盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列
Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series
■ 引用标准 Reference standards
GB10190(IEC384-16)
■ 结构 Structure
介质:聚丙烯膜
电极:双面金属化聚酯膜
封装:阻燃环氧树脂,符合 UL94 V-0
外壳:阻燃 PBT 塑壳,符合 UL94 V-0
Dielectric: polypropylene film
Electrode:double side metallized polyester film
Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0
Box: Flame retardant PBT plastic shell, conforming to UL94 V-0
典型应用 Typical
Application
广泛应用于高压高频脉冲电路中
适用于变频器的谐振电路中
适用于 LED 驱动和开关电源高效电路
吸收和 SCR 整流电路中
Widely used in high voltage high frequency pulse circuit.
Applicable for resonant circuit of frequency converter.
Suitable for LED driver and switching power supply high efficiency circuit
Snubber circuit and SCR rectifying circuit
特点 Features
损耗小,内部温升小, 小型化的安装尺寸,优异的阻燃性能(UL94V-0)
Low loss and low internal temperature rise, small mounting size, Excellent flame resistance property.
符合 RoHS 及 REACH 环保标准 Compliance with RoHs &
电性能规范 Performance Specifications
REACH requirements.
气候类别 Climate category
40/105/56
额定温度 Rated Temperature
85℃
工作温度范围
-40℃--+105℃.
Operating Temperature range
(+85℃~+105℃): decreasing factor 1.25% per ℃ for R.V(DC)
(+85℃~+105℃): 额定电压降额使用系数 1.25% per ℃ for R.V(DC)
额定电压 Rated Voltage
630VDC, 1000VDC,1600VDC,2000VDC,3000VDC
容量误差 Capacitance Tolerance
J: ±5%
容量范围
0.001μF~1.2μF
Capacitance Range
测试条件 Test Condition:
耐电压
1.6UR,5S
Withstand Voltage
损耗角 Dissipation factor
≤0.001
绝缘电阻或时间常数
CR≤0.33μF IR≥100000MΩ
Insulation Resistance
CR>0.33μF IR≥30000S
最大脉冲爬升速率
Max. Pulse Rise Time
(dV / dt)
(1KHZ )
20℃, 1KHz, 1Vrms
无击穿或飞弧
No breakdown or electric arcing
测试条件 Test Condition :
20℃
1Vrms
20℃
100V
1 min
UR(V)
P15
P22.5
P27.5
630V
2500
1600
1000
1000V
3500
2500
1300
1600V
6300
3200
2200
2000V
10000
5000
2500
3000V
10000
8000
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change ( relative to the initial
value):△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0020(1KHZ),CR>1uF
耐久性试验
温度 Temp.: +85℃,
绝缘电阻 Insulation Resistance
Endurance Test
电压 Voltage:
IR:≥ 额定值的 50%
IR:≥ 50% of rated value
1.25 Times Rated Voltage
持续时间 Duration Time: 1000H
损耗角增加:≤0.0015(10KHz)
dissipation factor rise:≤0.0015(10KHz)
容量变化(相对初始值):△C/C≤±10%
Capacitance change
(relative to the initial value):△C/C≤±10%
