HP Series
HP Series
Snap-in Type 105℃
Features
◆ Highly reliable capacitors that with high ripple current.
◆ Terminal spacing fixed at 10 mm for printed circuit board plug in.
◆ Aluminum case designed explosion-proof vent.
◆ Best for switching power supplies.
◆ For detail specifications, please refer to Engineering Bulletion No. E107
◆ RoHS Compliant
Specifications
Item
Performance Characteristics
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Leakage Current (+20℃,max.)
-40 to +105℃
10 to 100 VDC
330 to 68000μF
-25 to +105℃
160 to 450 VDC
33 to 2200μF
±20% (120Hz, +20℃)
I ≦ 0.02CV After 5 minutes with rated working voltage applied.
Less than the value under table (%)
μF VDC
47~390
470~3900
4700~8200
10000~22000
27000~47000
56000~68000
Dissipation Factor
(tanδ,at 20℃,120Hz)
10~16
25
35
40
45
50
25~35
35
40
45
50~63
30
35
80~100
15
160~250
15
15
315~450
160 200~250
4
4
400~450
8
Impedance ratio max.
Low Temperature Characteristics
(at 120Hz)
Load Life
Shelf Life
Rated voltage(V)
Z - 25℃ Z+20℃
Z - 40℃ Z+20℃
10
5
15
16
5
15
25
4
15
35
4
12
50
4
12
63
4
12
100
4
12
Test conditions
Duration time
:2000 Hrs
Ambient temperature
:+105℃
Applied voltage
:Rated DC working voltage
After test requirement at +20℃
Capacitance change
:≦ ±20% of the initial measured value
Dissipation factor
:≦ 200% of the initial specified value
Leakage current
:≦ The initial specified value
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+105℃
:None
Applied voltage
After test requirement at +20℃ : Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz) 50(60) 120
0.8
1
10<CAP≦100
0.8
1
100<CAP≦1000
0.8
1
1000<CAP
400
1.23
1.16
1.11
1K
1.36
1.25
1.17
10K 50K-100K
1.48
1.53
1.35
1.38
1.25
1.28
Diagram of Dimensions:(unit:mm)
182
HP Series
Case Size
φDxL(mm)
4700
6800
8200
10000
12000
15000
18000
22000
27000
Size
22
Ripple
22x26
1.24
22x26
22x26
22x31
1.56
2.04
2.20
22x31
22x36
22x36
2.34
2.49
2.76
22x36
22x41
2.94
3.12
22x46
3.48
33000
39000
47000
56000
68000
WV(SV)
Cap φD
(μF)
1500
2200
3300
3900
4700
5600
6800
8200
10000
12000
15000
22
Size Ripple
10 (13)
Size
25
Ripple
25x26
25x26
25x26
1.56
2.04
2.20
25x26
25x26
25x31
25x31
25x36
2.40
2.60
2.76
2.94
3.12
25x36
25x46
3.48
3.72
25x51
4.10
Size
30
Ripple
30x26
30x26
2.80
30x26
30x31
30x31
30x36
3.08
3.30
3.48
3.72
30x41
30x46
30x51
4.10
4.38
4.64
25 (32)
25
30
Size Ripple Size Ripple
1.03
22x26
1.48
25x26
1.48
22x26
22x31
22x31
22x31
1.88
1.92
2.25
2.60
25x26
1.90
30x26
1.92
25x26
2.60
30x26
2.60
22x36
