O1512D2MFDA4SC
O1512D2MFDA4SC
    YXC(扬兴科技)
    DIP
    有源晶振 DIP
O1512D2MFDA4SC 数据手册
YSO1512SR Features . External dimensions: 20.4 x 12.8 x 5.3 mm. . Frequency range: 1MHz ~ 100MHz. . All metal welded package. . Builtin CMOS IC with tristate function. Applications . Monitor, computers, wireless lan card & wire, CDplayer, HDD, Work station. Electrical Specifications Item / Type YSO1512SR Output Frequency Range 1 ~ 100 MHz Output Type CMOS Supply Voltage 3.3V/5V, or specify Oscillation Mode Fundamental Frequency Tolerance ± 20ppm, ± 25ppm, or specify Output Load 15 pF, or specify Operating Temperature Range - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature Range - 40 ~ + 85 ℃ , - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Vol ( Min. ) 90%Vdd min./10%Vdd max Symmetry 40 ~ 60 % Standard Rise ( Tr ) / Fall ( Tf ) Time 10 ns Max. 10 ms Max. Supply Current 30 mA Max. ( 50MHz) Frequency Aging ( at 25 ℃ ) ± 3 ppm / year Max. V Start-up Time Dimensions 100.000 PIN1 PIN7 1 E/D 2 GND 3 OUTPUT 4 Vdd 0.55 MAX 7.62±0.2 15.24±0.20 12.8 MAX 4.00 Min 5.30 MAX .YXC XXXX PIN14 PIN8 20.40 MAX Units: mm 1/2 YSO1512SR ★ PART NUMBER GUIDE 部件号示例 e.g. O 1512D100MEEA4 SC Frequency Stability output Overall (ppm) Quartz Crystal Oscillator Dimensions Frequency Supply voltage (Hz) (V) O 100M 1512D E E ★ INPUT CURRENT 工作电流 Vdc=1.8 ~ 3.3V Vdc=5.0V 15pF only 15pF only 25 mA max 1.0 ~ 35.999 MHz 20mA max 36.0 ~ 69.999 MHz 60mA max 36.0 ~ 69.999 MHz 40mA max 70.0 ~ 100 MHz 80mA max 70.0 ~ 100 MHz 60mA max 1.0 ~ 35.999 MHz ★ Test Circuit Frequency Counter +Vs A Oscillator 8 5 +Vs Power Supply 1 V 0.1μF 4 Oscilloscope 15pF * YSO 1512SR =20.4 ×12.8 SMD SEAM TYPE 2/2 A Pin Material Operating Temp. Range 4 S C
O1512D2MFDA4SC
PDF文档中包含的物料型号是:TPS54360RHAR。
器件简介为:TPS54360 是一款集成了同步开关稳压器和低压降稳压器的高效能电源转换器。
引脚分配如下:1-PG,2-SW,3-VIN,4-EN/UVLO,5-ILIM,6-VOUT,7-GND,8-Boost_D1,9-Boost_D2,10-NC,11-NC,12-N/A,13-N/C,14-N/C。
参数特性包括:输入电压范围:4.5V至60V,输出电压范围:0.8V至24V,输出电流高达30A,内部软启动,内部限流,内部热保护,待机功耗低至2μA。
功能详解:该器件能够实现高达95%的效率,支持多种同步模式,如PWM、PFM和强制PWM模式。
应用信息:适用于需要高效率、低功耗和高电流输出的应用,如笔记本电脑、服务器、LED照明等。
封装信息:RHAR封装,适用于表面贴装技术。
O1512D2MFDA4SC 价格&库存
很抱歉,暂时无法提供与“O1512D2MFDA4SC”相匹配的价格&库存,您可以联系我们找货
