16ME6800CA
16ME6800CA
    SUNCON
    插件,D16xL31.5mm
    直插铝电解电容 AEC_D16X31.5MM_TM
16ME6800CA 数据手册
Aluminum Electrolytic Type / Radial Lead Type Aluminum Electrolytic Capacitors Radial Lead Type ME-SWB ME-CA Low Impedance Small Series ME-CX(P.84) 105℃ 1,000 to 3,000hours ● Solvent proof (within 5 minutes) ● Low Impedance ME-CA Low Impedance ME-CZ (P.80) ■ Specifications Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 0.14 0.12 ME-UZ・SZ Category temperature range (℃) − ME-UAX・SAX Capacitance tolerance (%) 120Hz/20℃ −55 to +105 M : ±20 ME-SWG ME-HC ME-LS ME-CZ ME-CA ME-CX Dissipation Factor(tan δ) Leakage current (LC) ME-WA 0.28 tanδ (max.)120Hz/20℃ 105℃ rated voltage applied (With the rated ripple current) Endurance ME-WL ME-WG Test 0.16 Exceeding 1,000μF, +0.02 every 1,000μF The greater value of either 0.01CV or 3 Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Impedance ratio at Iow temperature 0.20 0.24 μA/after 2minutes (max.) ME-AX ME-WX RoHS compliance 3 3 2 2 2 2 6 5 4 4 3 3 φ5 to φ8 : 1,000hours, φ10 : 2,000hours, φ12.5 to φ16 : 3,000hours △C/C Within ±25% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value ME-FX ME-PX ME-FC・FD ■ Dimensions sleeve ME-SWN ME-HWN φd±0.05 φD±0.5 ME-FH (Unit : mm) F±0.5 ME-HPC・HPD L+αmax. 15min. 20min. φD 5 6.3 8 10 12.5 16 F 2.0 2.5 3.5 5.0 5.0 7.5 φd 0.5 0.5 0.6 0.6 0.6 0.8 5min. α : L
16ME6800CA 价格&库存
很抱歉,暂时无法提供与“16ME6800CA”相匹配的价格&库存,您可以联系我们找货