产品编码说明 Part No. Description:
15 位产品编码如下:
The Part No. Is total 15 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
11
C
4
Digit 1-3
8
2
1
J
型号代码 Product Name Code
2
J
E
12
R
13
14
15
8
C82= MMKP82 series
Digit 4-6
标称容量 Rated Capacitance Value
For example : 104 = 10×104pF = 0.1F
Digit 7
容量偏差 Capacitance Tolerance
J=±5%
Digit 8-9
额定电压 Rated Voltage Code
2J=630V 3A=1000V 3C=1600V 3D=2000V 3E=3000V
Digit 10-11 壳号 Plastic shell code
Digit 12
塑壳颜色 Plastic Shell Color
R = Grey Color with LOGO on the shell top
Digit 13
线径代码 Line diameter code
6=0.6 8=0.8
Digit 14-15 成型或内部识别码 Forming Type or Internal Use
料号明细及尺寸 Part No. List and Dimensions
UR :630Vdc(400Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
C82183J2JD2R8**
MMKP82
0.018
18
6
12
15
0.8
C82223J2JD2R8**
MMKP82
0.022
18
6
12
15
0.8
C82273J2JD2R8**
MMKP82
0.027
18
6
12
15
0.8
C82333J2JD2R8**
MMKP82
0.033
18
6
12
15
0.8
C82393J2JD2R8**
MMKP82
0.039
18
6
12
15
0.8
C82473J2JD2R8**
MMKP82
0.047
18
6
12
15
0.8
C82563J2JD3R8**
MMKP82
0.056
18
7.5
13.5
15
0.8
C82683J2JD4R8**
MMKP82
0.068
18
8.4
14.5
15
0.8
C82823J2JD4R8**
MMKP82
0.082
18
8.4
14.5
15
0.8
C82104J2JD6R8**
MMKP82
0.1
18
10
15.8
15
0.8
C82124J2JD8R8**
MMKP82
0.12
18
11.2
19.2
15
0.8
C82473J2JE1R8**
MMKP82
0.047
26.5
6
15
22.5
0.8
C82563J2JE1R8**
MMKP82
0.056
26.5
6
15
22.5
0.8
C82683J2JE1R8**
MMKP82
0.068
26.5
6
15
22.5
0.8
C82823J2JE1R8**
MMKP82
0.082
26.5
6
15
22.5
0.8
C82104J2JE1R8**
MMKP82
0.1
26.5
6
15
22.5
0.8
C82124J2JE2R8**
MMKP82
0.12
26.5
7
16.5
22.5
0.8
C82154J2JE3R8**
MMKP82
0.15
26.5
8.5
17
22.5
0.8
C82184J2JE3R8**
MMKP82
0.18
26.5
8.5
17
22.5
0.8
C82224J2JE4R8**
MMKP82
0.22
26.5
10
19
22.5
0.8
C82274J2JE5R8**
MMKP82
0.27
26.5
11
0.8
C82334J2JE6R8**
MMKP82
0.33
26.5
12
21.5
22.5
0.8
C82394J2JE6R8**
MMKP82
0.39
26.5
12
21.5
22.5
0.8
C82334J2JF1R8**
MMKP82
0.33
31.5
10.8
19.5
27.5
0.8
C82394J2JF1R8**
MMKP82
0.39
31.5
10.8
19.5
27.5
0.8
C82474J2JF2R8**
MMKP82
0.47
31.5
13
21.6
27.5
0.8
C82564J2JF2R8**
MMKP82
0.56
31.5
13
21.6
27.5
0.8
C82684J2JF3R8**
MMKP82
0.68
31
14
25
27.5
0.8
C82824J2JF4R8**
MMKP82
0.82
31.5
16
25.5
27.5
0.8
C82105J2JF5R8**
MMKP82
1
31.5
16
30
27.5
0.8
C82125J2JF5R8**
MMKP82
1.2
31.5
16
30
27.5
0.8
说明 Note: “**”表示内部特征码
“**”=Internal use.
