CPY160808T-2R2T-NP
CPY160808T-2R2T-NP
    CHILISIN(奇力新)
    固定电感器
CPY160808T-2R2T-NP 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL Customer: : Customer P/N: Drawing No: : Quantity: : 0 Pcs. Date : CPY160808T-SERIES-NP Chilisin P/N: : SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 Chilisin Electronic sCorp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com.tw http //www.chilisin.com.tw : : : : 奇力新電子( 奇力新電子(河南) 河南)有限公司 Chilisin Electronics (Henan) Co., Ltd. XiuWu Xian, industry gathering area JiaoZuo, Henan China Postal Code:454350 TEL:+86-391-717-0682 FAX:+86-391-717-0666 Drawn by 張瑞滿 rammi 東莞奇力新電子有限公司 Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL +86-769-8773-0251~3 FAX +86-769-8773-0232 E-mail cect@chilisin.com.tw : : : 奇力新電子( 奇力新電子(蘇州) 蘇州)有限公司 Chilisin Electronics (Suzhou) Co., Ltd. No.143,Song Shan Rd., Suzhou New District, Suzhou,China Postal Code:215129 TEL:+86-512-6841-2350 FAX:+86-512-6841-2356 E-mail suzhou@chilisin.com.tw Checked by 邱明傑 Joseph.Chiu Approved by JACKY jacky.chung 鍾 CPY160808T Series Specification 1 Scope: This specification applies to Multilayer Ferrite chip inductors 2 Part Numbering: 3 Rating: Operating Temperature: -40℃~105℃(Including self - temperature rise) Storage Temperature: -40℃~85℃(after PCB) -5℃~40℃,Humidity 40%~70%(before PCB) 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35 ) Ordinary Humidity(25 to 85% RH) ℃ In case of doubt 20±2 60 to 70 % RH ℃ CPY160808T Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Inductance (uH) Test Freq. RDC (Ω)Max. Rated Current (mA)Max. Tolerance (±%) CPY160808T-1R0□-NP 1 1 MHz,200 mV 0.12 1500 20,30 CPY160808T-2R2□-NP 2.2 1 MHz,200 mV 0.2 1000 20,30 CPY160808T-4R7□-NP 4.7 1 MHz,200 mV 0.25 800 20,30 CPY160808T-100□-NP 10 1 MHz,200 mV 0.9 90 20,30 Part No. NOTE: □-tolerance M=±20% / T=±30% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) ℃ 2.Rate Current : Applied the current to coils, the temperature rise shall not be more than 30 "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) CPY160808T Series Specification 8 CPY160808T Series 8.1 Construction: 8.2 Material List: CPY160808T Series Specification 9 Reliability Of Ferrite Multilayer Chip Inductor 1-1.Mechanical Performance No Item 1-1-1 Flexure Strength Test Method Specification The forces applied on the right Test device shall be soldered on the substrate conditions must not damage Substrate Dimension: 100x40x1.6mm the terminal electrode and the Deflection: 2.0mm ferrite Keeping Time: 30sec *For 100505, substrate dimension is 100x40x0.8mm 1-1-2 Vibration Test device shall be soldered on the substrate Oscillation Frequency: 10 to 55 to 10Hz for 1min Amplitude: 1.5mm Time: 2hrs for each axis (X, Y & Z), total 6hrs 1-1-3 Resistance to Soldering Heat Appearance: No damage Pre-heating: 150 , 1min More than 75% of the terminal.Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) electrode should be covered Solder Temperature: 260±5 with solder. Immersion Time: 10±1sec Inductance: within ±20% of initial value ℃ ℃ 1-1-4 Solder ability The electrodes shall be at least 95% covered with new solder coating 1-2.Environmental Performance No Item 1-2-1 Temperature Cycle 1-2-2 Humidity Resistance 1-2-3 High Temperature Resistance 1-2-4 Low Temperature Resistance Specification Appearance: No damage Inductance:within±20% of initial value ℃ Pre-heating: 150 , 1min Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) Solder Temperature: 245±5 (Pb-Free) Immersion Time: 4±1sec ℃ Test Method One cycle: Time (min) Step Temperature ( ) 1 -40±3 30 2 25±2 3 3 105±3 30 4 25±2 3 Total: 100cycles Measured after exposure in the room condition for 24hrs Temperature: 40±2 Relative Humidity: 90 ~ 95% / Time: 1000hrs Measured after exposure in the room condition for 24hrs Temperature: 85±3 Relative Humidity: 20% Applied Current: Rated Current / Time: 1000hrs Measured after exposure in the room condition for 24hrs Temperature: -40±3 Relative Humidity: 0% / Time: 1000hrs Measured after exposure in the room condition for 24hrs ℃ ℃ ℃ ℃ CPY160808T Series Specification CPY160808T Series Specification 11 Packaging: 11.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. 11.2 Packaging Quantity 11.3 Reel Dimensions CPY160808T Series Specification 11 Packaging: 11.4 Tape Dimensions in mm 12 Recommended Land Pattern: 13 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
CPY160808T-2R2T-NP 价格&库存
很抱歉,暂时无法提供与“CPY160808T-2R2T-NP”相匹配的价格&库存,您可以联系我们找货
CPY160808T-2R2T-NP
    • 20+0.16902
    • 200+0.13522
    • 600+0.11643
    库存:19
    CPY160808T-2R2T-NP
