OCV561M0ETR-0807
OCV561M0ETR-0807
    LELON(立隆电子)
    SMD,D8xL6.7mm
    贴片铝电解电容 SMD
OCV561M0ETR-0807 数据手册
OCV Organic Conductive Polymer Capacitors OCV Series Features ‧105℃, 2,000 hours assured ‧Ultra low ESR, solid capacitors of SMD type ‧RoHS Compliance Marking color: Blue Specifications Items Category Temperature Range Capacitance Tolerance Performance -55℃ ~ +105℃ ±20% Leakage Current (at 20℃)* Test Time 2,000 Hrs Capacitance Change Within ±20% of initial value Tanδ Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 105℃. Endurance Test Time 1,000 Hrs Capacitance Change Within ±20% of initial value Tanδ Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them at 60℃, 90 to 95% RH for 1,000 hours. Leakage current should be tested after voltage treatment*. Moisture Resistance Capacitance Change Tanδ ESR Leakage Current Resistance to Soldering Heat * (Please refer to page 25 for reflowsoldering conditions) Frequency (Hz) Multiplier Ripple Current and Frequency Multipliers Within ±10% of initial value Within specified value Within specified value Within specified value 120 ≦ f < 1k 1k ≦ f < 10k 10k ≦ f < 100k 100k≦ f < 500k 0.05 0.3 0.7 1.0 * For any doubt about measured values, measure the leakage current again after the following voltage treatment. Voltage treatment: DC rated voltage is applied to the capacitors for 2 hours at 105 ℃. Diagram of Dimensions Lead Spacing and Diameter B±0.2 φD±0.5 B C W P ± 0.2 5.7 ± 0.3 5.3 5.3 5.9 0.5 ~ 0.8 1.5 6.3 5.9 +0.1/-0.3 6.6 6.6 7.2 0.5 ~ 0.8 2.0 6.3 7.0 ± 0.2 6.6 6.6 7.2 0.5 ~ 0.8 2.0 8 6.7 ± 0.3 8.3 8.3 9.0 0.7 ~ 1.1 3.1 8 12.0 ± 0.5 8.3 8.3 9.0 0.7 ~ 1.1 3.1 10 7.7 ± 0.3 10.3 10.3 11.0 0.7 ~ 1.3 4.7 10 9.9 +0.1/-0.3 10.3 10.3 11.0 0.7 ~ 1.3 4.7 10 12.6 +0.1/-0.4 10.3 (*): For 5 ~ 6.3φ is 0.4 max. 10.3 11.0 0.7 ~ 1.3 4.7 5 W A±0.2 0.3 max. P C±0.2 Marking φD = 5 ~ 6.3 Negative polarity 34 34 A2 10 16V L Unit: mm A φD 0.5 max.(*) L OP-CAP Tanδ (at 120Hz, 20℃) ESR (at 100k ~ 300k Hz, 20℃) (at 120Hz, 20℃) Rated voltage applied, after 2 minutes at 20℃. See Standard Ratings See Standard Ratings See Standard Ratings φD = 8 ~ 10 Date code Rated cap. Rated voltage & Series code Negative polarity A2 OCV 470 6.3V Date code Series name Rated cap. Rated voltage All product specifications in the catalog are subject to change without notice. (CAT. 2018E1) All product specifications in the catalog are subject to change without notice. (CAT. 2018E1) Organic Conductive Polymer Capacitors Dimension: φD×L(mm) Ripple Current: mA/rms at 100k Hz, 105℃ Standard Ratings Rated Volt. (V) Surge Voltage (V) Capacitance (μF) 220 2.5V (0E) 2.9 0.12 110 25 2,500 3,100 23 340 12 4,770 1,000 10 × 7.7 0.12 500 19 4,240 1,200 10 × 9.9 0.18 750 13 5,200 1,500 10 × 12.6 0.18 750 10 5,500 5 × 5.7 0.12 120 30 1,490 6.3 × 5.9 0.12 120 26 2,450 8 × 6.7 0.12 176 25 3,020 330 8 × 6.7 0.12 264 25 3,020 470 10 × 7.7 0.12 376 20 4,130 560 