SMD Wire Wound Ceramic Chip Inductors - CS Series
CS Series
Due to technical expertise of accurately wounding skill, these chip
inductors are designed as filtering, impedance matching, resonance
and choke circuits for RF designer.
The stand series as well as
customer design to meet your needs of telecom & wireless products.
Features
Applications
RoHS Compliant
RF products for cellular phone, GPS receiver, Base Station, Repeater,
Ceramic body and wire wound construction provide high SRFs.
Wireless LAN/ Mouse/ Keyboard/ earphone, remote control, security
These ultra – compact inductors provided exceptional Q values,
system and other RF modules.
even at high frequencies.
Their ceramic construction delivers the highest possible SRFs as
well as excellent Q values.
The non-magnetic coil form also assures the utmost in thermal
stability, predictability and batch consistency.
CS series is standard parts for RF designers.
Product Identification
Shapes and Dimensions / Recommended Pattern
CS0402
CS0603/0805/1008
Dimensions
CS0402
CS0805
CS1008
CS0603
A Max
B Max
C Max
D
E
F
G
H
I
J
inch
0.047
0.028
0.026
0.010
0.020
0.009
0.022
0.026
0.014
0.018
mm
1.19
0.70
0.66
0.25
0.51
0.23
0.56
0.66
0.36
0.46
inch
0.093
0.068
0.06
0.028
0.050
0.020
0.040
0.070
0.040
0.030
mm
2.35
1.73
1.52
0.71
1.27
0.51
1.02
1.78
1.02
0.76
inch
0.115
0.110
0.083
0.046
0.080
0.020
0.060
0.100
0.040
0.050
mm
2.92
2.79
2.1
1.16
2.03
0.51
1.52
2.54
1.02
1.27
A
B
C
D
E
F
G
H
I
J
mm
+0.2
1.02±0.1
0.51
0.76
0.33
0.86
1.02
0.64
0.64
1.6
-0.1
0.82
+0.2
-0.1
Electrical Characteristics
Inductance
(nH)
Tolerance
Q
Min
L Typ
Q Typ
L Typ
Q Typ
SRF
(GHz) Min
Rdc
(Ω) Max
Irms
(mA) Max
CS0402-1N0□-S
1.0
10 / 5
16
1.02
77
1.02
69
12.70
0.045
1360
Part Number
900MHz
1.7GHz
CS0402-1N9□-S
1.9
10 / 5
16
1.72
68
1.74
82
11.30
0.070
1040
CS0402-2N0□-S
2.0
10 / 5
16
1.93
54
1.93
75
11.10
0.070
1040
CS0402-2N2□-S
2.2
10 / 5
19
2.19
59
2.23
100
10.80
0.070
960
790
CS0402-2N4□-S
2.4
10 / 5
15
2.24
51
2.27
68
10.50
0.068
CS0402-2N7□-S
2.7
10 / 5
16
2.58
42
2.60
61
10.40
0.120
640
CS0402-3N3□-S
3.3
10 / 5
19
3.10
65
3.12
87
7.00
0.066
840
CS0402-3N6□-S
3.6
10 / 5
19
3.56
45
3.62
71
6.80
0.066
840
CS0402-3N9□-S
3.9
10 / 5
19
3.89
50
4.00
75
