BC6R3M221LO6.3*8L-1A4T 数据手册
BC Series
low impedance, high ripple current
Load life of 2000 hours at 105℃
RoHS Compliant
◆ 规格表 Specifications
CF
BE
项目Items
mini size
Ultra low
ESR
耐久性
Endurence
耐湿负荷特性
Damp Heat
(Steady State)
High
BD
2.5 ~ 25V
静电容量允许偏差
Capacitance tolerance
温度特性
Low Temperture
Characteristics
(Max.Impedance Ratio)
BC
BC
-55 ~ +105℃
额定工作电压范围
Rated Voltage Range
损耗角正切值tanδ
Dissipation Factor
Long life
特性参数Characteristics
使用温度范围
Category
Temperture Range
漏电流
Leakage Current
CA
±20%(M)
(at 20℃,120Hz)
施加额定工作电压2分钟后读数,小于或等于规格值 ( 20℃)
I≤0.2CV 或280μA(取大值)(The bigger)(The bigger)
After 2 minutes applied for rated voltage at 20℃, less than or equal to the specified value.
Rated voltage (V)
2.5~25
(at 20℃,120Hz)
tanδ (Max.)
0.12
Z(-25℃)/Z(+20℃)
≤1.25
Z(-55℃)/Z(+20℃)
≤1.25
(100KHz)
105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be met when thecapacitors are restored to 20°C after the rated voltage
is applied for 2000 hours at 105℃.
Appearance
No significant damage
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦150% of the specified value
ESR
Leakage current
≦The specified value
在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be met when the capacitors are restored to 20°C after the rated voltage
is applied for 1000 hours at 60℃, 90%~ 95% RH.
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
浪涌电压=额定电压* 1.15(V)
Surge Voltage=Rated voltage * 1.15(V)
浪涌电压特性
(Surge Voltage)
在105℃环境中,按充电30秒,放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求
The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃
for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
◆ 外形图Dimensions (mm)
ΦD
5
5.5
6.3
8
10
P
2
2.5
2.5
3.5
5
Φd
0.5
0.5
0.5
0.6
0.6
ɑ
L
BC6R3M221LO6.3*8L-1A4T 价格&库存
很抱歉,暂时无法提供与“BC6R3M221LO6.3*8L-1A4T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.42866
- 50+0.41991
- 150+0.41408
- 500+0.40824
