6BS05000F20UCG
6BS05000F20UCG
    SJK(晶科鑫)
    HC49S
    无源晶振 5MHz ±20ppm 20pF -40℃~+85℃
6BS05000F20UCG 数据手册
HC-49S Crystal Resonators 6B Series HC-49S Crystal Resonator Features l l l l l l l l Resistance welded type crystal units. A great number of standard frequencies. Wide frequency from 3MHz up to 100MHz. Offers excellent frequency stability. High frequency pullability and lower equivalent series resistance. Lower cost and highly mass production capability. The best choice of TV, STB, LCDM, Communication, Cable modem, etc. RoHS Compliant / Pb-Free. 4 SJ 0 K .0 0 0 Electrical Specifications Item /Type Frequency Range 6B (HC-49S crystal resonator) 3~100MHz Frequency Tolerance(at 25 Ċ ) ±30ppm, or specify Frequency Stability Over Operating Temperature Range ±30ppm, or specify Operating Temperature Range -20~+70°C, or specify Shunt Capacitance(C0) 7pF Max. Drive Level 1~500µW Max.(100µW Typical) Load Capacitance 16pF, 20pF,30pF, 32pF, or specify Aging (at 25°C) ±3ppm / year Max. Storage Temperature Range -55~+125°C Packing Unit 1000pcs Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 3.0~3.686MHz 200 Ω Max. 27~30MHz 100 Ω Max. 3.686~5MHz 150 Ω Max. 30~50MHz 80 Ω Max. 50~100MHz 60 Ω Max. 5~10MHz 80 Ω Max. 10~14MHz 40 Ω Max. 14~30MHz 30 Ω Max. Units:mm Dimensions Http://www.q-crystal.com Mail: sjk@q-crystal.com Tel: 86-755-88352809 Fax: 86-755-88353718
6BS05000F20UCG 价格&库存
很抱歉,暂时无法提供与“6BS05000F20UCG”相匹配的价格&库存,您可以联系我们找货
6BS05000F20UCG
  • 5+0.63880
  • 50+0.50350
  • 200+0.43585
  • 400+0.38511
  • 2000+0.34448
  • 5000+0.32417
库存:133
