Metallized Polypropylene Film Interference Suppression Capacitors
金属化聚丙烯膜抑制电磁电源干扰用电容器
(MPX/MKP X2 320VAC--MP2 Series/ MP2 系列)
■ 引用标准 Reference standards
GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14
IEC60384-14 /EN60384-14/KC60384-14/KC60384-1
■ 结构 Structure
介质:(金属化)聚丙烯膜
封装:阻燃环氧树脂,符合 UL94 V-0
外壳:阻燃 PBT 塑壳,符合 UL94 V-0
Dielectric: (Metallized )Polypropylene film
Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0
Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0
典型应用 Typical
Application
跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等
Interlines, Surge suppression, Across-in-line as EMI filter;
Power switch etc. Such as: Lamps, Power Sources etc.
特点 Features
外观一致性好;有良好自愈性
抗湿性强;高耐温
长寿命,耐过电压优良
Good appearance consistency; Good self-healing property;
Good resistance to humidity; Can withstand high temperature;
Long lifetime; Good ability to withstand surge voltage.
符合 RoHS 及 REACH 环保标准 Compliance with RoHs &
电性能规范 Performance Specifications
气候类别 Climate category
阻燃等级
Passive flammability class
额定电压 Rated Voltage
容量误差
Capacitance Tolerance
REACH requirements.
40/110/56
B
320VAC
K: ±10%
容量范围
0.0022μF~4.7μF
Capacitance Range
Test Condition:
耐电压
No breakdown or electric arcing
Withstand Voltage
Terminal to terminal:4.3UR(Vdc),5S
Terminal to shell:2140VAC 60S
损耗角
≤0.0020
10KHZ
CR≤1.0μF
Test Condition :
Dissipation factor
≤0.0010
1KHZ
CR>1.0μF
绝缘电阻或时间常数
CR≤0.33μF IR≥15000MΩ
Insulation Resistance
CR>0.33μF IR≥5000S
最大脉冲爬升速率
Max. Pulse Rise Time
(dV / dt)
20℃, 1KHz, 1Vrms
20℃ 1V
Test Condition : 20℃
P=7.5mm dV / dt = 800V/μs P=10mm
dV / dt = 500V/μs
P=15mm dV / dt = 400V/μs
P=22.5mm dV / dt = 200V/μs
P=27.5mm dV / dt = 150V/μs P=37.5mm dV / dt = 80V/μs
100V
1 min
金属化聚丙烯膜抑制电磁电源干扰用电容器
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change:△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0080(10KHZ),CR≤1uF
Rise ≤0.0050(1KHZ),CR>1uF
绝缘电阻 Insulation Resistance
耐久性试验
温度 Temp.: +110℃,
Endurance Test
施加电压:1.25×额定电压(每小时
IR:≥ 50% of rated value
增加电压到 1000Vac,0.1 秒,1 次) 容量变化(相对初始值):△C/C≤±10%
Test Voltage:
Capacitance change: △C/C≤±10%
1.25 Times Rated Voltage(Rise
the voltage to 1000Vac for .01s
once per hours )
持续时间 Duration Time: 1000H
安规认证 Safety Certification
认证标志
额定电压
证书号码
引用标准
认证国家
Certification
Rated Voltage
Certificate No.
Reference standard
Certification Country
UL/CUL
320VAC
E319615
UL60384-14
CSA E60384-14
美国、加拿大
America / Canada
VDE
320VAC
40028812
EN60384-14
德国 Germany
ENEC
320VAC
40028812
EN60384-14
欧盟 Europe
CQC
320VAC
CQC09001035778
GB/T6346.14-2015
中国 China
KC
320VAC
SU030803(16001-16005)
KC60384-14
韩国 Korea
产品编码说明 Part No. Description:
15 位产品编码如下:
The Part No. Is total 15 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
M
4
R
8
Digit 1-3
P
2
1
K
型号代码 Product Name Code
3
2
E
MP2= Class X2 Capacitors
Digit 4-6
标称容量 Rated Capacitance Value
For example : 105 = 10×105pF = 1.0F
Digit 7
容量偏差 Capacitance Tolerance
K=±10%
Digit 8-9
额定电压 Rated Voltage Code
32=320VAC
Digit 10-11 壳号 Plastic shell code
Digit 12
塑壳颜色 Plastic Shell Color
R = Grey Color with LOGO on the shell top
Digit 13
线径代码 Line diameter code
6=0.6 8=0.8
Digit 14-15 成型或内部识别码 Forming Type or Internal Use
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part
No. List and Dimensions
成品编码
等级
电压
Part No.
