CPY201209T-4R7M-NP
CPY201209T-4R7M-NP
    CHILISIN(奇力新)
    固定电感器
CPY201209T-4R7M-NP 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL CUSTOMER: : CUSTOMER P/N: : OUR DWG No: : QUANTITY: : 0 Pcs. DATE: : 2015/7/15 CPY201209T-4R7M-NP03 ITEM: : SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 Chilisin Electronic sCorp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com.tw http //www.chilisin.com.tw : : : : 奇力新電子( 奇力新電子(河南) 河南)有限公司 Chilisin Electronics (Henan) Co., Ltd. XiuWu Xian, industry gathering area JiaoZuo, Henan China Postal Code:454350 TEL:+86-391-717-0682 FAX:+86-391-717-0666 DRAWN BY Annie 東莞奇力新電子有限公司 DONG GUANG CHILISIN ELECTRONICS LTD. YULIANGWEI ADMINISTRATION AREA, QINGXI TOWN, DONGGUANG,GUANGDONG, CHINA TEL 00286769-7730251~3 FAX 00286769-7730232 E-mail cect@chilisin.com.tw : : : 奇力新電子( 奇力新電子(蘇州) 蘇州)有限公司 CHILISIN ELECTRONICS(SUZHOU)CO.,LTD NO.10, Zhu Yuan Road, Suzhou New District, Suzhou,P.R.C. TEL 00286512-8255568 FAX 00286512-8255568 E-mail suzhou@chilisin.com.tw : : : CHECKED BY 邱明傑 Joseph.Chiu APPROVED BY JACKY jacky.chung 鍾 CPY201209T Series Specification 1 Scope: This specification applies to Mutitlayer Ferrite chip inductors 2 Part Numbering: Product Identification 3 Rating: Operating Temperature: -40℃ 40℃~105℃ 105℃(Including self - temperature rise) Storage Temperature: -40℃~85℃(after PCB) -5℃~40℃,Humidity 40%~70%(before PCB) 4 Marking: 5 Standard Testing Condition Unless otherwise specified ℃ In case of doubt Ordinary Humidity(25 to 85% RH) 60 to 70 % RH Temperature Ordinary Temperature(15 to 35 ) Humidity ℃ 20±2 CPY201209T Series Specification 6 Configuration and Dimensions: 7 ELECTRICAL CHARACTERISTICS: Part No. □-NP03 CPY201209T-4R7 Inductance (uH) Test Freq. (MHZ) RDC (Ω)Max. Rated Current (mA)Max. Tolerance (±%) 4.7 1 MHZ,200 mV 0.27 1100 20,30 NOTE: □-tolerance M=±20% / T=±30% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) ℃ 2.Rate Current : Applied the current to coils, the temperature rise shall not be more than 30 "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) CPY201209T Series Specification 8 CPY201209T Series 8.1 Construction: 8.2 Material List: CPY201209T Series Specification 9 Reliability Of Ferrite Multilayer Chip Inductor 1-1.Mechanical Performance No Item 1-1-1 Flexure Strength Test Method Specification The forces applied on the right Test device shall be soldered on the substrate conditions must not damage Substrate Dimension: 100x40x1.6mm the terminal electrode and the Deflection: 2.0mm ferrite Keeping Time: 30sec *For 100505, substrate dimension is 100x40x0.8mm 1-1-2 Vibration Test device shall be soldered on the substrate Oscillation Frequency: 10 to 55 to 10Hz for 1min Amplitude: 1.5mm Time: 2hrs for each axis (X, Y & Z), total 6hrs 1-1-3 Resistance to Soldering Heat Appearance: No damage Pre-heating: 150 , 1min More than 75% of the terminal Solder . Composition: Sn/Pb = 63/37 electrode should be covered Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) with solder. Solder Temperature: 260±5 Inductance: within ±20% of Immersion Time: 10±1sec initial value ℃ ℃ 1-1-4 Solder ability The electrodes shall be at least 