6.00
0.066
840
CS0402-4N3□-S
4.3
10 / 5
18
4.19
47
4.30
71
6.00
0.091
700
640
CS0402-4N7□-S
4.7
10 / 5
15
4.55
48
4.68
68
4.77
0.130
CS0402-5N1□-S
5.1
10 / 5
56
5.25
82
4.80
0.083
800
CS0402-5N6□-S
5.6
10 / 5
54
5.28
81
4.80
0.083
760
CS0402-6N2□-S
6.2
10 / 5
52
6.37
76
4.80
0.083
760
CS0402-6N8□-S
6.8
10 / 5
63
6.93
78
4.80
0.083
680
CS0402-7N5□-S
7.5
10 / 5
22
7.91
60
8.22
88
4.80
0.10
680
CS0402-8N2□-S
8.2
10 / 5
22
8.50
57
8.85
84
4.40
0.10
680
CS0402-8N7□-S
8.7
10 / 5
18
8.78
54
9.21
73
4.10
0.20
480
CS0402-9N0□-S
9.0
10 / 5
22
9.07
62
9.53
78
4.16
0.10
680
CS0402-9N5□-S
9.5
10 / 5
18
9.42
54
9.98
69
4.00
0.20
480
CS0402-10N□-S
10
10 / 5
21
9.8
50
10.10
67
3.90
0.20
480
CS0402-11N□-S
11
10 / 5
24
10.7
52
11.20
78
3.68
0.12
640
CS0402-12N□-S
12
10 / 5
24
11.9
53
12.70
71
3.60
0.12
640
CS0402-13N□-S
13
10 / 5
24
13.4
51
14.63
57
3.45
0.21
440
CS0402-15N□-S
15
10 / 5
24
14.6
55
15.50
77
3.28
0.17
560
CS0402-16N□-S
16
10 / 5
24
16.6
46
18.86
47
3.10
0.22
560
CS0402-18N□-S
18
10 / 5
25
18.3
57
20.28
62
3.10
0.23
420
CS0402-19N□-S
19
10 / 5
24
19.1
50
21.10
67
3.04
0.20
480
CS0402-20N□-S
25
20.7
52
23.66
53
3.00
0.25
420
CS0402-22N□-S
22
10 / 5
25
23.2
53
26.75
53
2.80
0.30
400
CS0402-23N□-S
23
10 / 5
22
23.8
49
26.90
64
2.72
0.30
400
CS0402-24N□-S
24
10 / 5
25
25.1
51
29.50
50
2.70
0.30
400
CS0402-27N□-S
27
10 / 5
24
28.7
49
33.50
63
2.48
0.30
400
CS0402-30N□-S
30
10 / 5
25
31.1
46
38.50
39
2.35
0.35
400
CS0402-33N□-S
33
10 / 5
24
34.9
31
41.74
32
2.35
0.40
400
CS0402-36N□-S
36
10 / 5
24
39.5
44
48.40
53
2.32
0.44
320
CS0402-39N□-S
39
10 / 5
25
41.7
47
50.23
45
2.10
0.55
200
CS0402-40N□-S
40
10 / 5
24
39.0
44
47.40
33
2.24
0.65
320
CS0402-43N□-S
43
10 / 5
25
45.8
46
61.55
34
2.03
0.81
100
CS0402-47N□-S
47
10 / 5
38
2.10
0.83
150
CS0402-51N□-S
51
10 / 5
25
56.6
40
1.75
0.82
100
CS0402-56N□-S
56
10 / 5
22
62.8
42
1.76
0.97
100
100
CS0402-68N□-S
68
10 / 5
22
78.2
36
1.62
1.12
CS0402-82N□-S
82
10 / 5
1.55
50
CS0402-R10□-S
100
10 / 5
2.00
30
When ordering, please specify tolerance and packaging codes.
Tolerance : J = ±5% , K = ±10%
L , Q : Agilent/HP4291A+Agilent/HP16197A @250MHz
SRF : Agilent/HP8753D / Agilent/HP8722ES
Rdc : CH502BC/HP4338B
Irms for a 15℃ rise above 25℃ ambient.