Class
MP2222K32B2R6**
容量
尺寸 Dimension (mm)
Voltage
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
X2
320VAC
0.0022
10
5
11
7.5
0.6
MP2272K32B2R6**
X2
320VAC
0.0027
10
5
11
7.5
0.6
MP2332K32B2R6**
X2
320VAC
0.0033
10
5
11
7.5
0.6
MP2392K32B2R6**
X2
320VAC
0.0039
10
5
11
7.5
0.6
MP2472K32B2R6**
X2
320VAC
0.0047
10
5
11
7.5
0.6
MP2562K32B2R6**
X2
320VAC
0.0056
10
5
11
7.5
0.6
MP2682K32B2R6**
X2
320VAC
0.0068
10
5
11
7.5
0.6
MP2822K32B2R6**
X2
320VAC
0.0082
10
5
11
7.5
0.6
MP2103K32B2R6**
X2
320VAC
0.01
10
5
11
7.5
0.6
MP2123K32B2R6**
X2
320VAC
0.012
10
5
11
7.5
0.6
MP2153K32B2R6**
X2
320VAC
0.015
10
5
11
7.5
0.6
MP2183K32B2R6**
X2
320VAC
0.018
10
5
11
7.5
0.6
MP2223K32B2R6**
X2
320VAC
0.022
10
5
11
7.5
0.6
MP2273K32B2R6**
X2
320VAC
0.027
10
5
11
7.5
0.6
MP2333K32B2R6**
X2
320VAC
0.033
10
5
11
7.5
0.6
MP2393K32B2R6**
X2
320VAC
0.039
10
5
11
7.5
0.6
MP2473K32B2R6**
X2
320VAC
0.047
10
5
11
7.5
0.6
MP2393K32B3R6**
X2
320VAC
0.039
10
6
12
7.5
0.6
MP2473K32B3R6**
X2
320VAC
0.047
10
6
12
7.5
0.6
MP2563K32B3R6**
X2
320VAC
0.056
10
6
12
7.5
0.6
MP2683K32B3R6**
X2
320VAC
0.068
10
6
12
7.5
0.6
MP2222K32C2R6**
X2
320VAC
0.0022
13
5
11
10
0.6
MP2272K32C2R6**
X2
320VAC
0.0027
13
5
11
10
0.6
MP2332K32C2R6**
X2
320VAC
0.0033
13
5
11
10
0.6
MP2392K32C2R6**
X2
320VAC
0.0039
13
5
11
10
0.6
MP2472K32C2R6**
X2
320VAC
0.0047
13
5
11
10
0.6
MP2562K32C2R6**
X2
320VAC
0.0056
13
5
11
10
0.6
MP2682K32C2R6**
X2
320VAC
0.0068
13
5
11
10
0.6
MP2822K32C2R6**
X2
320VAC
0.0082
13
5
11
10
0.6
MP2103K32C2R6**
X2
320VAC
0.01
13
5
11
10
0.6
MP2123K32C2R6**
X2
320VAC
0.012
13
5
11
10
0.6
MP2153K32C2R6**
X2
320VAC
0.015
13
5
11
10
0.6
MP2183K32C2R6**
X2
320VAC
0.018
13
5
11
10
0.6
说明 Note: “**”表示内部特征码
“**”=Internal use.
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part
成品编码
等级
电压
Part No.