22x41
3.14
3.50
25x31
25x36
3.14
3.50
30x26
30x31
3.14
3.50
22x46
4.02
25x41
25x46
25x51
4.02
4.58
4.82
30x31
30x36
30x41
4.02
4.58
4.82
30x46
5.12
22000
27000
33000
WV(SV)
22
Cap φD
Size Ripple
(μF)
680
1000
22x26 0.84
1200
22x26 1.10
1500
22x31 1.12
22x26 1.50
1800
22x331 1.62
2200
22x31 1.65
22x31 1.85
2700
22x36 1.97
22x36 2.24
3300
3900
4700
5600
6800
8200
10000
12000
15000
50 (63)
25
30
25x26
1.12
25x26
25x26
25x31
25x31
1.65
1.85
1.98
2.24
22x41
2.54
25x36
2.54
22x46
2.95
22x51
3.10
25x36
25x41
25x41
25x46
25x46
25x51
2.80
3.01
3.02
3.15
3.23
3.35
35
Ripple
2.20
22x26
18000
Size
35x27
3.20
35x27
35x27
35x32
35x32
35x37
35x42
35x52
3.48
3.65
3.85
4.10
4.38
4.64
4.80
35
Size Ripple
35x27
3.50
35x27
35x32
35x32
35x37
35x37
35x42
35x47
35x52
4.02
4.58
4.79
4.82
5.12
5.30
5.47
6.09
35
Size Ripple
22
Size Ripple
22x26 1.17
22x26 1.53
22x31 1.65
22x31 2.02
22x31 2.20
22x31 2.79
22x36 2.97
22x36 3.06
22x41
3.24
22x51
3.51
16 (20)
Size
25
Ripple
Size
30
Ripple
Size
35
Ripple
25x26
1.55
25x26
2.02
30x26
2.02
25x26
25x31
25x31
2.79
2.97
3.06
30x26
2.81
30x26
3.06
25x36
25x41
25x46
25x46
25x51
25x51
3.24
3.42
3.51
4.08
4.25
4.30
30x26
3.24
35x32
3.24
30x36
30x36
3.51
4.08
35x32
35x32
3.54
4.08
30x41
30x46
4.30
4.83
35x32
35x37
4.30
4.83
30x51
5.78
35x42
35x47
35x52
5.78
6.32
7.05
35 (44)
22
25
30
35
Size Ripple Size Ripple Size Ripple Size Ripple
22x26 1.26
22x26 1.35 25x26 1.45
22x31 1.45
22x26 1.80 25x26 1.90 30x26 1.92
22x31 1.90
22x31 2.23
22x36 2.42 25x26 2.30 30x26 2.54
25x31 2.44
22x36 2.89 25x31 2.89 30x26 2.89
22x41 3.24 25x36 3.24 30x26 3.21 35x27 3.24
30x31 3.43
22x51 3.57 25x41 3.57 30x31 3.57 35x27 3.57
25x46 3.96 30x36 3.96 35x27 3.75
35x32 4.00
25x51 4.21 30x41 4.21 35x32 4.21
30x46 4.69 35x37 4.69
35x42 5.07
35x52
63 (79)
22
25
30
22x26 0.70
22x26 0.85 25x26 0.85
22x26 0.98
22x26 1.10 25x26 1.12 30x26 1.14
22x31 1.15
22x31 1.40 25x26 1.40
Size
5.50
35
Ripple
30x26
1.65
22x36
22x41
1.65
2.07
25x31
25x36
1.65
2.07
30x26
30x26
1.65
2.07
30x26
2.24
2.48
30x36
3.05
35x27
3.05
2.95
2.40
2.54
2.92
3.07
3.43
35x27
35x27
25x36
25x41
25x41
25x46
25x51
2.48
2.49
2.66
2.95
2.46
2.55
30x31
30x26
30x31
30x31
22x46
22x51
30x41
3.43
35x32
3.43
30x36
30x41
30x41
3.14
3.20
3.26
35x27
35x32
35x32
3.10
3.20
3.26
30x46
3.86
35x37
3.86
30x51
4.64
35x42
4.64
30x46
30x51
3.58
4.11
35x37
35x42
35x47
35x52
3.58
4.11
4.62
5.05
35x47
35x52
5.05
5.75
183
Ripple Current ( A, rms ) at 105℃ 120Hz
Snap-in
WV(SV)
Cap φD
(μF)
3300
HP Series
φDxL(mm)