SMD Wire Wound Ceramic Chip Inductors – CS Series
Part Number
Test
Inductance
Tolerance
Frequency
(nH)
(MHz)
Q
Min
SRF
(MHz) Min
Rdc
(Ω) Max
900 MHz
1.7 GHz
Irms
(mA) Max L Typ Q Typ L Typ Q Typ
Color
CS0603-1N6-S
1.6
250
10 / 5
24
12500
0.030
700
1.67
49
1.65
63
Red
CS0603-1N8-S
1.8
250
10 / 5
16
12500
0.045
700
1.63
35
1.66
50
Black
CS0603-3N6-S
3.6
250
10 / 5
22
5900
0.063
700
3.72
53
3.71
65
Red
CS0603-3N9-S
3.9
250
10 / 5
22
6900
0.080
700
3.95
49
3.96
67
Brown
CS0603-4N3-S
4.3
250
10 / 5
22
5900
0.063
700
4.32
50
4.33
70
Orange
CS0603-4N7-S
4.7
250
10 / 5
0.116
700
4.72
47
4.75
57
Violet
CS0603-5N1-S
5.1
250
10 / 5
0.140
700
4.93
47
4.95
56
Green
CS0603-5N6-S
5.6
250
10 / 5
0.170
700
5.53
56
5.86
77
Yellow
White
CS0603-6N3-S
6.3
250
10 / 5
0.140
700
5.50
47
6.10
60
CS0603-6N8-S
6.8
250
10 / 5
27
5800
0.110
700
6.75
60
7.10
81
Red
CS0603-7N5-S
7.5
250
10 / 5
28
4800
0.106
700
7.70
60
7.82
65
Brown
CS0603-8N2-S
8.2
250
10 / 5
28
4700
0.109
700
8.30
60
8.50
60
White
CS0603-8N7-S
8.7
250
10 / 5
28
4600
0.109
700
8.86
62
9.32
58
Yellow
CS0603-9N5-S
9.5
250
10 / 5
28
5400
0.135
700
9.70
59
9.92
61
Blue
CS0603-10N-S
10
250
10 / 5 / 2
31
4800
0.130
700
10.0
66
10.6
83
Orange
CS0603-11N-S
11
250
10 / 5 / 2
33
4000
0.086
700
11.0
53
11.5
56
Gray
CS0603-12N-S
12
250
10 / 5 / 2
35
4000
0.130
700
12.3
72
13.5
83
Yellow
CS0603-15N-S
15
250
10 / 5 / 2
35
4000
0.170
700
15.4
64
16.8
89
Green
CS0603-16N-S
16
250
10 / 5 / 2
34
3300
0.104
700
16.2
55
17.3
52
White
CS0603-18N-S
18
250
10 / 5 / 2
35
3100
0.170
700
18.7
70
21.4
69
Blue
CS0603-22N-S
22
250
10 / 5 / 2
38
3000
0.190
700
22.8
73
26.1
71
Violet
CS0603-24N-S
24
250
10 / 5 / 2
37
2650
0.135
700
24.5
45
28.7
39
Black
CS0603-27N-S
27
250
10 / 5 / 2
40
2800
0.220
600
29.2
74
34.6
65
Gray
CS0603-30N-S
30
250
10 / 5 / 2
37
2250
0.144
600
31.4
47
39.9
28
Brown
White
CS0603-33N-S
33
250
10 / 5 / 2
40
2300
0.220
600
36
67
49.5
42
CS0603-36N-S
36
250
10 / 5 / 2
38
2080
0.250
600
39.4
47
52.7
24
Red
CS0603-39N-S
39
250
10 / 5 / 2
40
2200
0.250
600
42.7
60
60.2
40
Black
CS0603-43N-S
43
250
10 / 5 / 2
39
2000
0.280
600
47
44
64.9
21
Orange
CS0603-47N-S
47
200
10 / 5 / 2
38
2000
0.280
600
52.2
62
77.2
35
Brown
CS0603-56N-S
56
200
10 / 5 / 2
38
1900
0.310
600
62.5
56
97
26
Red
CS0603-68N-S
68
200
10 / 5 / 2
37
1700
0.340
600
80.5
54
168
21
Orange
CS0603-72N-S
72
150
10 / 5 / 2
34
1700
0.490
400
82
53
135
Yellow
Green
CS0603-82N-S
82
150
10 / 5 / 2
34
1700
0.540
400
96.2
54
177
21
CS0603-R10-S
100
150
10 / 5 / 2
34
1400
0.580
400
124
49
Blue
CS0603-R11-S
110
150
10 / 5 / 2
32
1350
0.610
300
138
43
Violet
CS0603-R12-S
120
150
10 / 5 / 2
32
1300
0.750
300
166
39
Gray
CS0603-R15-S
150
150
10 / 5 / 2
28
990
0.920
280
250
25
White
CS0603-R18-S
180
100
10 / 5 / 2
25
990
1.250
240
305
22
Black
Brown
CS0603-R22-S
220
100
10 / 5 / 2
25
900
2.100
200
CS0603-R27-S
270
100
10 / 5 / 2
24
900
2.800
170
Red
CS0603-R33-S
330
100
10 / 5 / 2
25
900
3.890
100
Orange
CS0603-R39-S
390
100
10 / 5 / 2
25
900
4.350
100
Yellow
Tolerance : G = ±2% , J = ±5% , K = ±10%
Packaging: Clear tape and reel {standard}.
