35ME680WA
35ME680WA
    SUNCON
    AEC_D10X22MM_TM
    直插铝电解电容 AEC_D10X22MM_TM
35ME680WA 数据手册
Aluminum Electrolytic Type / Radial Lead Type Aluminum Electrolytic Capacitors Radial Lead Type ME-SWB ME-WA ● ● 105℃, Small, Long Life Series ■ Specifications Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 63 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 79 0.12 0.10 0.10 Category temperature range (℃) − ME-UAX・SAX Capacitance tolerance (%) 120Hz/20℃ −40 to +105 M : ±20 ME-SWG ME-LS ME-CZ ME-CA ME-CX Dissipation Factor(tan δ) tanδ (max.)120Hz/20℃ Leakage current (LC) ME-WA 0.22 0.19 0.16 0.14 Exceeding 1,000μF, +0.02 every 1,000μF 0.03CV μA/after 2minutes (max.) Based on the value at −25℃ Z/Z20℃ 120Hz, +20℃ −40℃ Z/Z20℃ Impedance ratio at Iow temperature ME-AX ME-WX Low Impedance, High Ripple Current 105℃ 8,000 to 10,000hours Non solvent proof ME-UZ・SZ ME-HC RoHS compliance 105℃ rated voltage applied (With the rated ripple current) Endurance ME-WL 2 2 2 2 2 2 2 3 3 3 3 3 3 3 Test φ8 : 8,000hours, φ10 to φ16 : 10,000hours △C/C Within ±25% of the initial value(6.3V, 10V : ±30%) tanδ Less than 200% of the specified value LC Less than the specified value ME-WG ME-FX ME-PX ME-FC・FD ■ Dimensions (Unit : mm) sleeve ME-FH φd±0.05 φD±0.5 ME-SWN F±0.5 ME-HPC・HPD ME-HWN pressure relief vent φD 8 10 12.5 16 F 3.5 5.0 5.0 7.5 φd 0.6 0.6 0.6★ 0.8 ★φ12.5×30:φd=0.8 15min. L+αmax. 5min. 20min. α : L
35ME680WA 价格&库存
很抱歉,暂时无法提供与“35ME680WA”相匹配的价格&库存,您可以联系我们找货
