MEA123M2W-E220
MEA123M2W-E220
    LELON(立隆电子)
    AEC_D90X220MM
    贴片铝电解电容 AEC_D90X220MM
MEA123M2W-E220 数据手册
Aluminum Electrolytic Capacitors MEA Features ‧Endurance with ripple current: 85℃, 2,000 hours ‧ RoHS Compliance Sleeve & Marking Color: Black & White SPECIFICATIONS Items Category Temperature Range Performance -40℃ ~ +85℃ -25℃ ~ +85℃ 10 ~ 100V 160 ~ 450V ±20% Capacitance Tolerance Leakage Current (at 20℃) Dissipation Factor (Tanδat 120 Hz, 20℃) Low Temperature Characteristics (at 120Hz) Endurance (at 120Hz, 20℃) I = 3 CV or 5 (mA) whichever is smaller (after 5 minutes) V = rated DC working voltage in V Where, C= rated capacitance in µF See the Dimensions & Permissible Ripple Current Capacitance change : C(-25℃) / C(+20℃) ≧ 0.7 Test Time 2,000 Hrs Capacitance Change Within ±15% of initial value Dissipation Factor Less than 175% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with rated ripple current applied for 2,000 hours at 85℃. Shelf Life Test Test Time 500 Hrs Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 85℃ without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Ripple Current & Frequency Multipliers Ripple Current & Temperature Multipliers 2011 Version Frequency (Hz) 50 / 60 100 / 120 300 1k 10k up Multiplier 0.7 1.0 1.1 1.3 1.4 Temperature ( ℃) 40 60 70 85 Multiplier 2.7 2.0 1.7 1.0 Aluminum Electrolytic Capacitors MEA DIAGRAM OF DIMENSIONS 1. 35φ Unit: mm 58±1 48±1 Insulation Hexagon-head bolt sleeve Screw terminal 12.7±1 φ35+2 Max 30° Vinyle Plate 10 4 Mounting clamp 6 10 15 Vent 10.0 Screw specifications: Plus hexagon-headed screw: M5×0.8×10 Max. screw tightening torque: 3.23Nm L+2 Max 2. 51 ~ 90φ Insulation sleeve W2±2 W1±2 Hexagon-head bolt Screw terminal P±1 φD+2 Max Vinyle Plate Vent c h φD 51 64 77 90 H 10.0 L+2 Max P 22.0 28.6 32.0 32.0 10V (1A) b 12.0 14.0 16.0 16.0 c 4.5 4.5 4.5 5.0 a Dimension: φD×L(mm) Tanδ: 120 Hz, 20℃ Ripple Current: A/rms at 120 Hz, 85℃ 16V (1C) 25V (1E) 10,000 35×53 0.30 Ripple Current 3.5 12,000 A053 35×53 0.30 3.7 15,000 A065 35×65 0.30 3.9 φD×L Tan δ Ripple Current Size Code 35V (1V) Tan δ µF Tan δ Size Code a 7.0 7.0 8.0 8.0 φD×L φD×L Ripple Current h 15.0 20.0 20.0 20.0 Size Code A053 Item Size Code H 21.0 25.0 35.0 34.5 b DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC W1 W2 61.0 65.5 72.5 78.0 85.5 91.0 101 106 60° Mounting clamp φD×L Tan δ Ripple Current 18,000 A053 35×53 0.35 4.0 A065 35×65 0.35 4.2 22,000 A065 35×65 0.35 4.5 A083 