WV(SV)
Cap φD
(μF)
330
470
560
680
820
1000
1200
1500
1800
2200
Size
22
Ripple
22x26
0.63
22x26
22x31
22x26
22x31
22x31
0.70
0.75
0.81
0.87
1.02
22x31
22x36
22x36
80 (100)
Size
25
Ripple
25x26
0.86
1.11
1.18
1.46
25x26
25x31
25x31
1.02
1.09
1.16
25x31
1.46
22x41
1.74
25x36
1.74
22x46
1.95
22x51
2.25
25x36
25x41
25x41
25x46
25x46
25x51
25x51
25x56
1.89
1.99
2.20
2.31
2.58
2.70
3.30
3.45
2700
3300
3900
4700
5600
6800
WV(SV)
Cap φD
(μF)
100
150
220
270
330
390
470
560
680
22
Size Ripple
Size
30
Ripple
1.38
30x26
30x31
30x26
30x31
30x31
1.46
1.56
1.70
1.82
1.95
22x41
1.65
25x36
1.65
30x31
1.65
22x46
1.83
25x41
1.83
30x31
1.83
35x27
1.83
30x31
30x36
30x36
30x41
30x41
30x46
30x46
30x51
30x51
2.20
2.31
2.58
2.72
3.30
3.50
3.73
3.90
4.29
560
680
820
1000
1200
1500
1800
1.95
25x41
2.52
30x36
2.52
35x32
2.52
35x27
35x32
35x32
35x37
35x37
35x42
35x37
35x42
35x42
35x47
35x52
2.25
2.40
2.68
2.85
3.30
3.50
3.73
3.93
4.29
5.10
5.66
25x51
3.03
30x41
3.03
35x32
3.03
30x46
4.10
35x37
4.10
30x56
4.59
35x47
4.59
35x47
4.98
35x52
5.43
35
Size Ripple
30x26
1.21
22x41
1.40
25x36
1.40
30x31
1.40
35x27
1.40
22x46
1.64
25x36
25x41
25x41
25x46
25x51
1.58
1.67
1.76
1.85
2.15
30x31
30x36
30x36
1.65
1.75
1.85
35x27
35x32
35x32
1.71
1.80
1.85
30x41
2.15
35x32
2.15
25x56
2.46
30x46
30x51
2.46
2.80
35x37
35x42
2.46
2.80
30x51
3.13
35x42
35x52
35x57
3.13
3.26
3.39
2200
470
35x27
1.21
22x46
1.35
22x51
22x56
1.60
1.70
220 (270)
25
30
25x26
25x26
25x26
25x26
25x31
25x31
25x36
25x36
25x41
25x46
25x51
25x56
0.50
0.60
0.85
1.05
1.15
1.20
1.28
1.31
1.38
1.60
1.75
2.00
1.32
30x26
25x31
0.50
0.60
0.85
1.05
1.15
1.25
30x26
1.38
1.00
1.10
22x26
22x26
22x31
22x31
22x36
22x41
1.26
25x31
30x26
30x26
22
Size Ripple
25x26
1.38
0.98
1.10
1800
1.26
35
Ripple
22x36
160 (200)
25
30
1500
22x31
Size
1.16
25x26
25x31
1200
22
25
30
22x26 0.54
22x26 0.79 25x26 0.81
22x31 0.85
22x26 0.90 25x26 0.95
22x31 0.97
22x31 1.02 25x26 1.02 30x26 1.14
30x26
0.37
0.42
0.74
0.98
1.09
1.15
1.21
1000
390
35
Ripple
22x26
22x26
22x26
22x31
22x31
22x36
22x36
820
WV(SV)
Cap φD
(μF)
68
100
150
180
220
270
330
Size
100 (125)
30x26
30x26
30x26
30x26
30x31
30x31
0.85
1.05
1.15
1.25
1.33
1.35
30x36
30x41
30x46
30x51
1.60
1.75
2.00
2.30
35
Size Ripple
35x27
1.35
35x27
35x32
35x37
35x42
35x47
35x52
35x56
1.60
1.75
2.00
2.30
2.35
2.40
2.50
184
22
Size Ripple
22x26 0.38
22x26 0.54
22x31 0.92
22x31 1.03
22x36 1.21
22x36 1.33
22x41 1.41
22x41 1.57
22x46 1.65
22x46 1.81
22x51 1.90
22x51 2.04
22x56 2.12
22
Size Ripple
