OP322516.384MEDA4SI-u
    YXC(扬兴科技)
    SMD3225_4P
    可编程晶振 SMD3225_4P
OP322516.384MEDA4SI-u 数据手册
PROGRAMMABLE CRYSTAL OSCILLATOR YSO680PR Low Power Applications Features ‧Any frequency ‧One time programmable ‧Low power consumption design ‧PLL circuit provides wide frequency ‧Package Size: 2.5*2.0 3.2*2.5 5.0*3.2 7.0*5.0mm. range application (1-108MHz) Specifications Parameter Frequency Range Supply Voltage Variation (Vdd)10% 1.8V 2.5V 3.3V 1MHz to108MHz 1MHz to 108MHz 1MHz to 108MHz 1.62V~1.98V 2.25V~2.75V 2.97V~3.63V Standby Current 15uA Frequency Tolerance ±20ppm,±25ppm,±50ppm,or specify Output Load 15pF Operating Temperature Range -40~+85℃,or specify Storage Temperature Range -55~+125℃ Voltage Vol ( Max. ) / Vol ( Min. ) VOH = 90%Vdd/VOL = 10%Vdd Duty Cycle 45~55% Period Jitter (@12K-20Mhz) 1.8V=1.5ps 2.5V=1.1ps 3.3V=1ps Start-up Time 10ms Max. Supply Current See Below Frequency Aging (at 25℃) ±3 ppm / year Max. Pin Dimension Pin Symbol Output Enable 1 OE/ST/NC Pin Assignments Functionality Standby No Connect H:specified frequency output L:output is low. Specified frequency output stop. H:specified frequency output L:output is low. Device goes to sleep mode. Supply current reduces to 400uA(Standby Current). Pin 1 = VDD or Pin 1 is Open : Specified frequency output.Pin 1 has no function 2 GNG Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage Current Consumption Supply Voltage Power Dissipation 1.000~30.000MHZ 31.000~75.000MHZ 76.000~108.000MHZ 1.8V 6mA max 8mA max 12mA max 2.5V 8mA max 10mA max 15mA max 3.3V 10mA max 15mA max 20mA max www.yxc.hk 第1页共3页 PROGRAMMABLE CRYSTAL OSCILLATOR YSO680PR Low Power Dimensions and Patterns [unit:mm] Package Size – Dimensions (Unit: mm) 2.5*2.0mm Recommended Land Pattern (Unit: mm) 0.9 0.95 0.9 #4 #3 0.95 0.8±0.1 0.8 0.65 0.8 0.65 MARKING #2 2.0±0.1 #1 0.68 2.5±0.1 0.78 0.4 3.2*2.5mm 3.2±0.15 1.3 1.0 1.3 #2 1.1 0.8 1.1 1.0 MARKING 2.5±0.1 0.65 #1 #4 #3 0.9 0.9±0.1 1.2 5.0*3.2mm 1.4 2.54±0.1 5.0±0.2 #1 2.2 1.0 MARKING 3.2±0.1 1.2 #2 #4 #3 1.2±0.1 1.2 2.54 7.0*5.0mm 7.00±0.15 5.08±0.15 2.0 #3 1.4±0.1 #4 2.2 2.6±0.1 MAR KING #2 5.0±0.1 #1 1.4±0.15 0.6±0.15 3.28 1.8 Notes: A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required. www.yxc.hk 第2页共3页 PROGRAMMABLE CRYSTAL OSCILLATOR YSO680PR Low Power Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) Test Circuit Taping Specification(Unit: mm) Size(OSC) A B C D E F G H SMD-7050 180±2.0 16.0±0.3 7.50±0.1 5.50±0.1 8.0±0.1 2.00±0.1 61.0±1.0 16.0±1.0 SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.0±0.1 1.70±0.1 61.0±1.0 12.0±1.0 SMD-3225 180±2.0 8.0±0.3 3.40±0.1 2.70±0.1 4.0±0.1 1.50±0.1 61.0±1.0 8.0±1.0 SMD-2520 180±2.0 8.0±0.3 2.90±0.1 2.40±0.1 4.0±0.1 1.20±0.1 61.0±1.0 8.0±1.0 www.yxc.hk 第3页共3页
物料型号:YSO680PR
器件简介: - 低功耗设计 - 可提供任何频率 - 一次性可编程 - 适用于PLL电路,频率范围宽(1-108MHz) - 符合ROHS和NPS无铅标准
引脚分配: - 1号引脚:OE/ST/NC(输出使能/待机/无连接) - 2号引脚:GND(电源地) - 3号引脚:OUT(输出) - 4号引脚:VDD(电源电压)
参数特性: - 频率范围:1MHz至108MHz - 供电电压变化:1.62V-3.63V,具体取决于工作电压 - 待机电流:15uA - 频率容差:+20ppm、25ppm、50ppm或指定值 - 输出负载:15pF - 工作温度范围:-40°C至+85°C - 存储温度范围:-55°C至+125°C - 电压变化:VOH=90%Vdd,VOL=10%Vdd - 占空比:45-55% - 周期抖动:1.8V=1.5ps,2.5V=1.1ps,3.3V=1ps - 启动时间:最大10ms - 供电电流:见下文 - 频率老化:每年最大±3ppm
功能详解: - 1号引脚可以控制输出使能、待机或无功能 - 需要在Vdd和GND之间连接0.01uF至0.1uF或更高值的电容
应用信息: - 适用于需要宽频率范围和低功耗的应用场合
封装信息: - 提供多种封装尺寸,如2.52.0mm、3.22.5mm、5.03.2mm和7.05.0mm - 推荐焊盘图案和尺寸
OP322516.384MEDA4SI-u 价格&库存
很抱歉,暂时无法提供与“OP322516.384MEDA4SI-u”相匹配的价格&库存,您可以联系我们找货