L /Q: Agilent/HP4291A+ Agilent/HP16197A
SRF: HP8753D/ HP4291A
RDC: CH502BC/HP4338B
Operating temperature range from -40℃ to 125℃. (Including self - temperature rise)
Part Number
Inductance
(nH)
Test
Frequency
(MHz)
Tolerance
Q
Min
Test
Frequency
(MHz)
SRF
Rdc
Irms
(MHz) Min
(Ω) Max
(mA) Max
Color
CS0805-2N8-S
2.8
250
10 / 5
80
1500
7900
0.06
800
Gray
CS0805-3N0-S
3.0
250
10 / 5
65
1500
7900
0.06
800
White
CS0805-3N3-S
3.3
250
10 / 5
50
1500
7900
0.08
600
Black
CS0805-5N6-S
5.6
250
10 / 5
65
1000
5500
0.08
600
Orange
CS0805-6N8-S
6.8
250
10 / 5
50
1000
5500
0.11
600
Brown
CS0805-7N5-S
7.5
250
10 / 5
50
1000
4500
0.14
600
Green
CS0805-8N2-S
8.2
250
10 / 5
50
1000
4700
0.12
600
Red
CS0805-10N-S
10
250
10 / 5 / 2
60
500
4200
0.10
600
Blue
CS0805-12N-S
12
250
10 / 5 / 2
50
500
4000
0.15
600
Orange
CS0805-15N-S
15
250
10 / 5 / 2
50
500
3400
0.17
600
Yellow
Green
CS0805-18N-S
18
250
10 / 5 / 2
50
500
3300
0.20
600
CS0805-22N-S
22
250
10 / 5 / 2
55
500
2600
0.22
500
Blue
CS0805-24N-S
24
250
10 / 5 / 2
50
500
2000
0.22
500
Gray
Violet
CS0805-27N-S
27
250
10 / 5 / 2
55
500
2500
0.25
500
CS0805-33N-S
33
250
10 / 5 / 2
60
500
2050
0.27
500
Gray
CS0805-36N-S
36
250
10 / 5 / 2
55
500
1700
0.27
500
Orange
CS0805-39N-S
39
250
10 / 5 / 2
60
500
2000
0.29
500
White
CS0805-43N-S
43
200
10 / 5 / 2
60
500
1650
0.34
500
Yellow
CS0805-47N-S
47
200
10 / 5 / 2
60
500
1650
0.31
500
Black
CS0805-56N-S
56
200
10 / 5 / 2
60
500
1550
0.34
500
Brown
CS0805-68N-S
68
200
10 / 5 / 2
60
500
1450
0.38
500
Red
CS0805-82N-S
82
150
10 / 5 / 2
65
500
1300
0.42
400
Orange
CS0805-91N-S
91
150
10 / 5 / 2
65
500
1200
0.48
400
Black
CS0805-R10-S
100
150
10 / 5 / 2
65
500
1200
0.46
400
Yellow
CS0805-R11-S
110
150
10 / 5 / 2
50
250
1000
0.48
400
Brown
CS0805-R12-S
120
150
10 / 5 / 2
50
250
1100
0.51
400
Green
CS0805-R15-S
150
100
10 / 5 / 2
50
250
920
0.56
400
Blue
CS0805-R18-S
180
100
10 / 5 / 2
50
250
870
0.64
400
Violet
CS0805-R20-S
200
100
10 / 5 / 2
50
250
860
0.68
400
Red
CS0805-R22-S
220
100
10 / 5 / 2
50
250
850
0.70
400
Gray
CS0805-R24-S
240
100
10 / 5 / 2
44
250
690
1.00
350
Red
CS0805-R25-S
250
100
10 / 5 / 2
