D
WIMA MKS 2
Metallized Polyester (PET) Capacitors in PCM 5 mm.
Capacitances from 0.01 mF to 10 mF. Rated Voltages from 50 VDC to 630 VDC.
Special Features
Electrical Data
˜ High volume/capacitance ratio
˜ Self-healing
˜ AEC-Q200 qualified
˜ According to RoHS 2011/65/EU
Typical Applications
For general DC-applications e.g.
˜ By-pass
˜ Blocking
˜ Coupling and decoupling
˜ Timing
Construction
Capacitance range:
0.01 mF to 10 mF (E12-values on request)
Rated voltages:
50 VDC, 63 VDC, 100 VDC, 250 VDC,
400 VDC, 630 VDC
Capacitance tolerances:
±20%, ±10%, ±5%
Operating temperature range:
U r = 50 VDC: –55+ C to +100+ C
U r 63 VDC: –55+ C to +125+ C
Climatic test category:
55/100/21 in accordance with IEC
Insulation resistance at +20+ C:
Test specifications:
In accordance with IEC 60384-2
Test voltage: 1.6 Ur, 2 sec.
Voltage derating:
A voltage derating factor of 1.25 % per K
must be applied from +85+ C for DC
voltages and from +75+ C for AC
voltages
Reliability:
Operational life 300 000 hours (+125° C
permitted for 1000 hours max. distributed
over the entire operating life)
Failure rate 2 fit (0.5 x Ur and 40) C)
U r U test C 0.33 mF 0.33 mF < C T 10 mF
Dielectric:
Polyethylene-terephthalate (PET) film
Capacitor electrodes:
Vacuum-deposited
Internal construction:
50 VDC 10 V 5 x 103 M¸ (mean value: 3 x 104 M¸) 1000 sec (M¸ x mF) (mean value: 3000 sec)
63 VDC 50 V 1 x 104 M¸ (mean value: 5 x 104 M¸) 1250 sec (M¸ x mF) (mean value: 3000 sec)
U100 VDC 100 V 1.5 x 104 M¸ (mean value: 1 x 105 M¸) 3000 sec (M¸ x mF) (mean value: 6000 sec)
Measuring time: 1 min.
Dissipation factors at + 20) C: tan d
Plastic film
Vacuum-deposited
electrode
Metal contact layer
(schoopage)
Terminating wire
Encapsulation:
Solvent-resistant, flame-retardant plastic
case with epoxy resin seal, UL 94 V-0
Terminations:
Tinned wire.
Marking:
Colour: Red. Marking: Silver/White.
Epoxy resin seal: Red
at f
1 kHz
10 kHz
100 kHz
C 0.1 mF 0.1 mF < C T 1.0 mF
10 -3
C > 1.0 mF
10-3
8 x
8 x
10 x 10-3
15 x 10 -3
15 x 10-3 –
30 x 10 -3 –
Maximum pulse rise time: for pulses equal to the rated voltage
Capacitance
mF
50 VDC
Pulse rise time V/msec
max. operation/test
63 VDC 100 VDC 250 VDC 400 VDC 630 VDC
0.01
... 0.022 –
0.033 ... 0.068 –
0.1 ... 0.47 10/100
0.68 ... 1.0 8/80
1.5 ... 3.3 8/80
4.7 5/50
6.8 3/30
10
2.5/25
35/350 35/350 50/500 80/800 110/1100
20/200 25/250 50/500 80/800 90/900
15/150 20/200 50/500 80/800
12/120 15/150 25/250
7.5/75 10/100
5/50
3/30
Mechanical Tests
Available taped and reeled.
Detailed taping information and graphs
at the end of the catalogue.
For further details and graphs please
refer to Technical Information.
