BC025M221LO6.3*8L-1A4T 数据手册
BL-QM/D-02-214.01
CONDUCTIVE POLYMER ALUMINUM ELECTROLYTIC CAPACITORS
承 认 书
DATA SHEET
Customer name: 深圳市金鹏辉科技有限公司
BERYL SERIES:
BC
DESCRIPTION:
220μF/25V Φ6.3*8L
Apply
2019-10-9
date
TYPE:
BERYL
RADIAL
CUSTOMER
P/N:
P/N:
PREPARED
CHECKED
APPROVAL
王丽
邹建明
伍小军
PREPARED
CHECKED
APPROVAL
Zhao Qing Beryl Electronic Technology Co., Ltd.
TEL: (0758) 2862871
E-mail: master@zq-beryl.com
FAX: (0758) 2862870
http://www.zq-beryl.com
NO.8 DUANZHOU ROAD, ZHAOQING CITY. GUANGDONG. CHINA
After the product certification, please sign a copy, if you do not sign the acknowledgment before the formal order,it is
considered that the user has defaulted our relevant standards and technical indicators.
Sheet NO.:20191009A
Page
1 / 13
BL-QM/D-02-214.01
Revise record
NO.
Date
01
2019.10.9
Sheet NO.:20191009A
Revise reason
Revise content
Issue
First issue
Page
2 / 13
BL-QM/D-02-214.01
1、Application
This specification applies to Aluminum electrolytic capacitor (foil type) used in electronic equipment.
Designed capacitor’s quality meets IEC 60384.
2、Table of specification and characteristics
Series
Cap(uF)
120Hz/20℃
WV(V)
Size
Temperature
Life(hours)
BC
220
25
6.3*8
-55-105℃
2000
DF (%)(MAX)
120Hz/20℃
LC(μA)(MAX)
2min/20℃
12
ESR(mΩ)(MAX)
100KHz/20℃
RC (mArms)
(MAX)100KHz
Surge voltage(V)
30
1490
28.8
1100
Other:
Frequency Multipliers:
频率
Frequency(Hz)
60Hz
120HZ≤f﹤1KHZ
1KHZ≤f﹤10KHZ
10KHZ≤f﹤100KHZ
100KHZ≤f﹤500KHZ
系数Coefficient
0.04
0.05
0.30
0.70
1.00
3、Product Dimensions
St andard Type
ΦD
L
Φd
P
6.3±0.5
8±1.0
0.5±0.05
2.5±0.5
Sheet NO.:20191009A
Page
3 / 13
BL-QM/D-02-214.01
4、Part Number
BC
025
M
221
LO
6.3*8
TYPE CODE DESCRIPTION
RATED CAPACITANCE:221=220uF
CAPACITANCE TOLERANCE:M=±20%
RATED VOLTAGE:025=25V
SERIES NAME
5、Construction
Lead
Material
name
Composition
Supplier name
Rubber
Lead
Al and (Fe+Cu+Sn)
Nan Ming(Quan Yong)、
Jin
Lian fu
Rubber
EPT / IIR
Lian An 、Lian Hua Xin
Case
Aluminum+Coating
Yi Peng、Ao Xing
Paper
Wood / Fibrous
plant materials
KAN、NKK
Anode foil
Al + Al2O3
KDK、Heng Yang、JCC
Cathode foil
Aluminum
JCC、TOYO、Na Nuo
Dielectrics
Poly3,4-Ethylene
Dioxy Thiophene
BERYL
Case
Outer Paper
Cathode foil
Inside Paper
Anode foil
Sheet NO.:20191009A
Page
4 / 13
BL-QM/D-02-214.01
6、Product Marking
Marking Sample:
1
6
936
4
5
220 BC
3
25V
2
Marking Details:
Capacitor shall be marked the following items:
1) Trademark (BERYL)
2) working voltage
3) Nominal capacitance
4) Cathode marked
5) Series
6) Date code
19:Manufactured year 2019
Code
9
2
3
4
5
6
Year
2019
2020
2021
2022
2023
2024
2025
2026
Page
16:Manufactured week (01、02、03、04……51、52)
Sheet NO.:20191009A
5 / 13
BL-QM/D-02-214.01
7、Characteristics
Standard atmospheric conditions
Unless other specified, the standard range of atmospheric conditions for making
measurements and tests is as follows:
Ambient temperature :15C to 35C
Relative humidity :45% to 85%
Air pressure
:86kPa to 106kPa
If there is any doubt about the results, measurement shall be made within the following conditions:
Ambient temperature :20C 2C
Relative humidity :60% to 70%
Air pressure
: 86kPa to 106kPa
Operating temperature range
The ambient temperature range at which the capacitor can be operated continuously at rated voltage
is -55C to +105C.