45
250
660
1.20
350
Yellow
White
CS0805-R27-S
270
100
10 / 5 / 2
48
250
650
1.00
350
CS0805-R33-S
330
100
10 / 5 / 2
48
250
600
1.40
310
Black
CS0805-R39-S
390
100
10 / 5 / 2
48
250
560
1.50
290
Brown
CS0805-R47-S
470
50
10 / 5 / 2
33
100
375
1.76
250
Violet
CS0805-R56-S
560
25
10 / 5 / 2
23
50
340
1.90
230
Orange
CS0805-R62-S
620
25
10 / 5 / 2
23
50
220
2.20
210
Yellow
CS0805-R68-S
680
25
10 / 5 / 2
23
50
188
2.20
190
Green
CS0805-R82-S
820
25
10 / 5 / 2
23
50
215
2.35
180
Blue
CS0805-1R0-S
1000
25
10 / 5 / 2
100
2.50
170
Gray
CS0805-1R2-S
1200
7.9
10 / 5 / 2
18
25
100
2.50
170
White
L/Q: Agilent/HP4291A+Agilent/HP16197A
SRF: Agilent/HP8753D / Agilent/HP4291A
Part Number
CS1008-10N-S
CS1008-12N-S
Test
Tolerance
Inductance
Frequency
(nH)
(MHz)
10
12
50
50
10 / 5 / 2
10 / 5 / 2
Q
Min
50
50
Test
SRF
Frequency (MHz) Min
(MHz)
500
500
4100
3300
Color Coding
Rdc
(Ω) Max
Irms
(mA) Max
1
2ND
3RD
0.08
0.09
1000
1000
Brown
Brown
Black
Red
Black
Black
ST
CS1008-15N-S
15
50
10 / 5 / 2
50
500
2500
0.10
1000
Brown
Green
Black
CS1008-18N-S
18
50
10 / 5 / 2
50
350
2500
0.11
1000
Brown
Gray
Black
CS1008-22N-S
22
50
10 / 5 / 2
55
350
2400
0.12
1000
Red
Red
Black
CS1008-27N-S
27
50
10 / 5 / 2
55
350
1600
0.13
1000
Red
Violet
Black
CS1008-33N-S
33
50
10 / 5 / 2
60
350
1600
0.14
1000
Orange Orange
Black
CS1008-39N-S
39
50
10 / 5 / 2
60
350
1500
0.15
1000
Orange White
Black
CS1008-47N-S
47
50
10 / 5 / 2
65
350
1500
0.16
1000
Yellow
Violet
Black
CS1008-56N-S
56
50
10 / 5 / 2
65
350
1300
0.18
1000
Green
Blue
Black
CS1008-68N-S
68
50
10 / 5 / 2
65
350
1300
0.20
1000
Blue
Gray
Black
CS1008-82N-S
82
50
10 / 5 / 2
60
350
1000
0.22
1000
Gray
Red
Black
CS1008-R10-S
100
25
10 / 5 / 2
60
350
1000
0.56
650
Brown
Black
Brown
CS1008-R12-S
120
25
10 / 5 / 2
60
350
950
0.63
650
Brown
Red
Brown
CS1008-R15-S
150
25
10 / 5 / 2
45
100
850
0.70
580
Brown
Green
Brown
CS1008-R18-S
180
25
10 / 5 / 2
45
100
750
0.77
620
Brown
Gray
Brown
CS1008-R22-S
220
25
10 / 5 / 2
45
100
700
0.84
500
Red
Red
Brown
Red
Violet
Brown
CS1008-R27-S
270
25
10 / 5 / 2
45
100
600
0.91
500
CS1008-R33-S
330
25
10 / 5 / 2
45
100
570
1.05
450