04.16
Pull test on pins:
10 N in direction of pins according to
IEC 60068-2-21
Vibration:
6 hours at 10 ... 2000 Hz and 0.75 mm
displacement amplitude or 10 g in
accordance with IEC 60068-2-6
Low air density:
1kPa = 10 mbar in accordance with
IEC 60068-2-13
Bump test:
4000 bumps at 390 m/sec2 in
accordance with IEC 60068-2-29
Packing
44
D
WIMA
WIMA MKS
FKP 42
Continuation
General Data
Capacitance
W
H
50 VDC/30 VAC*
PCM**
Part number
L
W
H
L
63 VDC/40 VAC*
PCM**
Part number
0.01 mF
0.015 „
0.022 „
0.033 „
0.047 „
0.068 „
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
5
5
5
5
5
5
MKS2C021001A00_ _ _ _
MKS2C021501A00_ _ _ _
MKS2C022201A00_ _ _ _
MKS2C023301A00_ _ _ _
MKS2C024701A00_ _ _ _
MKS2C026801A00_ _ _ _
0.1 mF
0.15 „
0.22 „
0.33 „
2.5 6.5 7.2
5
MKS2B033301A00_ _ _ _
0.47 „
3 7.5 7.2
5
MKS2B034701B00_ _ _ _
0.68 „
3.5 8.5 7.2
5
MKS2B036801C00_ _ _ _
2.5
6.5 7.2
2.5 6.5 7.2
3 7.5 7.2
3.5
8.5 7.2
3.5
8.5 7.2
4.5
9.5 7.2
5
5
5
5
5
5
MKS2C031001A00_ _ _ _
MKS2C031501A00_ _ _ _
MKS2C032201B00_ _ _ _
MKS2C033301C00_ _ _ _
MKS2C034701C00_ _ _ _
MKS2C036801E00_ _ _ _
1.0
1.5
2.2
3.3
4.7
6.8
5 10 7.2
5.5 11.5 7.2
7.2 13 7.2
7.2 13 7.2
8.5 14 7.2
11 16 7.2
5
5
5
5
5
5
MKS2C041001F00_ _ _ _
MKS2C041501H00_ _ _ _
MKS2C042201K00_ _ _ _
MKS2C043301K00_ _ _ _
MKS2C044701M00_ _ _ _
MKS2C046801N00_ _ _ _
mF
3.5 8.5
4.5 9.5
5 10
5.5 11.5
7.2 13
8.5 14
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2B041001C00_ _ _ _
MKS2B041501E00_ _ _ _
MKS2B042201F00_ _ _ _
MKS2B043301H00_ _ _ _
MKS2B044701K00_ _ _ _
MKS2B046801M00_ _ _ _
10 mF
11
16
7.2
5
MKS2B051001N00_ _ _ _
Capacitance
W
H
L
0.01
0.015
0.022
0.033
0.047
0.068
mF
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2D021001A00_ _ _ _
MKS2D021501A00_ _ _ _
MKS2D022201A00_ _ _ _
MKS2D023301A00_ _ _ _
MKS2D024701A00_ _ _ _
MKS2D026801A00_ _ _ _
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
3.5
8.5 7.2
3.5
8.5 7.2
3.5
8.5 7.2
5
5
5
5
5
5
MKS2F021001A00_ _ _ _
MKS2F021501A00_ _ _ _
MKS2F022201A00_ _ _ _
MKS2F023301C00_ _ _ _
MKS2F024701C00_ _ _ _
MKS2F026801C00_ _ _ _
0.1 mF
0.15 „
0.22 „
0.33 „
0.47 „
0.68 „
2.5 6.5
3.5 8.5
3.5 8.5
4.5 9.5
4.5 9.5
5 10
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2D031001A00_ _ _ _
MKS2D031501C00_ _ _ _
MKS2D032201C00_ _ _ _
MKS2D033301E00_ _ _ _
MKS2D034701E00_ _ _ _
MKS2D036801F00_ _ _ _
4.5
9.5 7.2
5 10 7.2
5.5 11.5 7.2
7.2 13 7.2
8.5 14 7.2
11 16 7.2
5
5
5
5
5
5
MKS2F031001E00_ _ _ _
MKS2F031501F00_ _ _ _
MKS2F032201H00_ _ _ _
MKS2F033301K00_ _ _ _
MKS2F034701M00_ _ _ _
MKS2F036801N00_ _ _ _
1.0 mF
1.5 „
2.2 „
7.2 13
8.5 14
11 16
7.2
7.2
7.2
5
5
5
MKS2D041001K00_ _ _ _
MKS2D041501M00_ _ _ _
MKS2D042201N00_ _ _ _
100 VDC/63 VAC*
PCM**
Part number
W
H
250 VDC/160 VAC*
L PCM**
Part number
* AC voltage: f = 50 Hz; 1.4 x U rms + UDC U r
** PCM = Printed circuit module = pin spacing.
W
L
Dims. in mm.