Class
MP2223K32C2R6**
容量
尺寸 Dimension (mm)
Voltage
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.5
X2
320VAC
0.022
13
5
11
10
0.6
MP2273K32C2R6**
X2
320VAC
0.027
13
5
11
10
0.6
MP2333K32C2R6**
X2
320VAC
0.033
13
5
11
10
0.6
MP2393K32C2R6**
X2
320VAC
0.039
13
5
11
10
0.6
MP2473K32C2R6**
X2
320VAC
0.047
13
5
11
10
0.6
MP2563K32C2R6**
X2
320VAC
0.056
13
5
11
10
0.6
MP2683K32C2R6**
X2
320VAC
0.068
13
5
11
10
0.6
MP2104K32C2R6**
X2
320VAC
0.1
13
5
11
10
0.6
MP2683K32C3R6**
X2
320VAC
0.068
13
6
12
10
0.6
MP2104K32C3R6**
X2
320VAC
0.1
13
6
12
10
0.6
MP2154K32C3R6**
X2
320VAC
0.15
13
6
12
10
0.6
MP2224K32C5R6**
X2
320VAC
0.22
13
7.8
13.8
10
0.6
MP2563K32CDR6**
X2
320VAC
0.056
12.5
5
13
10
0.6
MP2823K32CDR6**
X2
320VAC
0.082
12.5
5
13
10
0.6
MP2823K32CGR6**
X2
320VAC
0.082
12.5
6
15.5
10
0.6
MP2104K32CGR6**
X2
320VAC
0.1
12.5
6
15.5
10
0.6
MP2124K32CGR6**
X2
320VAC
0.12
12.5
6
15.5
10
0.6
MP2154K32CGR6**
X2
320VAC
0.15
12.5
6
15.5
10
0.6
MP2184K32CKR6**
X2
320VAC
0.18
12.5
7
17.5
10
0.6
MP2184K32CGR6**
X2
320VAC
0.18
12.5
6
15.5
10
0.6
MP2224K32CKR6**
X2
320VAC
0.22
12.5
7
17.5
10
0.6
MP2274K32CKR6**
X2
320VAC
0.27
12.5
7
17.5
10
0.6
MP2274K32CNR6**
X2
320VAC
0.27
12.5
8
18.5
10
0.6
MP2334K32CNR6**
X2
320VAC
0.33
12.5
8
18.5
10
0.6
MP2334K32CRR6**
X2
320VAC
0.33
12.5
9
19.5
10
0.6
MP2104K32D1R6**
X2
320VAC
0.1
18
5
11
15
0.6
MP2124K32D1R6**
X2
320VAC
0.12
18
5
11
15
0.6
MP2104K32D2R8**
X2
320VAC
0.1
18
6
12
15
0.8
MP2124K32D2R8**
X2
320VAC
0.12
18
6
12
15
0.8
MP2184K32D2R8**
X2
320VAC
0.18
18
6
12
15
0.8
MP2334K32D3R8**
X2
320VAC
0.33
18
7.5
13.5
15
0.8
MP2224K32D4R8**
X2
320VAC
0.22
18
8.4
14.5
15
0.8
MP2334K32D4R8**
X2
320VAC
0.33
18
8.4
14.5
15
0.8
“**”=Internal use.
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part
成品编码
等级
电压
Part No.
Class
MP2474K32D4R8**
容量
尺寸 Dimension (mm)
Voltage
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.5
X2
320VAC
0.47
18
8.4
14.5
15
0.8
MP2474K32D6R8**
X2
320VAC
0.47
18
10
16
15
0.8
MP2684K32D6R8**
X2
320VAC
0.68
18
10
16
15
0.8
MP2474K32D8R8**
X2
320VAC
0.47
18
11.2
19.2
15
0.8
MP2684K32D8R8**
X2
320VAC
0.68
18
11.2
19.2
15
0.8
MP2154K32DBR6**
X2
320VAC
0.15
17.5
5
13
15
0.6
MP2224K32DBR6**
X2
320VAC
0.22
17.5
5
13
15
0.6
MP2184K32DDR8**
X2
320VAC
0.18
17.5
6
15.5
15
0.8
MP2224K32DDR8**
X2
320VAC
0.22
17.5
6
15.5
15
0.8
MP2274K32DDR8**
X2
320VAC
0.27
17.5
6
15.5
15
0.8
MP2334K32DDR8**
X2
320VAC
0.33
17.5
6
15.5
15
0.8
MP2394K32DDR8**
X2
320VAC
0.39
17.5
6
15.5
15
0.8
MP2224K32DGR8**
X2
320VAC
0.22
17.5
7
17.5
15
0.8
MP2274K32DGR8**
X2
320VAC
0.27
17.5
7
17.5
15
0.8
MP2334K32DGR8**
X2
320VAC
0.33
17.5
7
17.5
15
0.8
MP2474K32DGR8**
X2
320VAC
0.47
17.5
7
17.5
15
0.8
MP2334K32DKR8**
X2
320VAC
0.33