UR :1000Vdc(600Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
d±0.05
C82102J3AC2R6**
MMKP82
0.001
13
5
11
10
0.6
C82122J3AC2R6**
MMKP82
0.0012
13
5
11
10
0.6
C82152J3AC2R6**
MMKP82
0.0015
13
5
11
10
0.6
C82182J3AC2R6**
MMKP82
0.0018
13
5
11
10
0.6
C82222J3AC2R6**
MMKP82
0.0022
13
5
11
10
0.6
C82272J3AC2R6**
MMKP82
0.0027
13
5
11
10
0.6
C82332J3AC2R6**
MMKP82
0.0033
13
5
11
10
0.6
C82392J3AC2R6**
MMKP82
0.0039
13
5
11
10
0.6
C82472J3AC2R6**
MMKP82
0.0047
13
5
11
10
0.6
C82562J3AC2R6**
MMKP82
0.0056
13
5
11
10
0.6
C82682J3AC2R6**
MMKP82
0.0068
13
5
11
10
0.6
C82822J3AC2R6**
MMKP82
0.0082
13
5
11
10
0.6
C82103J3AC2R6**
MMKP82
0.01
13
5
11
10
0.6
C82822J3AD2R8**
MMKP82
0.0082
18
6
12
15
0.8
C82103J3AD2R8**
MMKP82
0.01
18
6
12
15
0.8
C82123J3AD2R8**
MMKP82
0.012
18
6
12
15
0.8
C82153J3AD2R8**
MMKP82
0.015
18
6
12
15
0.8
C82183J3AD3R8**
MMKP82
0.018
18
7.5
13.5
15
0.8
C82223J3AD3R8**
MMKP82
0.022
18
7.5
13.5
15
0.8
C82273J3AD4R8**
MMKP82
0.027
18
8.4
14.5
15
0.8
C82333J3AD4R8**
MMKP82
0.033
18
8.4
14.5
15
0.8
C82393J3AD6R8**
MMKP82
0.039
18
10
15.8
15
0.8
C82473J3AD8R8**
MMKP82
0.047
18
11.2
19.2
15
0.8
“**”=Internal use.
UR :1000Vdc(600Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
d±0.05
C82273J3AE1R8**
MMKP82
0.027
26.5
6
15
22.5
0.8
C82333J3AE1R8**
MMKP82
0.033
26.5
6
15
22.5
0.8
C82393J3AE1R8**
MMKP82
0.039
26.5
6
15
22.5
0.8
C82473J3AE2R8**
MMKP82
0.047
26.5
7
16.5
22.5
0.8
C82563J3AE2R8**
MMKP82
0.056
26.5
7
16.5
22.5
0.8
C82683J3AE3R8**
MMKP82
0.068
26.5
8.5
17
22.5
0.8
C82823J3AE4R8**
MMKP82
0.082
26.5
10
19
22.5
0.8
C82104J3AE4R8**
MMKP82
0.1
26.5
10
19
22.5
0.8
C82124J3AE5R8**
MMKP82
0.12
26.5
11
0.8
C82154J3AE6R8**
MMKP82
0.15
26.5
12
21.5
22.5
0.8
C82104J3AF1R8**
MMKP82
0.1
31.5
10.8
19.5
27.5
0.8
C82124J3AF1R8**
MMKP82
0.12
31.5
10.8
19.5
27.5
0.8
C82154J3AF1R8**
MMKP82
0.15
31.5
10.8
19.5
27.5
0.8
C82184J3AF2R8**
MMKP82
0.18
31.5
13
21.6
27.5
0.8
C82224J3AF2R8**
MMKP82
0.22
31.5
13
21.6
27.5
0.8
C82274J3AF3R8**
MMKP82
0.27
31
14
25
27.5
0.8
C82334J3AF4R8**
MMKP82
0.33
31.5
16
25.5
27.5
0.8
C82394J3AF5R8**
MMKP82
0.39
31.5
16
30
27.5
0.8
C82474J3AF9R8**
MMKP82
0.47
31.5
18
28
27.5
0.8
“**”=Internal use.