H
6 -2
d = 0.5 P
d
5
PCM
at the pin exit points
(± 0.5)
Part number completion:
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
Pin length: 6-2 = SD
Taped version see page 145.
Rights reserved to amend design data without prior notification.
04.16
Continuation page 46
45
D
WIMA MKS 2
Continuation
General Data
Capacitance
W
0.01
0.015
0.022
0.033
0.047
0.068
mF
2.5 6.5
2.5 6.5
3.5 8.5
4.5 9.5
4.5 9.5
5.5 11.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2G021001A00_ _ _ _
MKS2G021501A00_ _ _ _
MKS2G022201C00_ _ _ _
MKS2G023301E00_ _ _ _
MKS2G024701E00_ _ _ _
MKS2G026801H00_ _ _ _
0.1 mF
0.15 „
0.22 „
7.2 13
8.5 14
11 16
7.2
7.2
7.2
5
5
5
MKS2G031001K00_ _ _ _
MKS2G031501M00_ _ _ _
MKS2G032201N00_ _ _ _
H
400 VDC/200 VAC*
L PCM**
Part number
W
H
L
630 VDC/220 VAC*
PCM**
Part number
5.5 11.5 7.2
7.2 13 7.2
7.2 13 7.2
7.2 13 7.2
8.5 14 7.2
5
5
5
5
5
MKS2J021001H00_ _ _ _
MKS2J021501K00_ _ _ _
MKS2J022201K00_ _ _ _
MKS2J023301K00_ _ _ _
MKS2J024701M00_ _ _ _
Dims. in mm.
The values of the WIMA MKM 2 range
according to the main catalogue 2009
are still available on request.
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
Impedance change with frequency
(general guide).
04.16
Permissible AC voltage in relation to
frequency at 10) C internal temperature rise (general guide).
46
D
Recommendation for Processing
and Application of
Through-Hole Capacitors
Soldering Process
Internal temperature of the capacitor must
be kept as follows:
Polyester:
preheating: T max. T 125° C
soldering: T max. T 135° C
Polypropylene: preheating: Tmax. T 100° C
soldering: T max. T 110° C
Single wave soldering
Soldering bath temperature: T P 260 ° C
Dwell time:
t P 5 sec
Double wave soldering
Dwell time:
St P 5 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
WIMA Quality and Environmental Philosophy
ISO 9001:2008 Certification
ISO 9001:2008 is an international basic
standard of quality assurance systems
for all branches of industry. The approval
according to ISO 9001:2008 of our factories by the infaz (Institut für Auditierung und
Zertifizierung) certifies that organisation,
equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards.
WIMA WPCS
The WIMA Process Control System (WPCS)
is a quality surveillance and optimization
system developed by WIMA. WPCS is a
major part of the quality-oriented WIMA
production. Points of application during
production process:
All WIMA capacitors, irrespective of
whether through-hole devices or SMD,
are made of environmentally friendly
materials. Neither during manufacture
nor in the product itself any toxic substances are used, e.g.
Lead
PCB
CFC
Hydrocarbon chloride
Chromium 6+
PBB/PBDE
Arsenic
Cadmium
Mercury
etc.
We merely use pure, recyclable materials
for packing our components, such as:
” carton
” cardboard
” adhesive tape made of paper
” polystyrene
We almost completely refrain from using
packing materials such as:
” foamed polystyrene (Styropor®)
” adhesive tapes made of plastic
” metal clips
RoHS Compliance
According to the RoHS Directive 2011/65/EU
certain hazardous substances like e.g. lead,
cadmium, mercury must not be used any
longer in electronic equipment as of July 1st,
2006. For the sake of the environment WIMA
has refraind from using such substances since
years already.
WIMA Kondensatoren sind bleifrei
konform RoHS 2011/65/EU
WIMA capacitors are lead free
in accordance with RoHS 2011/65/EU
Tape for lead-free WIMA capacitors
DIN EN ISO 14001:2004
WIMA’s environmental management has
been established in accordance with the
guidelines of DIN EN ISO 14001:2004 to
optimize the production processes with
regard to energy and resources.