17.5
8
18.5
15
0.8
MP2394K32DKR8**
X2
320VAC
0.39
17.5
8
18.5
15
0.8
MP2474K32DKR8**
X2
320VAC
0.47
17.5
8
18.5
15
0.8
MP2564K32DKR8**
X2
320VAC
0.56
17.5
8
18.5
15
0.8
MP2684K32DKR8**
X2
320VAC
0.68
17.5
8
18.5
15
0.8
MP2394K32DNR8**
X2
320VAC
0.39
17.5
9
19.5
15
0.8
MP2564K32DNR8**
X2
320VAC
0.56
17.5
9
19.5
15
0.8
MP2564K32DRR8**
X2
320VAC
0.56
17.5
10
22.5
15
0.8
MP2684K32DRR8**
X2
320VAC
0.68
17.5
10
22.5
15
0.8
MP2684K32DUR8**
X2
320VAC
0.68
17.5
11
26.5
15
0.8
MP2824K32DUR8**
X2
320VAC
0.82
17.5
11
26.5
15
0.8
MP2105K32DXR8**
X2
320VAC
1.0
17.5
12
24.5
15
0.8
MP2334K32E2R8**
X2
320VAC
0.33
26.5
7
16.5
22.5
0.8
MP2394K32E2R8**
X2
320VAC
0.39
26.5
7
16.5
22.5
0.8
MP2474K32E2R8**
X2
320VAC
0.47
26.5
7
16.5
22.5
0.8
MP2334K32E3R8**
X2
320VAC
0.33
26.5
8.5
17
22.5
0.8
MP2394K32E3R8**
X2
320VAC
0.39
26.5
8.5
17
22.5
0.8
“**”=Internal use.
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part
成品编码
等级
电压
Part No.
Class
MP2474K32E3R8**
容量
尺寸 Dimension (mm)
Voltage
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.5
X2
320VAC
0.47
26.5
8.5
17
22.5
0.8
MP2564K32E3R8**
X2
320VAC
0.56
26.5
8.5
17
22.5
0.8
MP2684K32E3R8**
X2
320VAC
0.68
26.5
8.5
17
22.5
0.8
MP2474K32E4R8**
X2
320VAC
0.47
26.5
10
19
22.5
0.8
MP2564K32E4R8**
X2
320VAC
0.56
26.5
10
19
22.5
0.8
MP2684K32E4R8**
X2
320VAC
0.68
26.5
10
19
22.5
0.8
MP2824K32E4R8**
X2
320VAC
0.82
26.5
10
19
22.5
0.8
MP2105K32E4R8**
X2
320VAC
1.0
26.5
10
19
22.5
0.8
MP2824K32E5R8**
X2
320VAC
0.82
26.5
11
0.8
MP2105K32E5R8**
X2
320VAC
1.0
26.5
11
0.8
MP2105K32E6R8**
X2
320VAC
1.0
26.5
12
21.5
22.5
0.8
MP2125K32E6R8**
X2
320VAC
1.2
26.5
12
21.5
22.5
0.8
MP2155K32E7R8**
X2
320VAC
1.5
26.5
13
23
22.5
0.8
MP2105K32F1R8**
X2
320VAC
1.0
31.5
10.8
19.5
27.5
0.8
MP2125K32F1R8**
X2
320VAC
1.2
31.5
10.8
19.5
27.5
0.8
MP2125K32F2R8**
X2
320VAC
1.2
31.5
13
21.5
27.5
0.8
MP2155K32F2R8**
X2
320VAC
1.5
31.5
13
21.5
27.5
0.8
MP2185K32F2R8**
X2
320VAC
1.8
31.5
13
21.5
27.5
0.8
MP2155K32F3R8**
X2
320VAC
1.5
31
14
25
27.5
0.8
MP2185K32F3R8**
X2
320VAC
1.8
31
14
25
27.5
0.8
MP2205K32F3R8**
X2
320VAC
2.0
31
14
25
27.5
0.8
MP2225K32F3R8**
X2
320VAC
2.2
31
14
25
27.5
0.8
MP2205K32F4R8**
X2
320VAC
2.0
31.5
16
25.5
27.5
0.8
MP2255K32F4R8**
X2
320VAC
2.5
31.5
16
25.5
27.5
0.8
MP2275K32F4R8**
X2
320VAC
2.7
31.5
16
25.5
27.5
0.8
MP2305K32F4R8**
X2
320VAC
3.0
31.5
16
25.5
27.5
0.8
MP2225K32F5R8**
X2
320VAC
2.2
31.5
16
30
27.5
0.8
MP2255K32F5R8**
X2
320VAC
2.5
31.5
16
30
27.5
0.8
MP2335K32F5R8**
X2
320VAC
3.3
31.5
16
30
27.5
0.8
MP2305K32F6R8**
X2
320VAC
3.0
31
18
33
27.5
0.8
MP2335K32F6R8**
X2
320VAC
3.3
31
18
33
27.5
0.8
MP2355K32F6R8**
X2
320VAC
3.5
31
18
33
27.5
0.8
MP2395K32F6R8**
X2
320VAC
3.9
31
18
33
27.5
0.8
“**”=Internal use.