UR :1600Vdc(650Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
d±0.05
C82332J3CD2R8**
MMKP82
0.0033
18
6
12
15
0.8
C82472J3CD2R8**
MMKP82
0.0047
18
6
12
15
0.8
C82562J3CD2R8**
MMKP82
0.0056
18
6
12
15
0.8
C82682J3CD2R8**
MMKP82
0.0068
18
6
12
15
0.8
C82822J3CD2R8**
MMKP82
0.0082
18
6
12
15
0.8
C82103J3CD2R8**
MMKP82
0.01
18
6
12
15
0.8
C82123J3CD3R8**
MMKP82
0.012
18
7.5
13.5
15
0.8
C82153J3CD3R8**
MMKP82
0.015
18
7.5
13.5
15
0.8
C82183J3CD4R8**
MMKP82
0.018
18
8.4
14.5
15
0.8
C82223J3CD4R8**
MMKP82
0.022
18
8.4
14.5
15
0.8
C82273J3CD6R8**
MMKP82
0.027
18
10
15.8
15
0.8
C82333J3CD8R8**
MMKP82
0.033
18
11.2
19.2
15
0.8
C82153J3CE1R8**
MMKP82
0.015
26.5
6
15
22.5
0.8
C82183J3CE1R8**
MMKP82
0.018
26.5
6
15
22.5
0.8
C82223J3CE1R8**
MMKP82
0.022
26.5
6
15
22.5
0.8
C82273J3CE2R8**
MMKP82
0.027
26.5
7
16.5
22.5
0.8
C82333J3CE2R8**
MMKP82
0.033
26.5
7
16.5
22.5
0.8
C82393J3CE3R8**
MMKP82
0.039
26.5
8.5
17
22.5
0.8
C82473J3CE4R8**
MMKP82
0.047
26.5
10
19
22.5
0.8
C82563J3CE4R8**
MMKP82
0.056
26.5
10
19
22.5
0.8
C82683J3CE5R8**
MMKP82
0.068
26.5
11
0.8
C82823J3CE6R8**
MMKP82
0.082
26.5
12
21.5
22.5
0.8
C82823J3CF1R8**
MMKP82
0.082
31.5
10.8
19.5
27.5
0.8
C82104J3CF1R8**
MMKP82
0.1
31.5
10.8
19.5
27.5
0.8
C82124J3CF2R8**
MMKP82
0.12
31.5
13
21.6
27.5
0.8
C82154J3CF3R8**
MMKP82
0.15
31
14
25
27.5
0.8
C82184J3CF3R8**
MMKP82
0.18
31
14
25
27.5
0.8
C82224J3CF5R8**
MMKP82
0.22
31.5
16
30
27.5
0.8
“**”=Internal use.
and Dimensions
UR :2000Vdc(700Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
d±0.05
C82102J3DD2R8**
MMKP82
0.001
18
6
12
15
0.8
C82122J3DD2R8**
MMKP82
0.0012
18
6
12
15
0.8
C82152J3DD2R8**
MMKP82
0.0015
18
6
12
15
0.8
C82182J3DD2R8**
MMKP82
0.0018
18
6
12
15
0.8
C82222J3DD2R8**
MMKP82
0.0022
18
6
12
15
0.8
C82272J3DD2R8**
MMKP82
0.0027
18
6
12
15
0.8
C82332J3DD2R8**
MMKP82
0.0033
18
6
12
15
0.8
C82392J3DD2R8**
MMKP82
0.0039
18
6
12
15
0.8
C82472J3DD2R8**
MMKP82
0.0047
18
6
12
15
0.8
C82562J3DD3R8**
MMKP82
0.0056
18
7.5
13.5
15
0.8
C82682J3DD3R8**
MMKP82
0.0068
18
7.5
13.5
15
0.8
C82822J3DD4R8**
MMKP82
0.0082
18
8.4
14.5
15
0.8
C82103J3DD6R8**
MMKP82
0.01
18
10
15.8
15
0.8
C82123J3DD6J8**
MMKP82
0.012
18
10
15.8
15
0.8
C82153J3DD8R8**
MMKP82
0.015
18
11.2
19.2
15
0.8
C82103J3DE1R8**
MMKP82
0.01
26.5
6
15
22.5
0.8
C82123J3DE1R8**
MMKP82
0.012
26.5
6
15