04.16
” incoming material inspection
” metallization
” film inspection
” schoopage
” pre-healing
” pin attachment
” cast resin preparation/
encapsulation
” 100% final inspection
” Testing as per customer requirements
WIMA Environmental Policy
15
D
Typical Dimensions for
Taping Configuration
Vh
P
P2
Diagram 1:
PCM 2.5/5/7.5mm
W
W1
W0
H
H1
W2
P1
D0
d
P
t
F
P0
H1
P
P1
H
P1
d
d
F
P0
P2
Diagram 2: PCM 10/15 mm
Diagram 3: PCM 22.5 and 27.5*mm
*PCM 27.5 taping possible with two feed holes between components
Designation
Carrier tape width
Dimensions for Radial Taping
Symbol PCM 2.5 taping
W
P0
P2
F
PCM 5 taping
PCM 7.5 taping
PCM 10 taping*
PCM 15 taping*
PCM 22.5 taping
PCM 27.5 taping
18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
Hold-down tape width
W0 6.0
6.0
12.0
12.0
12.0
12.0
12.0
adhesive
tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape
Hole position
W1 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5
Hold-down tape position
W 2
Feed hole diameter
D0 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2
P
12.7 p1.0 12.7 p1.0 12.7 p1.0 25.4 p1.0 25.4 p1.0 38.1 p1.5 3*8.1 p1.5 or 50.8 p1.5
0.5 to 3.0 max.
Pitch of component
Feed hole pitch
P0 12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
Feed hole centre
to pin
P1 5.1 p0.5 3.85 p0.7 2.6 p0.7 7.7 p0.7 5.2 p0.7 7.8 p0.7 5.3 p0.7
Hole centre to
component centre
P2 6.35 p1.3 6.35 p1.3 6.35 p1.3 12.7 p1.3 12.7 p1.3 19.05 p1.3 19.05 p1.3
Feed hole centre to bottom
H
edge of the component
cumulative pitch
error max.
1.0 mm/20 pitch
16.5 p0.3 16.5 p0.3 16.5 p0.5 16.5 p0.5 16.5 p0.5 16.5 p0.5 16.5 p0.5
18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5
Feed hole centre to top
H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1
H
edge of the component 1
32.25 max.
32.25 max.
24.5 to 31.5
25.0 to 31.5
26.0 to 37.0
30.0 to 43.0
35.0 to 45.0
Pin spacing at
+0.8
F 2.5 p0.5 5.0 7.5 p0.8 10.0 p0.8 15 p0.8 22.5 p0.8 27.5 p0.8
upper edge of carrier tape –0.2
Pin diameter
d
0.4 p0.05 0.5 p0.05
Component alignment
Dh
p 2.0 max.
Total tape thickness
t
p 2.0 max.
+0.06 +0,06
+0,08 +0,08 +0.08
0.5 p0.05 or 0.6 –0.05 „ 0.5 p0.05 or 0.6 –0.05 0.8 –0.05 0.8 –0.05 0.8 –0.05
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2
ROLL/AMMO
Package
(see also page 146)
52 p2 depending on
P 360 max.
B p2 comp. dimensions
REEL P 30 p1 58
Unit
AMMO
52 p2 54 p2
500 max.
B 60 p2
REEL P 360 max. B 58 p2 or REEL PP 25
p1
P 30 p1 66 p2
68 p2
depending
on PCM and
component dimensions
see details page 147.
Dims in mm.
04.16
„ Diameter of pins see General Data.
Please clarify customer-specific deviations with the manufacturer.
* PCM 10 and PCM 15 can be crimped to PCM 7.5.
Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible
145
D
Types of Tape Packaging of
Capacitors for Automatic
Radial Insertion
˜ REEL Packaging
340 max.
30±1
25±1
360 max.
500 max.
˜ AMMO Packaging
340 max.
370 max.
˜ ROLL Packaging
34
0m
ax.
50 max.
50 max.
70 max.
ax
0 m ax.
