Aluminum Electrolytic Capacitors
SG
Features
‧ 105℃, 1,000 hours assured
‧ High temperature Category range, with 7mm height
‧ RoHS Compliance
Sleeve & Marking Color: Green & Black
SPECIFICATIONS
Items
Category Temperature Range
Capacitance Tolerance
Performance
-40℃ ~ +105℃
±20%
I = 0.01CV or 3 (µA) whichever is greater (after 2 minutes)
Where, C = rated capacitance in µF
V = rated DC working voltage in V
Leakage Current (at 20℃)
Dissipation Factor
(Tanδat 120Hz, 20℃)
Rated Voltage
Tanδ(max)
4
0.35
6.3
0.23
10
0.20
16
0.17
(at 120Hz, 20℃)
25
0.15
35
0.12
50
0.10
63
0.10
Impedance ratio shall not exceed the values given in the table below.
Rated Voltage
4
6.3
10
16
25
35
50
Impedance Z(-25℃)/Z(+20℃)
6
4
3
3
2
2
2
Z(-40℃)/Z(+20℃)
Ratio
12
10
8
6
4
4
4
Low Temperature
Characteristics (at 120Hz)
63
2
4
Test Time
1,000 Hrs
Within ±20% of initial value
Capacitance Change
Dissipation Factor
Less than 200% of specified value
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied
with rated ripple current for 1,000 hours at 105℃.
Test time: 500 hours; other items are the same as those for the Endurance.
Endurance
Shelf Life Test
Freq.(Hz)
Cap.(μ F)
Ripple Current &
Frequency Multipliers
60 (50)
120
500
1k
10k up
0.75
0.88
1.00
1.00
1.20
1.10
1.30
1.15
1.45
1.20
Under 47
100 to 330
DIAGRAM OF DIMENSIONS
φD+βmax
15 min
Sleeve
LEAD SPACING AND DIAMETER Unit: mm
φD
P
φd
α
β
P±0.5
φd
L+α max
4 min
V. DC
Contents
0.1
0.22
0.33
0.47
1
2.2
3.3
4.7
10
0R1
R22
R33
R47
010
2R2
3R3
4R7
100
22
33
47
100
220
330
220
330
470
101
221
331
4V (0G)
φD×L
4×7
4×7
5×7
6.3×7
8×7
mA
32
38
61
90
156
6.3V (0J)
φD×L
4×7
4×7
4×7
6.3×7*
6.3×7
8×7
mA
31
32
38
75
99
156
10V (1A)
φD×L
4×7
4×7
5×7*
6.3×7
8×7
Note: Case size in mark of “*” is available to product down size.
2011 Version
mA
32
35
47
80
140
5
2.0
6.3
2.5
0.5
8
3.5
1.0
0.5
Dimension: φD × L(mm)
Ripple Current: mA/rms at 120 Hz, 105°C
DIMENSION & PERMISSIBLE RIPPLE CURRENT
µF
4
1.5
0.45
16V (1C)
φD×L
mA
25V (1E)
φD×L
mA
4×7
25
4×7
26
5×7*
5×7
6.3×7*
6.3×7
8×7
39
43
59
90
146
5×7*
6.3×7
6.3×7
8×7
41
53
65
125
35V (1V)
φD×L
50V (1H)
63V (1J)
mA
φD×L
mA
φD×L
mA
4×7
5×7*
22
30
4×7
4×7
4×7
4×7
4×7
4×7
4×7
5×7*
6.3×7*
2
3
4
5
10
15
18
23
34
4×7
4×7
4×7
4×7
4×7
4×7
4×7
5×7
6.3×7
2
3
4.4
7.9
11
17
21
26
40
6.3×7
8×7*
8×7
47
71
83
6.3×7
8×7
8×7
53
76
85
8×7
70
很抱歉,暂时无法提供与“SG-101M1EBK-0807”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45922
- 100+0.37368
- 300+0.33092