22.5
0.8
C82153J3DE2R8**
MMKP82
0.015
26.5
7
16.5
22.5
0.8
C82183J3DE2R8**
MMKP82
0.018
26.5
7
16.5
22.5
0.8
C82223J3DE3R8**
MMKP82
0.022
26.5
8.5
17
22.5
0.8
C82273J3DE4R8**
MMKP82
0.027
26.5
10
19
22.5
0.8
C82333J3DE4R8**
MMKP82
0.033
26.5
10
19
22.5
0.8
C82393J3DE5R8**
MMKP82
0.039
26.5
11
0.8
C82473J3DE6R8**
MMKP82
0.047
26.5
12
21.5
22.5
0.8
C82393J3DF1R8**
MMKP82
0.039
31.5
10.8
19.5
27.5
0.8
C82473J3DF1R8**
MMKP82
0.047
31.5
10.8
19.5
27.5
0.8
C82563J3DF2R8**
MMKP82
0.056
31.5
13
21.6
27.5
0.8
C82683J3DF2R8**
MMKP82
0.068
31.5
13
21.6
27.5
0.8
C82823J3DF3R8**
MMKP82
0.082
31
14
25
27.5
0.8
C82104J3DF4R8**
MMKP82
0.1
31.5
16
25.5
27.5
0.8
C82124J3DF4R8**
MMKP82
0.12
31.5
16
25.5
27.5
0.8
C82154J3DF5R8**
MMKP82
0.15
31.5
16
30
27.5
0.8
“**”=Internal use.
UR 3000Vdc(750Vac)
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
W±0.5
T±0.5
H±0.5
P±0.5
d±0.05
C82102J3ED2R8**
MMKP82
0.001
18.0
6.0
12.0
15.0
0.8
C82122J3ED2R8**
MMKP82
0.0012
18.0
6.0
12.0
15.0
0.8
C82152J3ED2R8**
MMKP82
0.0015
18.0
6.0
12.0
15.0
0.8
C82182J3ED2R8**
MMKP82
0.0018
18.0
6.0
12.0
15.0
0.8
C82222J3ED2R8**
MMKP82
0.0022
18.0
6.0
12.0
15.0
0.8
C82272J3ED2R8**
MMKP82
0.0027
18.0
6.0
12.0
15.0
0.8
C82332J3ED3R8**
MMKP82
0.0033
18.0
7.5
13.5
15.0
0.8
C82392J3ED3R8**
MMKP82
0.0039
18.0
7.5
13.5
15.0
0.8
C82472J3ED4R8**
MMKP82
0.0047
18.0
8.4
14.5
15.0
0.8
C82562J3ED5R8**
MMKP82
0.0056
18.0
9.5
15.5
15.0
0.8
C82682J3ED6R8**
MMKP82
0.0068
18.0
9.5
15.5
15.0
0.8
C82822J3ED8R8**
MMKP82
0.0082
18.0
11.2
19.2
15.0
0.8
C82442J3EE2R8**
MMKP82
0.0044
26.5
7.0
16.5
22.5
0.8
C82472J3EE2R8**
MMKP82
0.0047
26.5
7.0
16.5
22.5
0.8
C82562J3EE2R8**
MMKP82
0.0056
26.5
7.0
16.5
22.5
0.8
C82682J3EE2R8**
MMKP82
0.0068
26.5
7.0
16.5
22.5
0.8
C82822J3EE3R8**
MMKP82
0.0082
26.5
8.5
17.0
22.5
0.8
C82103J3EE3R8**
MMKP82
0.01
26.5
8.5
17.0
22.5
0.8
C82123J3EE4R8**
MMKP82
0.012
26.5
10.0
19.0
22.5
0.8
C82153J3EE5R8**
MMKP82
0.015
26.5
11.0
20.0
22.5
0.8
C82183J3EE6R8**
MMKP82
0.018
26.5
12.0
21.5
22.5
0.8
C82223J3EE7R8**
MMKP82
0.022
26.5
13.0
23.0
22.5
0.8
“**”=Internal use.
Note: We can customize the capacitors according to customers special requirements.
很抱歉,暂时无法提供与“C82152J3DD2R8LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.03380
- 50+0.81660
- 150+0.72354
- 500+0.60740
- 2500+0.55569
- 5000+0.52470