34 0 m
49
B
BAR CODE (Labelling)
Labelling of package units in
plain text and with
alphanumerical Bar Code
BARCODE „Code 39”
Scanner decoding of
„ WIMA supplier number
„ Customer‘s P/O number
„ Customer‘s part number
„ WIMA confirmation number
„ WIMA part number
„ Lot number
„ Date code
„ Quantity
In addition part description of
article
capacitance value
rated voltage
dimensions
capacitance tolerance
packing
04.16
as well as gross weight and customer‘s
name are indicated in plain text.
146
D
Packing Quantities for Capacitors with
Radial Pins in PCM 2.5 mm to 22.5 mm
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
2.5
3
4
4.5
5
5.7
7.2
3
4
4
4
5
5
6
6
8
5
5
6
6
7
7
8
8
9
9
10
11
5
6
7
8
8.5
10
10.5
10.5
11
12
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
7
8.5
9
9.5
10.5
12.5
12.5
9
8.5
9
9.5
10
11
12
12.5
12
11
13
12.5
14
14
15
15
17
14
16
18
14
14
15
16.5
22
19
20.5
21
24
bulk
L
4.6
4.6
4.6
4.6
4.6
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
10
10
10
10.3
10.3
10.3
10.3
13
13.5
13
13
13.5
13
13
13
13
18
19
18
19
18
19
18
19
18
18
19
18
26.5
26.5
26.5
28
26.5
28
26.5
26.5
26.5
28
Codes
0B
0C
0D
0E
0F
1A
1B
1C
1D
1E
1F
1G
1H
1I
1J
1K
1L
1M
1N
2A
2B
2C
2D
2E
2F
2G
3A
FA
3C
3D
FB
3F
3G
3H
3I
4B
FC
4C
FD
4D
FE
4F
FF
4H
4J
FG
4M
5A
5B
5D
FH
5F
FI
5G
5H
5I
FJ
S
5000
5000
5000
5000
5000
5000
5000
5000
6000
4000
3500
4000
2500
2500
2500
2000
2000
1500
1000
5000
5000
4000
3500
3000
2000
1500
3000
3000
3000
3000
2000
3000
2400
2400
2000
2400
1000
2000
1000
1600
1000
1200
500
1200
900
500
1000
1200
1000
760
500
500
570*
594*
594*
561*
480*
Moulded versions.
04.16
* TPS (Tray-Packing-System). Plate versions may have different packing units.
Samples and pre-production needs on request.
pcs. per packing unit
REEL
AMMO
P 360
P 500
340 x 340
490 x 370
H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5
N
O
F
I
H
J
A
C
B
D
2200
2500
2800
2000
2300
2300
1500
1800
1800
1200
1500
1500
900
1200
1200
2200
2500
2800
2000
2300
2300
1600
2000
2000
1300
1500
1500
1300
1500
1500
1100
1400
1400
1000
1200
1200
1000
1200
1200
800
1000
1000
700
1000
1000
700
950
1000
600
800
800
600
800
800
500
600
400
2500
4400
2500
2200
4300
2300
4150
1700
3200
1700
3100
1500
2900
1400
2700
1300
2500
1300
1000
2200
1100
900
1800
1000
1100
2200
1900
900
1600
1450
900
1600
1450
900
1600
1400
700
1300
1200
700
1300
1200
550
1100
1000
550
1100
1000
400
800
740
600
1200
1150
600
1200
1200
500
1000
1000
500
1000
1000
450
900
850
450
900
850
400
800
740
400
800
740
350
700
650
350
700
650
300
650
590
300
600
540
800
770
700
640
600
550
500
480
480
450
420
380
400
360
400
360
380
350
350
310
ROLL
147
D
Radial Pins in PCM 27.5 mm to 52.5 mm
Size
PCM
REEL
AMMO
P 360
P 500
340 x 340
490 x 370
N
O
F
I
H
J
A
C
B
D
460/340*
420
380/280*
350
300
290
270
250
ROLL
bulk
W
9
11
13
13
15
15
17
17
H
19
21
24
25
26
26
29
34.5
32
39.5
L
31.5
31.5
31.5
33
31.5
33
31.5
31.5
33
31.5
Codes
6A
6B
6D
FK
6F
FL
6G
6I
FM
6J
S
567*
459*
378*
405*
324*
324*
198*
198*
162*
162*
37.5 mm
9
11
13
15
17
19
31
35
40
19
22
24
26
29
32
39.5
45.5
46
50
55
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
7A
7B
7C
7D
7E
7F
7G
7H
7I
7J
7K
441*
357*
294*
252*
154*
140*
126*
112*
84*
35*
28*
48.5 mm
19
23
27
33
37
31
34
37.5
48
54
56
56
56
56
56
8D
8E
8H
8J
8L
120*
80*
84*
25*
25*
45
45
50
55
65
57
57
57
57
57
9D
9E
9F
9H
9J
70*
60*
25*
20*
20*
52.5 mm
25
30
35
45
45
27.5 mm
* for 2-inch transport pitches.
