SHENZHEN HUAYUAN MICRO ELECTRONIC TECHNOLOGY CO. , LTD .
Shenzhen Office:
TEL: 0755-29881155
FAX:0755-29881157
EMAIL:zxsf_sales@163.com
QQ:2109300457
www.szhywd.com
APPROVAL SHEET
Approval Specification
Customer’s Approval Certificate
Please return this copy as a certification of
your approval
TO:
Part No.:
Checked & Approved by:
Customer’s Part No.:
Date:
BEIJING ZHONGXUN SIFANG SCIENCE &
TECHNOLOGY CO.,LTD.
Tel:
+86-010-58937383
Fax:
+86-010-58937263
E-mail: zxsf_sales@163.com
QQ:
2109300457
Website: http://www.bjzxsf.net
Add:
No 201, Block A. Building 3. Yongjie Beilu
Yongfeng high-tech industrial base
Haidian District Beijing city
Part No.
SFR315A
Pages
6
Date
2013/3/21
Revision
1.0
Prepared by:
Checked by:
Approved by:
SAW Resonator
SFR315A
315.00MHz
Features
1-port Resonator
Ceramic Package for Surface Mounted Technology (SMT)
RoHS compatible
Package size 5.00x5.00x1.50mm3
Package Code QCC8C
Electrostatic Sensitive Device(ESD)
Application
Typical Low-Power Transmitter Application
Typical Local Oscillator Application
Package Dimensions (QCC8C)
Please read notes at the end of this document.
Pin Configuration
-2-
2
Input
6
Output
1,3,4,5,7,8
Ground
www.bjzxsf.net
2013/3/21
SAW Resonator
SFR315A
315.00MHz
Marking
SF
SF
Trademark
R315A
R
SAW Resonator
315A
Part number
Test Circuit
Equivalent LC Model
Temperature Characteristics
The curve shown above accounts for resonator contribution only and does not include LC component
temperature contributions.
-3-
www.bjzxsf.net
2013/3/21
SAW Resonator
SFR315A
315.00MHz
Performance
Maximum Rating
Item
Value
Unit
V DC
±30
V
T
-40 ~ +85
Storage Temperature
T stg
-55 ~ +125
RF Power Dissipation
P
10
dBm
DC Voltage
Operation Temperature
Electronic Characteristics
Test Temperature:
25℃±2℃
Terminating source impedance: 50Ω
Terminating load impedance: 50Ω
Item
Center
Frequency
Temperature
Stability
Frequency
Aging
Maximum
Unit
315.00
MHz
△fc
±75
KHz
IL
1.1
Unloaded Q
QU
17824
50Ω Loaded Q
QL
1925
Turnover Temperature
T0
Turnover Frequency
f0
fc
Frequency Temperature Coefficient
FTC
0.032
ppm/℃
Absolute Value during the First Year
|fA|
≤10
ppm/yr
Tolerance from 315.00MHz
DC Insulation Resistance between Any Two Pins
RF
Equivalent
RLC
Model
Typical
fc
Absolute Frequency
Insertion Loss(min)
Quality Factor
Minimum
25
40
1.6
dB
55
1.0
MΩ
Motional Resistance
RM
13.0
Motional Inductance
LM
109.1
µH
Motional Capacitance
CM
2.34
fF
Static Capacitance
C0
-4-
2.9
3.2
www.bjzxsf.net
20.0
3.5
Ω
pF
2013/3/21
SAW Resonator
SFR315A
315.00MHz
Frequency Response
Reliability(The SAW components shall remain electrical performance after tests)
No.
Test item
1
Temperature
Storage
2
Humidity Test
Test condition
(1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h
(2) Temperature: –55℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h
Conditions: 60℃±2℃ , 90~95% RH
Duration: 250h
Heat cycle conditions: TA=-40℃±3℃, TB=85℃±2℃, t1=t2=30min, Switch
3
Thermal Shock
Frequency of vibration: 10~55Hz
Amplitude:1.5mm
4
Vibration Fatigue
Directions: X,Y and Z
Duration: 2h
5
Drop Test
Cycle time: 10 times
Height: 1.0m
Temperature: 245℃±5℃
Duration: 3.0s--5.0s
6
Solder Ability Test
time: ≤3min , Cycle time: 100 times , Recovery time : 2h±0.5h.
Depth: DIP--2/3 , SMD--1/5
(1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s
7
Resistance to
Soldering Heat
(2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s ,
Recovery time : 2 ± 0.5h
-5-
www.bjzxsf.net
2013/3/21
SAW Resonator
SFR315A
315.00MHz
Recommended Reflow Soldering Diagram
Notes
1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by
electrostatic, so we should pay attention to ESD protect in the test.
2. Static voltage between signal load and ground may cause deterioration and destruction of the
component. Please avoid static voltage.
3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic
cleaning.
4. Only leads of component may be soldered. Please avoid soldering another part of component.
5. There is a close relationship between the device's performance and matching network. The
specifications of this device are based on the test circuit shown above. L and C values may change
depending on board layout. Values shown are intended as a guide only.
-6-
www.bjzxsf.net
2013/3/21
很抱歉,暂时无法提供与“SFR315A”相匹配的价格&库存,您可以联系我们找货