8 × 12 0.18 448 12 4,770 680 10 × 7.7 0.12 544 20 4,130 820 10 × 9.9 0.18 656 13 5,200 10 × 12.6 0.18 960 10 5,500 6.3 × 5.9 0.12 103 27 2,400 5 × 5.7 0.12 126 35 1,380 6.3 × 5.9 0.12 126 27 2,400 6.3 × 7 0.12 151 30 2,010 6.3 × 7 0.12 189 30 2,250 0.12 189 25 3,020 7.2 8 × 6.7 0.12 277 30 2,250 8 × 6.7 0.12 277 25 3,020 330 10 × 7.7 0.12 416 20 4,130 470 8 × 12 0.15 592 12 4,770 560 10 × 9.9 0.15 706 16 4,700 820 10 × 12.6 0.15 1,033 10 5,500 47 5 × 5.7 0.12 94 40 1,270 56 6.3 × 5.9 0.10 112 31 2,250 150 8 × 6.7 0.10 300 27 2,800 8 × 12 0.15 660 14 4,420 10 × 7.7 0.10 660 24 3,770 470 10 × 9.9 0.15 940 18 4,400 560 10 × 12.6 0.15 1,120 12 5,300 22 5 × 5.7 0.12 70 45 1,210 47 6.3 × 5.9 0.10 150 50 1,650 82 8 × 6.7 0.10 262 30 2,700 8 × 12 0.15 576 16 4,360 10 × 7.7 0.10 576 26 3,430 220 10 × 9.9 0.15 704 20 4,200 330 10 × 12.6 0.15 792 14 5,050 820 10 × 12.6 0.12 2,624 18 4,200 220 330 180 6.3 × 7 All product specifications in the catalog are subject to change without notice. (CAT. 2018E1) All product specifications in the catalog are subject to change without notice. (CAT. 2018E1) OP-CAP 280 150 18.0 6.3 × 5.9 0.18 120 16V (1C) Rated R. C. (mA/rms at 100k Hz, 105℃) 0.12 100 12.0 ESR (mΩ/at 100k ~ 300k Hz, 20℃ max.) 8 × 6.7 82 10V (1A) LC (μA) 8 × 12 1,200 6.3V (0J) Tanδ (120Hz, 20℃) 560 220 4.6 Size φD×L(mm) 680 150 4V (0G) OCV 35 35 OCV Organic Conductive Polymer Capacitors Dimension: φD×L(mm) Ripple Current: mA/rms at 100k Hz, 105℃ Standard Ratings Rated Volt. (V) Surge Voltage (V) 20V (1D) OP-CAP 25V (1E) 23.0 40.0 50V (1H) 58.0 63V (1J) 73.0 Size φD×L(mm) 470μF OCV 471 Series Name Capacitance LC (μA) ESR (mΩ/at 100k ~ 300k Hz, 20℃ max.) Rated R. C. (mA/rms at 100k Hz, 105℃) 6.3 × 5.9 0.10 88 50 1,650 47 8 × 6.7 0.10 188 45 2,000 82 10 × 7.7 0.10 328 40 2,500 8 × 12 0.15 400 24 3,320 10 × 9.9 0.15 400 25 3,700 150 10 × 12.6 0.15 600 20 4,320 330 10 × 12.6 0.12 1,320 26 2,700 6.8 6.3 × 5.9 0.10 170 80 1,200 10 8 × 6.7 0.10 125 60 1,500 22 10 × 7.7 0.10 275 50 2,000 33 8 × 12 0.12 413 30 2,980 56 10 × 12.6 0.12 700 28 3,800 270 10 × 12.6 0.12 1,350 27 2,700 39 8 × 12 0.12 273 31 2,100 68 10 × 12.6 0.12 476 28 2,700 39 8 × 12 0.12 390 34 2,000 68 10 × 12.6 0.12 680 29 2,600 27 8 × 12 0.12 340 35 2,000 47 10 × 12.6 0.12 592 30 2,500 Part Numbering System OCV Series Tanδ (120Hz, 20℃) 22 100 29.0 35V (1V) Capacitance (μF) ±20% M Capacitance Tolerance 6.3V 0J Rated Voltage Carrier Tape TR Package Type 8φ×12L - Terminal Type 0812 Case size Pb-free and PET coating case Lead Wire and Coating Type Note: For more details, please refer to “Part Numbering System (SMD Type)” on page 15. 36 36 All product specifications in the catalog are subject to change without notice. (CAT. 2018E1) All product specifications in the catalog are subject to change without notice. (CAT. 2018E1)
OCV561M0ETR-0807 价格&库存
很抱歉,暂时无法提供与“OCV561M0ETR-0807”相匹配的价格&库存,您可以联系我们找货