35×83 0.35 4.9 27,000 A053 35×53 0.45 4.2 A065 35×65 0.40 5.0 A083 35×83 0.40 5.2 33,000 A053 35×53 0.60 4.4 A065 35×65 0.50 5.5 A083 35×83 0.40 5.5 A121 35×121 0.40 7.1 39,000 A053 35×53 0.60 4.7 A065 35×65 0.50 5.8 A083 35×83 0.40 6.2 A121 35×121 0.40 7.3 47,000 A065 35×65 0.60 5.6 A083 35×83 0.55 7.2 A121 35×121 0.40 7.4 B083 51×83 0.45 8.3 56,000 A065 35×65 0.60 5.9 A083 35×83 0.60 7.5 A121 35×121 0.45 8.3 B083 51×83 0.50 8.7 68,000 A083 35×83 0.60 7.5 A121 35×121 0.60 10.2 B100 51×100 0.50 9.3 B100 51×100 0.50 10.2 82,000 A083 35×83 0.60 7.7 A121 35×121 0.70 10.4 B121 51×121 0.50 9.7 B100 51×100 0.55 10.5 100,000 A121 35×121 0.70 9.2 B083 51×83 0.70 10.9 B121 51×121 0.60 10.5 C100 64×100 0.60 10.9 120,000 A121 35×121 0.70 9.4 B083 51×83 0.80 11.3 B121 51×121 0.60 11.5 C121 64×121 0.60 12.8 150,000 B083 51×83 0.90 10.2 B121 51×121 0.90 12.6 C100 64×100 0.70 12.9 C144 64×144 0.70 15.3 180,000 B083 51×83 0.90 10.7 B121 51×121 0.90 13.0 C121 64×121 0.75 14.7 C144 64×144 0.70 15.8 220,000 B121 51×121 1.00 13.9 C100 64×100 1.00 14.7 C144 64×144 0.80 18.0 D144 77×144 0.75 17.3 270,000 B121 51×121 1.20 15.2 C100 64×100 1.20 15.3 C144 64×144 0.90 18.3 330,000 C121 64×121 1.40 17.2 D121 77×121 1.30 18.2 D144 77×144 1.00 19.5 390,000 C121 64×121 1.50 18.1 D121 77×121 1.60 18.6 D144 77×144 1.20 20.8 470,000 D121 77×121 2.00 19.2 D121 77×121 1.80 19.3 560,000 D121 77×121 2.50 19.8 D144 77×144 2.00 20.7 680,000 D121 77×121 3.00 21.0 2011 Verison Aluminum Electrolytic Capacitors Dimension: φD×L(mm) Tanδ: 120 Hz, 20℃ Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 50V (1H) 63V (1J) Tan δ 2,200 35×53 0.15 Ripple Current 2.5 2,700 A053 35×53 φD×L Tan δ Size Code φD×L Tan δ Ripple Current Size Code 100V (2A) φD×L µF Ripple Current 80V (1K) Size Code A053 Item Size Code MEA φD×L Tan δ Ripple Current 0.15 2.5 3,300 A053 35×53 0.15 2.5 A065 35×65 0.15 2.9 3,900 A053 35×53 0.15 2.7 A083 35×83 0.15 3.5 4,700 A065 35×65 0.15 2.9 A083 35×83 0.15 3.7 5,600 A053 35×53 0.20 3.0 A065 35×65 0.20 3.7 A100 35×100 0.15 4.6 6,800 A053 35×53 0.25 3.2 A053 35×53 0.20 3.7 A083 35×83 0.20 4.3 A100 35×100 0.20 4.9 8,200 A053 35×53 0.25 3.4 A065 35×65 0.25 4.4 A083 35×83 0.20 4.5 B083 51×83 0.20 5.8 10,000 A065 35×65 0.25 4.3 A083 35×83 0.25 4.5 A100 35×100 0.20 5.4 B083 51×83 0.20 6.2 12,000 A065 35×65 0.25 4.5 A083 35×83 0.25 4.7 A100 35×100 0.20 5.6 B100 51×100 0.20 7.5 15,000 A083 35×83 0.25 4.7 A100 35×100 0.25 5.6 B083 51×83 0.25 7.3 B121 