1
Crystal Units
RoHS compliance
Crystal Units
XX
3.2×2.5×0.7mm typ.
Tight Tolerance 10ppm
Type
Feature
A small surface mount type crystal unit,especially suited for
small-sizing requirements.
Ultra compact and thin.(3.2×2.5×0.7 mm typ.)
Tight Tolerance 10ppm available.
Application:Bluetooth ;Mobile phone;W-LAN;Office Automation;
Audio & Visual.
Meets the requirements for re-flow profiling using lead-free solder.
Specifications
Type
Item
Frequency Range
Oscillator Mode
Load Capacitance
Drive Level
Frequency Tolerance
Series Resistance
Operating Temperature Range
Storage Temperature Range
Packing Unit
XX-Type
8~12MHz
12~16MHz
16~20MHz 20~30MHz 30~60MHz
Fundamental
Series,8pF,10pF,12pF
10μW(100μW max.)
-6
±10×10 ,±20×10-6,±30×10-6,±50×10 -6 (at 25°C)
100 Ω max. 80 Ω max. 50 Ω max.
40 Ω max.
30 Ω max.
-10~+60°C, -20~+70°C, -40~+85°C
-40~+85°C
3000pcs./reel(Ø180)
Outline Drawing
3.2±0.1
Internal connections (TOP VIEW)
#3
#1
#2
2.5±0.1
#4
0.65±0.1
*#2 and #4 are connected with
metal cap. Of top.
Q.C
Reference land pattern
#1
#2
1.2
0.7
1.6
T1106A
1.7
PASS
#3
#4 0.9
1.4
2.2
2.1
Frequency Stability Vs. Temperature Range
±15
Available(case by case)
16
Standard
±10
-10 ~ +60
-20 ~ +70
-40 ~ +85
±5
PP m
Temp.(°C)
Not Available
Oscillation Circuit of Fundamental Mode
RF
R
C1
Crys tal
C2
CL=
Contact:www.chinatact.com
C1*C2
C1+C2
+3~5pf
Sales@chinatact.com
很抱歉,暂时无法提供与“XXCBELNANF-12M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.96909
- 50+0.77037
- 150+0.67112
- 500+0.59660