Orange Orange Brown
CS1008-R39-S
390
25
10 / 5 / 2
45
100
500
1.12
470
Orange White
Brown
CS1008-R47-S
470
25
10 / 5 / 2
45
100
450
1.19
470
Yellow
Violet
Brown
CS1008-R56-S
560
25
10 / 5 / 2
45
100
415
1.33
400
Green
Blue
Brown
Brown
CS1008-R62-S
620
25
10 / 5 / 2
45
100
375
1.40
300
Blue
Red
CS1008-R68-S
680
25
10 / 5 / 2
45
100
375
1.47
400
Blue
Gray
Brown
CS1008-R75-S
750
25
10 / 5 / 2
45
100
360
1.54
360
Violet
Green
Brown
CS1008-R82-S
820
25
10 / 5 / 2
45
100
350
1.61
400
Gray
Red
Brown
CS1008-R91-S
910
25
10 / 5 / 2
35
50
320
1.68
380
White
Brown
Brown
CS1008-1R0-S
1000
25
10 / 5 / 2
35
50
290
1.75
370
Brown
Black
Red
Red
CS1008-1R2-S
1200
7.9
10 / 5 / 2
35
50
250
2.0
310
Brown
Red
CS1008-1R5-S
1500
7.9
10 / 5 / 2
28
50
200
2.3
330
Brown
Green
Red
CS1008-1R8-S
1800
7.9
10 / 5 / 2
28
50
160
2.6
300
Brown
Gray
Red
CS1008-2R2-S
2200
7.9
10 / 5 / 2
28
50
160
2.8
280
Red
Red
Red
CS1008-2R7-S
2700
7.9
10 / 5 / 2
22
25
140
3.2
290
Red
Violet
Red
CS1008-3R3-S
3300
7.9
10 / 5 / 2
22
25
110
3.4
290
Orange Orange
Red
CS1008-3R9-S
3900
7.9
10 / 5 / 2
100
3.6
260
Orange White
Red
CS1008-4R7-S
4700
7.9
10 / 5 / 2
90
4.0
260
Yellow
Violet
Red
CS1008-5R6-S
5600
7.9
10 / 5 / 2
18
7.9
45
4.0
240
Green
Blue
Red
CS1008-6R8-S
6800
7.9
10 / 5 / 2
18
7.9
40
4.9
200
Blue
Gray
Red
CS1008-8R2-S
8200
7.9
10 / 5 / 2
18
7.9
25
6.0
170
Gray
Red
Red
CS1008-100-S
10000
2.52
10 / 5 / 2
18
7.9
25
8.0
150
Brown
Black
Orange
L/Q: Agilent/HP4291A+ Agilent/HP16197A
Inductance would be correct Chilisin standard piece.
1st Code
3rd Code
2nd Code
COLOR CODING
Packaging Specifications
Tape Dimensions
Tape Dimensions
Figure 1
Figure 2
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Fig.
Reel Dimensions
Quantity
A
B
T
W
P
F
K
A
B
C
D
PCS / Reel
CS0402
1
0.75
1.23
0.53
8
2
3.5
178
60
12
1.5
4000
CS0603
1
1.16
1.85
0.95
8
4
3.5
178
60
12
1.5
4000
CS0805
2
1.85
2.45
0.23
8
4
3.5
1.45
178
60
12
1.5
2000
CS1008
2
2.80
2.95
0.23
8
4
3.5
2.20
178
60
12
1.5
2000
很抱歉,暂时无法提供与“CS0603-56NG-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34816
- 100+0.28139
- 300+0.24800
- 1000+0.22297
- 4000+0.18015
- 8000+0.17010