Table
ITEM
1
2
3
Nominal
capacitance
(Tolerance)
Leakage
current
Dissipation
factor
PERFORMANCE
Measuring Frequency: 120Hz±12Hz
Measuring Voltage: Not more than 0.5Vrms +1.5~2.0V.DC
Measuring Temperature: 20±2℃
Shall be within the specified capacitance tolerance.
Connecting the capacitor with a protective resistor (1kΩ±10Ω) in series for
2 minutes, and then, measure leakage current.
I: Leakage current (μA)
I (μA) ≤0.2CVor280 (μA) whichever is greater,
measurement circuit refer to right drawing.
C: Capacitance (μF)
V: Rated DC working voltage (V)
Nominal capacitance, for measuring frequency, voltage and temperature.
Must be within the parameters (See page 3)
Sheet NO.:20191009A
Page
6 / 13
BL-QM/D-02-214.01
ITEM
4
5
6
7
Equivalent
Series
Resistance
Load
life
test
Shelf
life
test
Terminal
strength
PERFORMANCE
Measuring frequency:100kHz; Measuring temperature:20±2℃
Measuring point: 2mm max. from the surface of a sealing rubber on the lead wire.
(20℃) Must be within the parameters (See page 3)
According to IEC60384-4No. 4.13 methods, the capacitor is stored at a temperature of
Maximum operating temperature ±2°C with DC bias voltage for Rated life +48/0hours.
Then the product should be tested after 16 hours
recovering time at atmospheric conditions. The result should meet the following table:
The characteristic shall meet the following requirements.
Leakage current
Not more than the specified value.
Capacitance Change
Within ±20% of initial value.
Dissipation Factor
Not more than 150%of the specified value.
Equivalent Series Resistance
Appearance
There shall be no leakage of electrolyte.
The capacitors are then stored with no voltage applied at a temperature of Maximum operating
temperature±2℃ for1000+48/0 hours. Following this period, the capacitors shall be removed
from the test chamber and be allowed to stabilized at room temperature for16 hours. measure
leakage current
Leakage current
Capacitance Change
Dissipation Factor
Appearance
Tensile strength of terminals
Fixed the capacitor, applied force to the terminal in lead out direction for30+5-0
seconds. Bending strength of terminals.
Fixed the capacitor, applied force to bent the terminal (1~4 mm from the rubber) for 90o within
2~3 seconds, and then bent it for 90o to its original position within 2~3 seconds.
Tensile force N
Diameter of lead wire
Bending force N (kgf)
(kgf)
0.5mm and less
5 (0.51)
2.5 (0.25)
0.6~0.8 mm
10(1.02)
5(0.51)
No noticeable changes shall be found, no breakage or looseness at the terminal.
Sheet NO.:20191009A
Page
7 / 13
BL-QM/D-02-214.01
ITEM
PERFORMANCE
STEP
1
8
Temperatur
e
characterist
ics
Time
Testing temperature (℃)
20±2
Time to reach thermal equilibrium
2
(-55)-25±3
3
20±2
4
105±2
5
20±2
Capacitance, DF, and impedance shall be measured at 120Hz.
a. At +105℃, capacitance measured at +20℃ shall be within ±25% of its original value.
Dissipation factor shall be within the specified value
The leakage current measured shall be within the specified value.
b. In step 5, capacitance measured at +20℃ shall be within ±10% of its original value.
c. At- 55℃/ (20℃), Impedance (Z) ratio shall not exceed the value of the following table.
Z-25℃/Z+20℃
≦1.25
(100KHz)
Z-55℃/Z+20℃
≦1.25
Applied a surge voltage to the capacitor connected with a (100 ±50)/CR (kΩ) resistor in
series for 30±5 seconds in every 5±0.5 minutes at 15~35℃.Procedure shall be repeated
1000 times. Then the capacitors shall be left under normal humidity for 1-2 hours
before measurement
CR :Nominal Capacitance (μF)
9
Surge
test
Leakage current
Capacitance Change
Within ±15% of initial value.