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part
成品编码
等级
电压
Part No.
Class
MP2405K32F6R8**
容量
尺寸 Dimension (mm)
Voltage
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.5
X2
320VAC
4.0
31
18
33
27.5
0.8
MP2455K32F6R8**
X2
320VAC
4.5
31
18
33
27.5
0.8
MP2475K32F6R8**
X2
320VAC
4.7
31
18
33
27.5
0.8
MP2505K32F6R8**
X2
320VAC
5.0
31
18
33
27.5
0.8
MP2275K32F9R8**
X2
320VAC
2.7
31.5
18
28
27.5
0.8
MP2335K32F9R8**
X2
320VAC
3.3
31.5
18
28
27.5
0.8
MP2355K32F9R8**
X2
320VAC
3.5
31.5
18
28
27.5
0.8
MP2155K32S0R1**
X2
320VAC
1.5
41
11
22
37.5
1.0
MP2185K32S0R1**
X2
320VAC
1.8
41
11
22
37.5
1.0
MP2205K32S0R1**
X2
320VAC
2.0
41
11
22
37.5
1.0
MP2185K32S1R1**
X2
320VAC
1.8
41
12
26
37.5
1.0
MP2205K32S1R1**
X2
320VAC
2.0
41
12
26
37.5
1.0
MP2225K32S1R1**
X2
320VAC
2.2
41
12
26
37.5
1.0
MP2255K32S1R1**
X2
320VAC
2.5
41
12
26
37.5
1.0
MP2275K32S1R1**
X2
320VAC
2.7
41
12
26
37.5
1.0
MP2225K32S2R1**
X2
320VAC
2.2
41
14
28
37.5
1.0
MP2255K32S2R1**
X2
320VAC
2.5
41
14
28
37.5
1.0
MP2275K32S2R1**
X2
320VAC
2.7
41
14
28
37.5
1.0
MP2305K32S2R1**
X2
320VAC
3.0
41
14
28
37.5
1.0
MP2335K32S2R1**
X2
320VAC
3.3
41
14
28
37.5
1.0
MP2355K32S2R1**
X2
320VAC
3.5
41
14
28
37.5
1.0
MP2305K32S3R1**
X2
320VAC
3.0
41
16
30
37.5
1.0
MP2335K32S3R1**
X2
320VAC
3.3
41
16
30
37.5
1.0
MP2355K32S3R1**
X2
320VAC
3.5
41
16
30
37.5
1.0
MP2395K32S3R1**
X2
320VAC
3.9
41
16
30
37.5
1.0
MP2405K32S3R1**
X2
320VAC
4.0
41
16
30
37.5
1.0
MP2455K32S3R1**
X2
320VAC
4.5
41
16
30
37.5
1.0
MP2475K32S3R1**
X2
320VAC
4.7
41
16
30
37.5
1.0
说明 Note:“**”表示内部特征码
“**”=Internal use. 说明 Note:“**”表示内部特征码
We can customize the capacitors according to customers special requirements.
“**”=Internal use.
很抱歉,暂时无法提供与“MP2224K32D2R8LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39655
- 100+0.31776
- 500+0.27835
- 1000+0.24880
- 5000+0.22521
- 10000+0.21330