22x26 0.27
22x31 0.44
22x31 0.60
22x31 0.69
22x36 1.00
22x41 1.16
22x46 1.28
22x46 1.48
200 (250)
25
30
25x26
25x26
25x26
25x31
25x31
25x36
25x36
25x41
25x41
25x46
25x46
25x51
25x51
25x56
0.54
0.92
1.03
1.21
1.34
1.43
1.59
1.68
1.85
1.94
2.07
2.17
2.30
2.40
0.44
0.60
0.69
1.00
1.16
1.28
1.48
25x41
25x46
25x51
1.76
1.85
1.93
35
Ripple
30x26
30x26
30x26
30x31
0.92
1.05
1.21
1.45
30x31
1.65
35x27
1.65
30x31
30x36
30x31
30x36
30x36
30x41
30x41
30x46
30x51
1.85
1.94
2.04
2.17
2.30
2.40
2.62
2.75
3.00
35x27
1.85
35x32
2.17
35x37
2.31
35x37
35x42
35x42
35x47
35x52
35x52
2.62
2.75
3.00
3.28
3.46
4.01
250 (300)
25
30
25x26
25x26
25x26
25x31
25x36
25x36
25x36
Size
Size
35
Ripple
30x26
30x26
30x26
30x31
30x31
30x31
0.60
0.69
1.00
1.16
1.28
1.48
35x27
35x27
1.28
1.48
30x36
1.76
35x32
1.76
30x41
30x46
30x51
1.93
2.22
2.48
35x32
35x37
35x42
35x47
35x52
1.93
2.22
2.48
2.80
3.17
HP Series
φDxL(mm)
220
270
330
400 (450)
Size
25
Ripple
Size
30
Ripple
220
270
330
390
30
Ripple
0.72
0.82
30x26
30x26
0.72
0.85
22x31
22x31
0.64
0.75
25x26
25x31
0.64
0.75
30x26
30x26
0.64
0.75
25x31
25x31
25x36
25x41
0.82
0.90
0.98
1.14
30x26
30x26
30x31
30x36
0.82
0.90
0.95
1.14
22x36
22x36
22x41
22x46
0.78
0.84
0.97
1.02
25x31
25x36
25x36
25x41
0.78
1.84
0.97
1.02
30x26
30x26
30x31
30x36
0.78
0.84
0.97
1.02
25x46
1.21
30x41
30x46
30x51
1.21
1.40
1.57
25x46
1.22
30x41
30x46
30x51
1.22
1.5
1.68
WV(SV)
450 (500)
22
25
30
φD
Cap
(μF)
33
22x26 0.24
47
22x31 0.35 25x26 0.35
22x31 0.41 25x26 0.41
56
180
Size
25x26
25x31
560
100
120
150
22
25
22x26 0.32
22x26 0.45 25x26 0.45
22x26 0.52 25x26 0.52
0.56
0.68
470
82
35
Ripple
25x26
25x26
390
68
Size
420 (470)
22x36
22x36
0.55
0.64
25x31
25x31
0.55
0.64
30x26
30x26
0.55
0.64
22x41
22x46
22x51
0.74
0.82
0.96
25x31
25x36
25x41
25x46
0.74
0.82
0.96
1.14
30x31
30x31
30x36
30x36
30x41
30x41
30x51
0.74
0.82
0.96
1.10
1.16
1.24
1.48
35x27
35x32
0.95
1.14
35x32
35x37
35x42
35x42
35x47
35x47
35x52
35x52
1.21
1.40
1.57
1.71
1.79
1.94
2.03
2.23
Size
Size
35
Ripple
35x27
1.02
35x32
35x37
35x42
35x47
1.22
1.5
1.68
1.76
35x52
1.87
35
Ripple
35x27
35x32
0.96
1.14
35x37
35x42
35x47
35x52
1.24
1.48
1.64
1.86
470
560
185
Snap-in
WV(SV)
22
φD
Cap
Size Ripple
(μF)
33
22x26 0.39
47
22x26 0.56
22x26 0.63
56
22x31 0.68
68
22x31 0.72
22x31 0.77
82
22x36 0.82
100
22x36 0.82
22x36 0.90
120
150
22x41 0.98
22x46 1.14
180
很抱歉,暂时无法提供与“HP561M400P520A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.09000
- 10+17.71200
- 30+17.46360
- 100+17.21520