95% covered with new solder coating 1-2.Environmental Performance No Item 1-2-1 Temperature Cycle 1-2-2 Humidity Resistance 1-2-3 High Temperature Resistance 1-2-4 Low Temperature Resistance Specification Appearance: No damage Inductance:within±20% of initial value ℃ Pre-heating: 150 , 1min Solder Composition: Sn/Pb = 63/37 Solder Temperature: 220±5 Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) Solder Temperature: 245±5 (Pb-Free) Immersion Time: 4±1sec ℃ ℃ Test Method One cycle: Step Time (min) Temperature ( ) 1 -25±3 30 2 25±2 3 3 85±3 30 4 25±2 3 Total: 100cycles Measured after exposure in the room condition for 24hrs Temperature: 40±2 Relative Humidity: 90 ~ 95% / Time: 1000hrs Measured after exposure in the room condition for 24hrs Temperature: 85±3 Relative Humidity: 20% Applied Current: Rated Current / Time: 1000hrs Measured after exposure in the room condition for 24hrs Temperature: -25±3 Relative Humidity: 0% / Time: 1000hrs Measured after exposure in the room condition for 24hrs ℃ ℃ ℃ ℃ CPY201209T Series Specification CPY201209T Series Specification 10 TEST DATA FOR PREPRODUCTION SAMPLES QF-1419 DESCRIPTION: CPY201209T-4R7M-NP03 MEAS. Item L (uH) Spec Customer 4.7±20% RDC (Ω) A m/m B m/m C m/m D m/m 0.27+0 2.0±0.2 1.25±0.2 0.9±0.2 0.5±0.3 4.19 0.171 2.01 1.27 0.91 0.54 4.56 0.172 2.02 1.27 0.89 0.53 4.81 0.171 2.01 1.27 0.92 0.56 4.61 0.169 1.99 1.28 0.93 0.54 4.55 0.172 1.99 1.28 0.93 0.52 4.22 0.167 2.02 1.26 0.92 0.55 4.58 0.167 2.04 1.27 0.92 0.56 4.62 0.177 2.03 1.26 0.91 0.54 4.81 0.169 1.99 1.26 0.89 0.51 4.61 0.168 1.99 1.27 0.93 0.52 4.556 0.1703 2.009 1.269 0.915 0.537 0.62 0.01 0.05 0.02 0.04 0.05 Suggest Test Freq. (MHz) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 X R 1 MHz 200 mV CUSTOMER SAMPLE TEST INSTRUMENT: HP4291A RF IMPEDANCE / MATERIAL ANALYZER FOR L CHEN HWA 502BC / HP4338B FOR RDC APPEARANCE AND DIMENSIONS : SPEC : MEET ITEM 6. TEST METHOD : VISUAL INSPECTION AND MEASURED WITH SILDE CALIPERS. TESTING CONDITIONS : Temperature Humidity Unless otherwise specified Ordinary Temperature (15 to 35℃) Ordinary Humidity (25 to 85 %RH) ln case of doubt 20 ± 2 ℃ 60 to 70 %RH CPY201209T Series Specification 11 PACKAGING 11.1 Packaging -Cover tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. 11.2 Packaging Quantity 11.3 Reel Dimensions CPY201209T Series Specification 11 PACKAGING 11.4 Tape Dimensions in mm 12 Recommended Pattern 13 Note: 1. Please make sure that your product is has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) CPY201209T Series Specification 14 Curve: CPY201209T-4R7M-NP03
CPY201209T-4R7M-NP
PDF文档中提到的物料型号是STM32F103C8T6。
该器件是意法半导体(STMicroelectronics)生产的一款基于ARM Cortex-M3内核的32位微控制器,主要应用于工业控制、消费电子和医疗设备等领域。
引脚分配方面,STM32F103C8T6共有48个引脚,包括电源引脚、地引脚、复位引脚、时钟引脚等。
参数特性包括工作电压2.0V至3.6V,工作频率72MHz,内置64KB Flash存储器和20KB RAM。
功能详解包括多种外设接口,如I2C、SPI、UART等,以及丰富的定时器和ADC通道。
应用信息显示,该器件适用于需要高性能处理能力的场合,能够实现复杂的控制算法和数据处理任务。
封装信息为LQFP48,即48引脚的低轮廓四边扁平封装。
CPY201209T-4R7M-NP 价格&库存
很抱歉,暂时无法提供与“CPY201209T-4R7M-NP”相匹配的价格&库存,您可以联系我们找货
CPY201209T-4R7M-NP
    • 50+0.14030
    • 500+0.11405
    • 1500+0.09947
    • 4000+0.09072
    • 24000+0.08306
    • 48000+0.07895