Moulded versions.
04.16
Updated data on www.wima.com
148
D
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Version code (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Pin length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
04.16
Type description:
SMD-PET
= SMDT
SMD-PEN
= SMDN
SMD-PPS
= SMDI
FKP 02
= FKP0
MKS 02
= MKS0
FKS 2
= FKS2
FKP 2
= FKP2
FKS 3
= FKS3
FKP 3
= FKP 3
MKS 2
= MKS2
MKP 2
= MKP2
MKS 4
= MKS4
MKP 4C
= MKPC
MKP 4
= MKP4
MKP 10
= MKP1
FKP 1
= FKP1
MKP-X2
= MKX2
MKP-X1 R
= MKX1
MKP-Y2
= MKY2
MP 3-X2
= MPX2
MP 3-X1
= MPX1
MP 3-Y2
= MPY2
MP 3R-Y2
= MPRY
MKP 4F
= MKPF
Snubber MKP = SNMP
Snubber FKP
= SNFP
GTO MKP
= GTOM
DC-LINK MKP 3 = DCP3
DC-LINK MKP 4 = DCP4
DC-LINK MKP 4S = DCPS
DC-LINK MKP 5 = DCP5
DC-LINK MKP 6 = DCP6
DC-LINK HC
= DCHC
DC-LINK HY
= DCHY
63 VDC
Rated voltage:
50 VDC = B0
63 VDC = C0
100 VDC = D0
250 VDC = F0
400 VDC = G0
450 VDC = H0
520 VDC = H2
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
250 VAC = 0W
275 VAC = 1W
300 VAC = 2W
305 VAC = AW
350 VAC = BW
440 VAC = 4W
500 VAC = 5W
0.01 mF
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 mF = 2100
0.022 mF = 2220
0.047 mF = 2470
0.1 mF = 3100
0.22 mF = 3220
0.47 mF = 3470
= 4100
1 mF
2.2 mF = 4220
4.7 mF = 4470
= 5100
10 mF
= 5220
22 mF
= 5470
47 mF
100 mF = 6100
220 mF = 6220
1000 mF = 7100
1500 mF = 7150
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812 = KA
4.8 x 3.3 x 4 Size 1812 = KB
5.7 x 5.1 x 3.5 Size 2220 = QA
5.7 x 5.1 x 4.5 Size 2220 = QB
7.2 x 6.1 x 3 Size 2824 = TA
7.2 x 6.1 x 5 Size 2824 = TB
10.2 x 7.6 x 5 Size 4030 = VA
12.7 x 10.2 x 6 Size 5040 = XA
15.3 x 13.7 x 7 Size 6054 = YA
2.5 x 7 x 4.6 PCM 2.5 = 0B
3 x 7.5 x 4.6 PCM 2.5 = 0C
2.5 x 6.5 x 7.2 PCM 5 = 1A
3 x 7.5 x 7.2 PCM 5
= 1B
2.5 x 7 x 10 PCM 7.5
= 2A
3 x 8.5 x 10 PCM 7.5
= 2B
3 x 9 x 13 PCM 10
= 3A
4 x 9 x 13 PCM 10
= 3C
5 x 11 x 18 PCM 15
= 4B
6 x 12.5 x 18 PCM 15 = 4C
5 x 14 x 26.5 PCM 22.5 = 5A
6 x 15 x 26.5 PCM 22.5 = 5B
9 x 19 x 31.5 PCM 27.5 = 6A
11 x21 x 31.5 PCM 27.5 = 6B
9 x 19 x 41.5 PCM 37.5 = 7A
11 x 22 x 41.5 PCM 37.5 = 7B
19 x 31 x 56 PCM 48.5 = 8D
25 x 45 x 57 PCM 52.5 = 9D
Version code:
Standard
Version A1
Version A1.1.1 =
Version A2
00
1A
1B
2A
Tolerance:
±20 % =
±10 % =
±5 %
±2.5 % =
±1 %
6 -2
M
K
J
H
E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk/TPS Standard
=A
=B
=C
=D
=F
=H
=I
=J
=N
=O
=P
=Q
=R
=T
=S
3.5 ±0.5 = C9
6 -2
= SD
16 ±1
= P1
Pin length (taped)
none
= 00
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the
pages of the respective WIMA range.
