CRYSTAL UNIT
YSX321SL
Applications
Features
‧SmartWearable
‧Dimensions:3.20 x 2.50 x 0.70 mm.
‧High precision and high frequency stability.
IOT Communication.
‧Standard Frequency: 8~64MHz
‧Extremely good for reducing EMI effect.
Specifications
Standard Frequency
8~64 MHz
Vibration Mode
AT Fundamental
Load Capacitance
10pF,20pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±20ppm,or specify
-20~+70℃,-40~+85℃,or specify
-55~+125℃ or specify
Storage Temperature
Shunt Capacitance
7 pF Max.
Level of Drive
1~200μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
8 ~ 11.2892MHz
12 ~ 16 MHz
17 ~ 64 MHz
Fundamental
150 Ω Max.
80 Ω Max.
50 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX321SL
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-3225
180±2.0
8.0±0.3
3.50±0.1
2.50±0.1
4.0±0.1
1.40±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X322516384MSB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.62370
- 200+0.40215
- 1500+0.34965
- 3000+0.30975
- 国内价格
- 5+0.82178
- 50+0.65708
- 150+0.57478
- 500+0.51311
- 3000+0.45512
- 国内价格
- 100+0.27222
- 500+0.26637
- 国内价格
- 20+0.86720
- 100+0.64850
- 800+0.50290
- 3000+0.36440
- 6000+0.34610
- 30000+0.32070