51×121 0.20 8.5 18,000 A083 35×83 0.25 4.9 A100 35×100 0.25 6.2 B083 51×83 0.25 7.7 C100 64×100 0.20 8.8 22,000 A121 35×121 0.30 6.3 B083 51×83 0.30 7.7 B100 51×100 0.30 8.5 C100 64×100 0.25 9.6 27,000 A121 35×121 0.35 6.6 B083 51×83 0.30 8.2 C100 64×100 0.30 8.6 C121 64×121 0.25 10.3 33,000 B083 51×83 0.40 7.5 B100 51×100 0.35 8.7 C100 64×100 0.35 10.5 C144 64×144 0.25 12.1 39,000 B083 51×83 0.40 7.7 B100 51×100 0.35 9.6 C121 64×121 0.35 11.8 D144 77×144 0.25 12.4 47,000 B100 51×100 0.40 9.6 C100 64×100 0.40 11.5 C144 64×144 0.35 14.0 D144 77×144 0.25 13.9 56,000 B100 51×100 0.40 9.8 C100 64×100 0.40 11.8 C144 64×144 0.35 14.2 D144 77×144 0.30 15.3 68,000 C100 64×100 0.45 11.9 C144 64×144 0.40 13.7 D144 77×144 0.35 16.7 D144 77×144 0.35 17.1 82,000 C100 64×100 0.50 12.2 C144 64×144 0.45 14.2 100,000 C144 64×144 0.50 14.2 D144 77×144 0.45 15.2 120,000 C144 64×144 0.50 14.5 D144 77×144 0.50 15.8 150,000 D144 77×144 0.60 16.5 180,000 D144 77×144 0.70 16.8 V. DC 160V (2C) Size Code 390 35×53 0.15 Ripple Current 1.6 470 A065 35×65 0.15 2.1 560 A083 35×83 0.15 2.3 680 A083 35×83 0.15 2.6 820 A100 35×100 0.15 3.0 1,000 A100 35×100 0.15 3.4 1,200 B075 51×75 0.15 3.8 φD×L Tan δ Ripple Current Size Code 350V (2V) Tan δ φD×L Tan δ Ripple Current 250V (2E) φD×L µF Size Code 200V (2D) Size Code A053 Item φD×L Tan δ Ripple Current 1,500 A100 35×100 0.15 3.2 B075 51×75 0.15 4.2 1,800 A100 35×100 0.15 3.5 B096 51×96 0.15 5.1 2,200 A100 35×100 0.15 3.9 B075 51×75 0.15 4.0 B096 51×96 0.15 5.7 2,700 A121 35×121 0.15 4.7 B075 51×75 0.15 4.4 B130 51×130 0.15 7.1 7.9 3,300 A121 35×121 0.15 5.2 B075 51×75 0.15 4.9 B096 51×96 0.15 5.4 C115 64×115 0.15 3,900 B075 51×75 0.15 5.3 B075 51×75 0.15 5.3 B115 51×115 0.15 6.3 C115 64×115 0.15 8.9 4,700 B075 51×75 0.15 5.8 B096 51×96 0.15 6.4 C096 64×96 0.15 7.1 C130 64×130 0.15 10.3 5,600 B096 51×96 0.15 7.0 B115 51×115 0.15 7.5 C096 64×96 0.15 7.7 D115 77×115 0.15 11.3 6,800 B096 51×96 0.15 7.7 B130 51×130 0.15 8.7 C115 64×115 0.15 9.1 D130 77×130 0.15 13.1 8,200 B115 51×115 0.15 9.1 C096 64×96 0.15 9.4 C115 64×115 0.15 10.0 D155 77×155 0.15 15.4 10,000 C096 64×96 0.15 10.3 C096 64×96 0.15 10.3 C130 64×130 0.15 11.6 E157 90×157 0.15 18.1 12,000 C096 64×96 0.15 11.3 D096 77×96 0.15 12.0 D115 77×115 0.15 12.8 E157 90×157 0.15 20.0 15,000 C130 64×130 0.15 14.3 D096 77×96 0.15 14.4 D130 77×130 0.15 15.1 E196 90×196 0.15 24.4 18,000 C130 64×130 0.15 15.6 D130 77×130 0.15 16.5 D155 77×155 0.15 17.7 E236 