O5310000153350
O5310000153350
    JGHC(晶光华)
    SMD5032_4P
    有源晶振 10MHz 3.3V -40℃~+85℃ CMOS
O5310000153350 数据手册
www.jghcorp.com 【深圳市晶光华电子有限公司】  Small SMD seam sealed clock crystal oscillator units.  High precision characteristic covering up to wide frequency range.  Designed for automatic mounting and reflow soldering.  Tri-State function available.  Supply voltage range : 1.8 V ~ 5.0 V.  High stability, low jitter, low power consumption.  Main application : wireless communication set, PDA, and DSC. Crystals specifications ITEMS(项目) PARAMETER(规格说明) O53 Output Type(输出模式) CMOS Output Load(输出负载条件) 15 pF , 30 pF Oscillation Mode(振荡模式) Fundamental / 3rd Overtone Supply Voltage(电源电压) 1.8±10%V ;2.5±10%V ;2.8±10%V ;3.3±10%V;5±10%V; Frequency Range(输出频率范围) 1 ~ 150 MHz Frequency Stability ± 20 ppm , ± 25 ppm , ± 30 ppm , ± 50 ppm Operating Temperature Range(工作温度) - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range(储存温度) - 55 ~ + 125 ℃ Oscillating voltage(振荡电压) Voltage Vol ( Max. ) 10 % VCC Max. Voltage Voh ( Min. ) 90 % VCC Min 8 ns Max. Rise ( Tr ) / Fall ( Tf ) Time:上升/下降时间 Current Consumption(功耗) 1-75 MHz 5 mA Max. 10 mA Max. 20 mA Max. 75-150 MHz 15 mA Max. 20 mA Max. NA Symmetry(占空比) 40 ~ 60 % Start-up Time(振荡启动时间) 5 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) Dimensions 1 ps Max. Aging ( at 25 ℃ )频率老化 ± 3 ppm / year Max. Packing Unit(包装单位) 1,000pcs/Reel
O5310000153350 价格&库存
很抱歉,暂时无法提供与“O5310000153350”相匹配的价格&库存,您可以联系我们找货
O5310000153350
  • 1+3.36960
  • 10+2.61360
  • 30+2.28960
  • 100+1.87920
  • 500+1.69560
库存:511
