6.70±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10
1.50±0.10 0.85±0.15
P
4.0±0.10
Page No.
9/9
Front & Back Lead Dimensions
Top Adhesive Peel Off Strength:10~70g
Package
Inner Box Size
External Box Size
Contain Length
(Kpcs)
(mm)
Width
(mm)
Width
(mm)
180
180
60
50K
180
180
110
150K
430
200
200
300K
400
400
200
Reel
Size
H(mm)
1
13
25K
2
24
3
36
5
60
10
113
Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
很抱歉,暂时无法提供与“TR0805B442KP0525Z”相匹配的价格&库存,您可以联系我们找货
