SQH6020S-2R2M-LF
SQH6020S-2R2M-LF
    COILMASTER(统宇电研)
    SMD,6.2x6.2mm
    功率电感 SMD
SQH6020S-2R2M-LF 数据手册
Coilmaster Electronics Co., Ltd. 3F No.211, Huan Bei Rd. Chung Li City, Taoyuan 320, Taiwan Tel : +886-3-422-8279 Fax : +886-3-452-5688 E-mail :info@coilmaster.com.tw Web Site : www.coilmaster.com.tw SQH6020S SERIES ~ Low Profile SMD Power Inductors PART NUMBERING SYSTEM SQH 6020S TYPE DIMENSIONS - 220M INDUCTANCE SHAPES AND DIMENSIONS - LF LEAD FREE UNIT:mm A=6.2 Max.    B=6.2 Max.    C=4.0 Ref.    D=2.0 Max.    E=1.35±0.2  RECOMMENDED PATTERNS UNIT:mm G= 3.10          H= 5.70          I = 1.60              FEATURES * Low profile and small inductors ( 6.2mm Max. square and 2.0mm Max. height )  * Magnetically shielded construction and high current    * Ideal for DC‐DC converter choke coil for portable equipments ( DVDs , DSC , Cellular , PDAs )  * RoHS compliant option with lead free    1/2 Coilmaster Electronics Co., Ltd. 3F No.211, Huan Bei Rd. Chung Li City, Taoyuan 320, Taiwan Tel : +886-3-422-8279 Fax : +886-3-452-5688 E-mail :info@coilmaster.com.tw Web Site : www.coilmaster.com.tw SQH6020S SERIES ~ Low Profile SMD Power Inductors SPECIFICATION TABLE PART NUMBER INDUCTANCE (μH) DCR (mΩ) (Max.) Isat (A) (Max.) Irms (A) (Max.) TEST FREQ. (f) SQH6020S‐0R8N‐LF  0.8±30%  26.0  5.50  3.80  100KHz  SQH6020S‐1R5N‐LF  1.5±30%  33.8  4.00  3.20  100KHz  SQH6020S‐2R2M‐LF  2.2±20%  44.2  3.20  2.70  100KHz  SQH6020S‐3R3M‐LF  3.3±20%  52.0  2.80  2.60  100KHz  SQH6020S‐4R7M‐LF  4.7±20%  75.4  2.40  2.00  100KHz  SQH6020S‐6R8M‐LF  6.8±20%  110.5  2.00  1.80  100KHz  SQH6020S‐100M‐LF  10±20%  162.5  1.70  1.40  100KHz  SQH6020S‐220M‐LF  ● ● ● 377.0  1.05  0.95  100KHz  22±20%  Isat : DC current at which the inductance drops 30%(typ) from its value without current.  Irms : The temperature rise current value is the DC current value having temperature increase up 40°C temperature  rise from 25°C ambient.  Operating temperature range ‐40℃  to +105℃  , Electrical specifications at 25℃  .          2/2
SQH6020S-2R2M-LF
1. 物料型号:SQH6020S系列,型号包括SQH6020S-OR8N-LF、SQH6020S-1R5N-LF等,具有不同的电感值。
2. 器件简介:这些电感器具有低轮廓和小型化设计,尺寸最大为6.2mm x 6.2mm,高度最大为2.0mm。它们采用磁屏蔽结构,适用于高电流应用。
3. 引脚分配:文档中未明确提供引脚分配信息,但通常这类电感器为SMD封装,具有端对端的引脚布局。
4. 参数特性:包括电感值、直流电阻(DCR)、饱和电流(Isat)、有效值电流(Irms)和测试频率。例如,SQH6020S-220M-LF型号的电感值为22μH,直流电阻为377mΩ,饱和电流为1.05A,有效值电流为0.95A,测试频率为100kHz。
5. 功能详解:这些电感器适用于便携式设备的DC-DC转换器,如DVD、DSC、手机、PDA等。
6. 应用信息:适用于需要低轮廓和小型化电感器的便携式设备。
7. 封装信息:封装类型为SQH6020S,尺寸和推荐布局图案在文档中有详细说明。
SQH6020S-2R2M-LF 价格&库存
很抱歉,暂时无法提供与“SQH6020S-2R2M-LF”相匹配的价格&库存,您可以联系我们找货