143
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
WIMA:
MKS2-1/50/10 MKS2-.15/63/5 MKS2-1/63/10T MKS2-.047/63/5T MKS2-.022/63/5T MKS2-.22/63/5T MKS2.01/63/5T MKS2-.47/63/5T MKS2-.1/63/5T MKS2-1/63/5T MKS2-.22/63/10 MKS20-.033/63/10 MKS20-.068/63/10
MKS2G021001A00MSSD MKS2B051001N00MSSD MKS2B034701B00KI00 MKS2B043301H00JF00
MKS2D023301A00MSSD MKS2D024701A00JSSD MKS2C031001A00KSSD MKS2C041001F00JSSD
MKS2C022201A00JSSD MKS2D022201A00KSSD MKS2C032201B00JSSD MKS2-.1/63/5 MKS2C043301K00JSSD
MKS2C021001A00JSSD MKS2D023301A00JSSD MKS2C026801A00JSSD MKS2C034701E00JSSD
MKS2D031001A00KSSD MKS2C042201K00JSSD MKS2C044701M00JSSD MKS2C021501A00JSSD
MKS2C036801E00JSSD MKS2C033301C00JSSD MKS2B044701K00KSSD MKS2D041001K00KSSD
MKS2C023301A00JSSD MKS2D041001K00JSSD MKS2C024701A00KSSD MKS2F031001E00JSSD
MKS2C041501H00JSSD MKS2C024701A00JSSD MKS2C031501A00KSSD MKS2C021001A00KSSD
MKS2C033301C00KSSD MKS2C034701C00KSSD MKS2F033301K00MSSD MKS2D021001A00KSSD
MKS2C022201A00KSSD MKS2D034701E00KSSD MKS2D032201C00KSSD MKS2B042201F00KSSD
MKS2D021001A00JSSD MKS2B043301H00KSSD MKS2C036801E00KSSD MKS2B041501E00KSSD
MKS2C026801A00KSSD MKS2B036801C00KSSD MKS2C023301A00KSSD MKS2C021501A00KSSD
MKS2J023301K00KSSD MKS2D024701A00KSSD MKS2D026801A00KSSD MKS2D031501C00KSSD
MKS2J021001H00KSSD MKS2D023301A00KSSD MKS2J021501K00KSSD MKS2D033301E00KSSD
MKS2J024701M00KSSD MKS2J022201K00KSSD MKS2B042201F00JSSD MKSD033301E00MSSD MKS2-.33/63/5
REEL MKS2-0.22/63/10 MKS2-0.015/63/10 MKS2G021001A00JSSD MKS2C041001F00KSSD
MKS2C021501A00JI00 MKS2C021001A00KC00 MKS2G021001A00MC00 MKS2G031001K00KC00
MKS2G031001K00KSSD MKS2B046801M00KSSD MKS2B051001N00KSSD MKS2C021001A00JC00
MKS2B041001C00KF00 MKS2B042201F00KC00 MKS2B043301H00JSSD MKS2B043301H00KC00
MKS2B044701K00JC00 MKS2B044701K00KC00 MKS2B044701K00MC00 MKS2C022201A00JC00
MKS2C022201A00KC00 MKS2C023301A00JC00 MKS2C023301A00KC00 MKS2C024701A00JC00
MKS2C024701A00KC00
很抱歉,暂时无法提供与“MKS2C041001F00KSSD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.16280
- 10+10.00080
- 30+9.89280