90×236 0.15 28.8 22,000 D130 77×130 0.15 18.2 D155 77×155 0.15 19.6 E157 90×157 0.15 20.9 27,000 D130 77×130 0.15 20.2 E130 90×130 0.15 21.5 33,000 E130 90×130 0.15 23.7 E157 90×157 0.15 25.5 39,000 E157 90×157 0.15 27.8 2011 Version Aluminum Electrolytic Capacitors Dimension: φD×L(mm) Tanδ: 120 Hz, 20℃ Ripple Current: A/rms at 120 Hz, 85℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 400V (2G) Size Code φD×L 330 A053 390 450V (2W) Tan δ Ripple Current Size Code A053 φD×L Tan δ 35×53 0.15 Ripple Current 1.3 35×53 0.15 1.5 A065 35×65 0.15 1.8 A065 35×65 0.15 2.0 A083 35×83 0.15 2.0 470 A083 35×83 0.15 2.1 A083 35×83 0.15 2.1 560 A083 35×83 0.15 2.3 A100 35×100 0.15 2.5 680 A100 35×100 0.15 2.8 A100 35×100 0.15 2.8 820 A100 35×100 0.15 3.1 B075 51×75 0.15 3.2 1,000 B075 51×75 0.15 3.5 B075 51×75 0.15 3.5 1,200 B075 51×75 0.15 3.8 B096 51×96 0.15 4.2 1,500 B096 51×96 0.15 4.7 B115 51×115 0.15 5.0 1,800 B096 51×96 0.15 5.1 B130 51×130 0.15 5.8 2,200 B130 51×130 0.15 6.4 C096 64×96 0.15 6.3 2,700 C096 64×96 0.15 6.9 C115 64×115 0.15 7.5 3,300 C115 64×115 0.15 8.2 C130 64×130 0.15 8.6 3,900 C130 64×130 0.15 9.4 D115 77×115 0.15 9.5 4,700 D115 77×115 0.15 10.4 D130 77×130 0.15 10.8 5,600 D130 77×130 0.15 11.9 D155 77×155 0.15 12.8 6,800 E157 90×157 0.15 14.0 E157 90×157 0.15 15.0 8,200 E157 90×157 0.15 16.4 E157 90×157 0.15 16.4 10,000 E157 90×157 0.15 18.2 E196 90×196 0.15 19.9 12,000 E196 90×196 0.15 21.8 E236 90×236 0.15 23.6 Item µF MEA 270 15,000 E236 90×236 0.15 26.3 *Special requirements are available upon request. Case Code φD Unit: mm 35 51 64 77 90 53 A053 - - - - 65 A065 - - - - 75 A075 B075 - - - 83 A083 B083 - - - 96 - B096 C096 D096 - 100 A100 B100 C100 - - L 115 - B115 C115 D115 121 A121 B121 C121 D121 - 130 - B130 C130 D130 E130 144 - - C144 D144 - 155 - - - D155 - 157 - - - - E157 196 - - - - E196 236 - - - - E236 Part numbering system ±20% 400V 332 M 2G Capacitance Capacitance tolerance MEA series 3300µF MEA Series name Example: Cap. Symbol 470 471 1,800 182 10,000 103 M = ±20% K = ±10% Rated voltage Plain case + M5 Post Mounting clamp 64φ×115L - - C115 Case Type Terminal type Case size Example: WV Symbol 350 2V 400 2G 450 2W Example: φD×L 35×83 51×96 90×157 Pb-free Terminal + PVC Sleeve Terminal and Sleeve Type Code A083 B096 E157 Note: For more details, please refer to “Product Code Guide– Screw Type” on page 16. 2011 Verison
MEA123M2W-E220 价格&库存
很抱歉,暂时无法提供与“MEA123M2W-E220”相匹配的价格&库存,您可以联系我们找货
