O3212288153350
O3212288153350
    JGHC(晶光华)
    SMD3225_4P
    有源晶振 12.288MHz 3.3V -40℃~+85℃ CMOS
O3212288153350 数据手册
www.jghcorp.com 【深圳市晶光华电子有限公司】  Mainstream miniature oscillator package;  Supply voltage range : 1.8 V ~ 3.3 V;  Tri-State function available;  High stability, low jitter, low power consumption;  Main application :Optimal solution for home security devices, power saving application, and low frequency specification circuit design looking for a smaller package;  RoHS Compliant / Pb Free。 Crystals specifications ITEMS(项目) PARAMETER(规格说明) O32 Output Type(输出模式) CMOS Output Load(输出负载条件) 15 pF , or specify Oscillation Mode(振荡模式) Fundamental / 3rd Overtone Supply Voltage(电源电压) Frequency Range(输出频率范围) 1.8 V 2.5 V,2.8V 1 ~ 160 MHz Frequency Stability ± 25 ppm ,± 50 ppm Operating Temperature Range(工作温度) - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range(储存温度) - 55 ~ + 125 ℃ Oscillating voltage(振荡电压) Voltage Vol ( Max. ) 10 % VCC Max. Voltage Voh ( Min. ) 90 % VCC Min Rise ( Tr ) / Fall ( Tf ) Time:上升/下降时间 8 ns Max. Current Consumption(功耗) 15 mA Max. Symmetry(占空比) 40 ~ 60 % Start-up Time(振荡启动时间) 3 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) Dimensions 1 ps Max. Aging ( at 25 ℃ )频率老化 ± 3 ppm / year Max. Packing Unit(包装单位) 3,000pcs/Reel 3.3 V
O3212288153350 价格&库存
很抱歉,暂时无法提供与“O3212288153350”相匹配的价格&库存,您可以联系我们找货
O3212288153350
  • 5+2.29824
  • 50+1.77498
  • 150+1.55952
  • 500+1.28250
  • 3000+1.15938
  • 6000+1.07730
库存:1961
