MEK472M2H-E130
MEK472M2H-E130
    LELON(立隆电子)
    AEC_D90X130MM
    贴片铝电解电容 AEC_D90X130MM
MEK472M2H-E130 数据手册
Aluminum Electrolytic Capacitors MEK Features ‧Endurance with ripple current: 85℃, 5,000 hours ‧ RoHS Compliance Sleeve & Marking Color: Black & Golden SPECIFICATIONS Items Performance -40℃ ~ +85℃ Category Temperature Range (at 120Hz, 20℃) ±20% Capacitance Tolerance I = 3 CV or 5 (mA) whichever is smaller (after 5 minutes) Where, C= rated capacitance in µF. V = rated DC working voltage in V. Leakage Current (at 20℃) Dissipation Factor (Tanδat 120 Hz, 20℃) Low Temperature Characteristics (at 120Hz) See the Dimensions & Permissible Ripple Current Capacitance change : C(-25℃) / C(+20℃) ≧ 0.7 Test Time 5,000 Hrs Capacitance Change Within ±15% of initial value Dissipation Factor Less than 175% of specified value Endurance Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with rated ripple current applied for 5,000 hours at 85℃. Test Time 1,000 Hrs Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Shelf Life Test Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Ripple Current & Frequency Multipliers Frequency (Hz) 50 / 60 100 / 120 300 1k 10k up Multiplier 0.7 1.0 1.1 1.3 1.4 Ripple Current & Temperature Multipliers Temperature ( ℃) 40 60 85 Multiplier 1.89 1.67 1.0 DIAGRAM OF DIMENSIONS Insulation sleeve W2±2 W1±2 Hexagon-head bolt Screw terminal P ±1 φD+2 Max Vinyle Plate Vent c h H 2011 Version L+2 Max 10.0 Unit: mm 60° Mounting clamp a b P W1 W2 H h φD 51 22.0 61.0 65.5 21.0 15.0 64 28.6 72.5 78.0 25.0 20.0 77 32.0 85.5 91.0 35.0 20.0 90 32.0 101 106 34.5 20.0 Screw specifications: Plus hexagon-headed screw: M5×0.8×10 Max. screw tightening torque: 3.23Nm a 7.0 7.0 8.0 8.0 b 12.0 14.0 16.0 16.0 c 4.5 4.5 4.5 5.0 Aluminum Electrolytic Capacitors Dimension: φD× L(mm) Tanδ: 120 Hz, 20℃ Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC Item µF 350V (2V) Size Code φD×L 400V (2G) Tan δ Ripple Current 1,000 Size Code B075 φD×L Tan δ 51×75 450V (2W) 500V (2H) Size Code B075 φD×L Tan δ 0.15 Ripple Current 5.0 51×75 0.15 Ripple Current 5.0 1,200 B075 51×75 0.15 5.5 B075 51×75 0.15 5.5 B096 51×96 0.15 6.0 1,500 B075 51×75 0.15 6.1 B096 51×96 0.15 6.7 B115 51×115 0.15 7.2 1,800 2,200 B096 B096 51×96 51×96 0.15 0.15 7.4 8.2 B096 B130 51×96 51×130 0.15 0.15 7.4 9.2 B130 C096 51×130 64×96 0.15 0.15 8.3 9.0 2,700 3,300 B130 B130 51×130 51×130 0.15 0.15 10.2 11.3 C096 C115 64×96 64×115 0.15 0.15 9.9 11.8 C115 C130 64×115 64×130 0.15 0.15 10.7 12.4 64×130 64×155 77×115 64×195 77×130 77×155 90×157 0.15 0.15 0.15 0.15 0.15 0.15 0.15 13.5 15.9 14.9 19.1 17.0 20.2 23.5 D115 C195 D130 77×115 64×195 77×130 0.15 0.15 0.15 13.6 17.5 15.6 D155 77×155 0.15 18.3 E157 E157 90×157 90×157 0.15 0.15 21.4 23.5 3,900 C115 64×115 0.15 12.8 4,700 C130 64×130 0.15 14.8 6,800 8,200 C155 D115 D130 D155 64×155 77×115 77×130 77×155 0.15 0.15 0.15 0.15 17.3 16.3 18.8 22.1 C130 C155 D115 C195 D130 D155 E157 10,000 E157 90×157 0.15 25.9 E157 90×157 0.15 25.9 E196 90×196 0.15 28.3 12,000 E157 90×157 0.15 28.4 E196 90×196 0.15 31.0 E236 90×236 0.15 33.6 15,000 18,000 E196 E236 90×196 90×236 0.15 0.15 34.6 41.4 E236 90×236 0.15 37.5 5,600 V. DC MEK Size Code B096 B115 C096 B130 C096 C115 C130 φD×L Tan δ 51×96 51×115 64×96 51×130 64×96 64×115 64×130 0.20 D115 D130 D155 77×115 77×130 77×155 0.20 0.20 0.20 9.9 10.4 11.0 E130 90×130 0.20 13.5 E157 90×157 0.20 15.5 0.20 0.20 0.20 0.20 0.20 0.20 Ripple Current 5.5 6.6 6.9 7.8 7.7 8.6 9.4 525V (2Y) Size Ripple φD×L Tan δ µF Code Current 1,000 B115 51×115 0.20 6.7 B130 51×130 0.20 7.6 1,200 C096 64×96 0.20 7.5 1,500 C115 64×115 0.20 8.4 1,800 C130 64×130 0.20 9.1 2,200 D115 77×115 0.20 9.9 2,700 D130 77×130 0.20 10.5 3,300 D155 77×155 0.20 11.2 3,900 E157 90×157 0.20 12.1 *Special requirements are available upon request. Item Case Code φD L 75 96 115 130 155 157 170 171 195 196 236 Unit: mm 51 64 77 90 B075 B096 B115 B130 - C096 C115 C130 C155 - D115 D130 D155 D170 E157 C195 D195 E171 E196 E236 Part numbering system ±20% 350V 332 M 2V Capacitance Capacitance tolerance MEK series 3300µF MEK Series name Example: Cap. Symbol 470 471 1,800 182 10,000 103 M = ±20% K = ±10% Rated voltage Plain case + M5 Post Mounting clamp 51φ×130L - - B130 Case Type Terminal type Case size Example: WV Symbol 350 2V 400 2G 450 2W Example: φD×L 51×130 64×130 90×157 Pb-free Terminal + PVC Sleeve Terminal and Sleeve Type Code B130 C130 E157 For more details, please refer to “Product Code Guide– Screw Type” on page 16. 2011 Verison
MEK472M2H-E130 价格&库存
很抱歉,暂时无法提供与“MEK472M2H-E130”相匹配的价格&库存,您可以联系我们找货