Dissipation Factor
Appearance
Attention:
This test simulates over voltage at abnormal situation only. It is not applicable to such over
voltage as often applied.
Sheet NO.:20191009A
Page
8 / 13
BL-QM/D-02-214.01
ITEM
PERFORMANCE
Temperature cycle:
According to IEC60384-4 No.4.7 methods, capacitor shall be placed in an oven, the condition
according as below:
Temperature
10
Change of
temperature
test
Time
(1) +20℃
3
Minutes
(2) Rated low temperature (- 55℃) (-25℃)
30±2
Minutes
(3) Rated high temperature (+105℃)
30±2
Minutes
(1) to (3) =1 cycle, total 5 cycle
The characteristic shall meet the following requirement.
Leakage current
11
12
Damp
heat
test
Solderabilit
y test
Dissipation Factor
Appearance
Humidity test:
According to IEC60384-4 No.4.12 methods, capacitor shall
be exposed for 500±8 hours in an atmosphere of 90~95%R H .at
40±2℃, the characteristic change shall meet the following requirement.
Leakage current
Capacitance Change
Within ±10% of initial value.
Dissipation Factor
Not more than 150% of the specified value.
Appearance
The capacitor shall be tested under the following conditions:
Soldering temperature :245 5C
Dipping depth
: 2mm
Dipping speed
: 252.5mm/s
Dipping time
:30.5s
Soldering wetting time Less than 3s
Coating quality
Sheet NO.:20191009A
A minimum of 95% of the surface being
immersed
Page
9 / 13
BL-QM/D-02-214.01
ITEM
PERFORMANCE
The following conditions shall be applied for 2 hours in each 3 mutually perpendicular
directions. Vibration frequency range :10Hz ~ 55Hz
each to peak amplitude :1.5mm
Sweep rate
:10Hz ~ 55Hz ~ 10Hz in about 1 minute
Mounting method:The capacitor with diameter greater than 12.5mm or longer than 25mm
must be fixed in place with a bracket.
Within 30
4mm or less
13
Vibration
test
To be soldered
After the test, the following items shall be tested:
No intermittent contacts, open or short circuiting.
Inner construction
No damage of tab terminals or electrodes.
No mechanical damage in terminal. No leakage
of electrolyte or swelling of the case. The
Appearance
markings shall be legible.
14
Resistance
to
solder heat
test
Terminals of the capacitor
shall be immersed into solder bath at 260±5℃for10±1seconds
1
or400±10℃for3 0 seconds to 1.5~2.0 mm from the body of capacitor. Then the capacitor
shall be left under the normal temperature and normal humidity for 1~2 hours before
measurement.
Sheet NO.:20191009A
Leakage current
Capacitance Change
Within ±5% of initial value.
Dissipation Factor
Appearance
Page
10 / 13
BL-QM/D-02-214.01
8、 Packing Information
Packing Label Marked (the following items shall be marked on the label)
(Inside box or bag)
⑴Clint order number ⑵Client part number ⑶Beryl part number ⑷Capacitance ⑸Voltage ⑹Dimension
⑺Packaging quantity ⑻Capacitance tolerance ⑼ QC Marking ⑽ Lot number ⑾ Series
LOT Number :
1)Bulk Packing:
3)Outer box
Sheet NO.:20191009A
2)Taped Packing:
4) Outer box label:
Page
11 / 13
BL-QM/D-02-214.01
9、Prohibition to Use Environment- related Substances
We are hereby to certify the followings:
Our company hereby warrants and guarantees that all or part of products, including, but
not limited to, the peripherals, accessories or package, delivered to your company (including
your subsidiaries and affiliated companies) directly or indirectly by our company are free
from any of the substances listed below.
The latest version of
BC025M221LO6.3*8L-1A4T 价格&库存
很抱歉,暂时无法提供与“BC025M221LO6.3*8L-1A4T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.02349
- 50+0.85242
- 150+0.76688
- 1000+0.59115
- 2000+0.53983
- 5000+0.51417
