YSO751SR
Features
000
X
XX
1 2 5
X
C
Y X
. External dimensions: 7.0 x 5.0 x 1.3 mm.
. Frequency range: 1MHz ~ 200MHz.
. Small SMD seam sealed clock crystal oscillator units.
.High precision characteristic covering up to wide frequency range.
.Designed for automatic mounting and reflow soldering.
.Tri-State function available
.High stability, low jitter, low power consumption.
. Applications: wireless communication, PC, and LCDM.
Electrical Specifications
Item / Type
YSO751SR
Output Frequency Range
1 ~ 200 MHz
Output Type
CMOS
Supply Voltage
1.8V/2.5V/3.3V/5V, or specify
Oscillation Mode
Fundamental / 3rd Overtone
Frequency Tolerance
± 20ppm, ± 25ppm,
or specify
Output Load
15 pF, or specify
Operating Temperature Range
- 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify
Storage Temperature Range
- 40 ~ + 85 ℃ , - 55 ~ + 125 ℃
Voltage Vol ( Max. ) / Vol ( Min. )
90%Vdd min./10%Vdd max
Symmetry
40 ~ 60 % Standard
Rise ( Tr ) / Fall ( Tf ) Time
8 ns Max.
Start-up Time
10 ms Max.
Supply Current
See Below
Frequency Aging ( at 25 ℃ )
± 3 ppm / year Max.
Dimensions
引脚功能定义
引脚
125.000
1
.YXC XXXX
功能
E/D
定义
三态/无三态
2
GND
接地
3
OUTPUT
输出
4
Vdd
电源电压
Units: mm
1/2
YSO751SR
★ PART NUMBER GUIDE 部件号示例
Quartz Crystal Oscillator Dimensions Frequency Supply voltage
(Hz)
(V)
O
125M
7050
Supply voltage
YSO 7 51SR =7 .0×5.0 SMD SEAM TYPE
e.g. O 7 050125MEEA4 SC
Frequency
Stability output
Overall
(ppm)
E
Frequency tolerance
Pin
Range
4
A
E
A
1.8V
D
±20PPM
C
E
3.3V
E
±25PPM
I
-40 to 85 ℃
F
5.0V
H
±50PPM
C
S
Output
Operating temperature
-20 to 70 ℃
Material Operating Temp.
A
CMOS
★ INPUT CURRENT 工作电流
Vdc=1.8 ~ 3.3V
Vdc=5.0V
15pF only
15pF only
25 mA max
1.0 ~ 35.999 MHz
20mA max
36.0 ~ 69.999 MHz
60mA max
36.0 ~ 69.999 MHz
40mA max
70.0 ~ 150 MHz
80mA max
70.0 ~ 150 MHz
60mA max
1.0 ~ 35.999 MHz
★ TAPING SPECIFICATION (Unit: mm)
φ1.31
4.0
编带规格
1.02
12
0°
φ13
2.0
C
B
D
OSC-SMD7050
G
A
F
E
A
B
178±2.0
16.0±0.3
C
8.40±0.15
D
5.80±0.15
E
F
G
7.88±0.1
1.90±0.1
58.0±1.0
1000 pcs per reel
★ REFLOW SOLDERING PROFILE
★ Test Circuit
回流焊特性
2/2
很抱歉,暂时无法提供与“O705033333MEEA4SC”相匹配的价格&库存,您可以联系我们找货
