Aluminum Electrolytic Type / Surface Mount Type
Capacitors
Surface
Mount Type
CE-BD
CE-BS
Solvent proof (within 2 minutes)
AEC-Q200
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
4
6.3
10
16
25
35
50
63
100
Surge voltage
(V)
Room temperature
5.0
8.0
13
44
63
79
125
−40 to +85
Category temperature range (℃)
CE-BS
Capacitance tolerance (%)
120Hz/20℃
CE-LD
CE-FS
CE-FS(High Voltage)
CE-FH
CE-AX
CE-KX
tanδ
(max.)
120Hz/20℃
Dissipation Factor(tan δ)
M : ±20
φ4 to φ6.3
0.35
0.26
φ8 to φ16
0.40
0.30
Impedance ratio at
Iow temperature
Endurance
85℃, 2,000hours
rated voltage applied
(With the rated
ripple current)
CE-LX
0.16
0.14
0.12
0.12
0.12
0.10
0.24
0.20
0.16
0.14
0.12
0.12
0.10
The greater value of either 0.01CV or 3
Based on the value at −25℃ Z/Z20℃
120Hz, +20℃ −40℃ Z/Z20℃
CE-GA
0.20
Exceeding 1,000μF, +0.02 every 1,000μF
μA/after 2minutes (max.)
Leakage current
(LC)
CE-ZX
CE-ZC
Standard
Series
CE-BSS
CE-FSS
RoHS compliance
7
4
3
2
2
2
2
2
2
15
8
6
4
4
3
3
3
3
△C/C
Within ±25% of the initial value
tanδ
Less than 200% of the specified value
LC
Less than the specified value
CE-LS
CE-LH
CE-PS
CE-PF
CE-TH
CE-JX
CE-NP
CE-FN
Polarity
(Cathode)
0D
10
16 V
W
Rated Capacitance
Series Symbol
Rated Voltage(6.3V→6)
L
[ φD≥12.5 ]
Polarity
(Cathode) Lot No.
Indicated Only φD=16
0DT
4700
10 V
D±0.5
Lot No.
Rated Capacitance
Series Symbol
42
(Unit : mm)
0.3max.
C
CE-PC
CE-PH
[ φD≤10 ]
(P)
CE-LF
■ Marking, Dimensions
H
CE-LL
φD
CE-LH(High Voltage)
R (+)
A pressure relief vent is provided
for φD=8 or bigger
(P)reference size
L
W±0.2
H±0.2
C±0.2
R
P
4
5.4−0.2
+0.1
4.3
4.3
5.0
0.5 to 0.8
1.0
4
6.0
±0.3
4.3
4.3
5.0
0.5 to 0.8
1.0
5
5.4−0.2
+0.1
5.3
5.3
6.0
0.5 to 0.8
1.4
6.3
5.4−0.2
+0.1
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
6.0
±0.3
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
7.7
±0.3
6.6
6.6
7.3
0.5 to 0.8
2.2
8
10.2
±0.3
8.3
8.3
9.0
0.7 to 1.0
3.2
10
7.7
±0.3
10.3
10.3
11.0
1.0 to 1.4
4.6
10
10.2
±0.3
10.3
10.3
11.0
1.0 to 1.4
4.6
12.5
13.5
±0.5
12.8
12.8
13.5
1.0 to 1.4
4.6
16
16.5
±0.5
16.3
16.3
17.3
1.7 to 2.1
7.0
RoHS compliance
■ Size, Rated Ripple Current
6.3
10
16
25
10
22
4×5.4
19
4×5.4
25
5×5.4
28
4×5.4
31
5×5.4
35
5×5.4
39
6.3×5.4
52
63
33
4×5.4
26
5×5.4
39
5×5.4
43
6.3×5.4
57
6.3×5.4
47
4×5.4
34
5×5.4
47
6.3×5.4
59
6.3×5.4
68
6.3×6.0
68
100
5×5.4
61
6.3×5.4
71
6.3×5.4
76
6.3×5.4
86
6.3×7.7
130
6.3×6.0
88
6.3×7.7
135
8×10.2
200
6.3×5.4
82
6.3×6.0
95
6.3×7.7
150
6.3×7.7
150
8×10.2
250
150
220
10×7.7
6.3×6.0
330
102
6.3×7.7
150
8×10.2
280
8×10.2
10×7.7
6.3×7.7
470
150
8×10.2
300
8×10.2
10×7.7
8×10.2
680
10×7.7
1000
300
280
250
CE-BD
8×10.2
310
CE-BSS
10×10.2
430
280
8×10.2
330
10×10.2
450
CE-BS
300
300
330
10×10.2
450
CE-LD
CE-FSS
CE-FS
300
8×10.2
Surface
Mount Type
4
4.7
Capacitors
V
μF
CE-FS
(High Voltage)
10×10.2
450
12.5×13.5
660
CE-FH
CE-AX
1500
2200
12.5×13.5
12.5×13.5
3300
12.5×13.5
16×16.5
CE-KX
16×16.5
16×16.5
16×16.5
6800
730
750
4700
710
1150
1200
1260
CE-ZX
CE-ZC
CE-LX
1330
CE-GA
CE-LS
CE-LH
V
μF
35
50
63
100
CE-LH
(High Voltage)
0.47
4×5.4
5
4×5.4
5
1.0
4×5.4
10
4×5.4
10
4×6.0
10
CE-LF
2.2
4×5.4
15
4×5.4
15
6.3×6.0
CE-PC
3.3
4×5.4
18
5×5.4
6.3×6.0
28
CE-PH
CE-LL
4×5.4
5×5.4
23
5×5.4
23
6.3×6.0
35
CE-PS
10
5×5.4
30
6.3×5.4
34
6.3×5.4
34
6.3×7.7
50
CE-PF
22
6.3×5.4
54
6.3×6.0
60
6.3×7.7
70
8×10.2
120
CE-TH
33
6.3×6.0
60
6.3×7.7
85
8×10.2
160
10×10.2
190
CE-JX
47
6.3×6.0
70
6.3×7.7
90
8×10.2
170
12.5×13.5
330
CE-NP
8×10.2
180
12.5×13.5
350
CE-FN
10×10.2
280
16×16.5
550
16×16.5
560
4.7
68
82
100
150
10×7.7
6.3×7.7
120
8×10.2
8×10.2
200
200
220
10×7.7
220
220
8×10.2
270
10×10.2
320
330
10×10.2
340
12.5×13.5
520
12.5×13.5
550
470
12.5×13.5
590
680
12.5×13.5
610
1000
16×16.5
1000
1500
16×16.5
1060
390
16×16.5
12.5×13.5
410
16×16.5
700
940
Please refer to page 14 for ripple current frequency coefficients.
■ Part number BS
Case size:φDxL(mm)
10×7.7:CE-BSA
16×16.5:CE-BST
BSA
16 CE 10 BS
10 CE 470 BSA
Series code
Rated capacitance
Type code
Rated voltage
Series code
Rated capacitance
Type code
Rated voltage
Rated ripple current
mArms(120Hz, 85℃)
BST
10 CE 4700 BS T
Sn plating terminal option
Series code
Rated capacitance
Type code
Rated voltage
43
很抱歉,暂时无法提供与“10CE100BS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.93809
- 50+0.75676
- 150+0.66604
- 1000+0.59800
- 2000+0.54357
- 5000+0.51635
