C82222J3DD2R8LC
C82222J3DD2R8LC
    SRD(圣融达)
    插件,P=15mm
    薄膜电容 径向
C82222J3DD2R8LC 数据手册
盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 引用标准 Reference standards GB10190(IEC384-16) ■ 结构 Structure 介质:聚丙烯膜 电极:双面金属化聚酯膜 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: polypropylene film Electrode:double side metallized polyester film Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0 Box: Flame retardant PBT plastic shell, conforming to UL94 V-0 ■ 典型应用 Typical Application 广泛应用于高压高频脉冲电路中 适用于变频器的谐振电路中 适用于 LED 驱动和开关电源高效电路 吸收和 SCR 整流电路中 ■ Widely used in high voltage high frequency pulse circuit. Applicable for resonant circuit of frequency converter. Suitable for LED driver and switching power supply high efficiency circuit Snubber circuit and SCR rectifying circuit 特点 Features 损耗小,内部温升小, 小型化的安装尺寸,优异的阻燃性能(UL94V-0) Low loss and low internal temperature rise, small mounting size, Excellent flame resistance property. ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category 40/105/56 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.25% per ℃ for R.V(DC) (+85℃~+105℃): 额定电压降额使用系数 1.25% per ℃ for R.V(DC) 额定电压 Rated Voltage 630VDC, 1000VDC,1600VDC,2000VDC,3000VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.001μF~1.2μF Capacitance Range 测试条件 Test Condition: 耐电压 1.6UR,5S Withstand Voltage 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.33μF IR≥100000MΩ Insulation Resistance CR>0.33μF IR≥30000S 最大脉冲爬升速率 Max. Pulse Rise Time (dV / dt) (1KHZ ) 20℃, 1KHz, 1Vrms 无击穿或飞弧 No breakdown or electric arcing 测试条件 Test Condition : 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min UR(V) P15 P22.5 P27.5 630V 2500 1600 1000 1000V 3500 2500 1300 1600V 6300 3200 2200 2000V 10000 5000 2500 3000V 10000 8000 --- 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0015(10KHz) dissipation factor rise:≤0.0015(10KHz) 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% ■ 产品编码说明 Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 11 C 4 Digit 1-3 8 2 1 0 4 J 型号代码 Product Name Code 2 J E 12 R 13 14 15 8 * * C82= MMKP82 series Digit 4-6 标称容量 Rated Capacitance Value For example : 104 = 10×104pF = 0.1F Digit 7 容量偏差 Capacitance Tolerance J=±5% Digit 8-9 额定电压 Rated Voltage Code 2J=630V 3A=1000V 3C=1600V 3D=2000V 3E=3000V Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :630Vdc(400Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 C82183J2JD2R8** MMKP82 0.018 18 6 12 15 0.8 C82223J2JD2R8** MMKP82 0.022 18 6 12 15 0.8 C82273J2JD2R8** MMKP82 0.027 18 6 12 15 0.8 C82333J2JD2R8** MMKP82 0.033 18 6 12 15 0.8 C82393J2JD2R8** MMKP82 0.039 18 6 12 15 0.8 C82473J2JD2R8** MMKP82 0.047 18 6 12 15 0.8 C82563J2JD3R8** MMKP82 0.056 18 7.5 13.5 15 0.8 C82683J2JD4R8** MMKP82 0.068 18 8.4 14.5 15 0.8 C82823J2JD4R8** MMKP82 0.082 18 8.4 14.5 15 0.8 C82104J2JD6R8** MMKP82 0.1 18 10 15.8 15 0.8 C82124J2JD8R8** MMKP82 0.12 18 11.2 19.2 15 0.8 C82473J2JE1R8** MMKP82 0.047 26.5 6 15 22.5 0.8 C82563J2JE1R8** MMKP82 0.056 26.5 6 15 22.5 0.8 C82683J2JE1R8** MMKP82 0.068 26.5 6 15 22.5 0.8 C82823J2JE1R8** MMKP82 0.082 26.5 6 15 22.5 0.8 C82104J2JE1R8** MMKP82 0.1 26.5 6 15 22.5 0.8 C82124J2JE2R8** MMKP82 0.12 26.5 7 16.5 22.5 0.8 C82154J2JE3R8** MMKP82 0.15 26.5 8.5 17 22.5 0.8 C82184J2JE3R8** MMKP82 0.18 26.5 8.5 17 22.5 0.8 C82224J2JE4R8** MMKP82 0.22 26.5 10 19 22.5 0.8 C82274J2JE5R8** MMKP82 0.27 26.5 11 20 22.5 0.8 C82334J2JE6R8** MMKP82 0.33 26.5 12 21.5 22.5 0.8 C82394J2JE6R8** MMKP82 0.39 26.5 12 21.5 22.5 0.8 C82334J2JF1R8** MMKP82 0.33 31.5 10.8 19.5 27.5 0.8 C82394J2JF1R8** MMKP82 0.39 31.5 10.8 19.5 27.5 0.8 C82474J2JF2R8** MMKP82 0.47 31.5 13 21.6 27.5 0.8 C82564J2JF2R8** MMKP82 0.56 31.5 13 21.6 27.5 0.8 C82684J2JF3R8** MMKP82 0.68 31 14 25 27.5 0.8 C82824J2JF4R8** MMKP82 0.82 31.5 16 25.5 27.5 0.8 C82105J2JF5R8** MMKP82 1 31.5 16 30 27.5 0.8 C82125J2JF5R8** MMKP82 1.2 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc(600Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82102J3AC2R6** MMKP82 0.001 13 5 11 10 0.6 C82122J3AC2R6** MMKP82 0.0012 13 5 11 10 0.6 C82152J3AC2R6** MMKP82 0.0015 13 5 11 10 0.6 C82182J3AC2R6** MMKP82 0.0018 13 5 11 10 0.6 C82222J3AC2R6** MMKP82 0.0022 13 5 11 10 0.6 C82272J3AC2R6** MMKP82 0.0027 13 5 11 10 0.6 C82332J3AC2R6** MMKP82 0.0033 13 5 11 10 0.6 C82392J3AC2R6** MMKP82 0.0039 13 5 11 10 0.6 C82472J3AC2R6** MMKP82 0.0047 13 5 11 10 0.6 C82562J3AC2R6** MMKP82 0.0056 13 5 11 10 0.6 C82682J3AC2R6** MMKP82 0.0068 13 5 11 10 0.6 C82822J3AC2R6** MMKP82 0.0082 13 5 11 10 0.6 C82103J3AC2R6** MMKP82 0.01 13 5 11 10 0.6 C82822J3AD2R8** MMKP82 0.0082 18 6 12 15 0.8 C82103J3AD2R8** MMKP82 0.01 18 6 12 15 0.8 C82123J3AD2R8** MMKP82 0.012 18 6 12 15 0.8 C82153J3AD2R8** MMKP82 0.015 18 6 12 15 0.8 C82183J3AD3R8** MMKP82 0.018 18 7.5 13.5 15 0.8 C82223J3AD3R8** MMKP82 0.022 18 7.5 13.5 15 0.8 C82273J3AD4R8** MMKP82 0.027 18 8.4 14.5 15 0.8 C82333J3AD4R8** MMKP82 0.033 18 8.4 14.5 15 0.8 C82393J3AD6R8** MMKP82 0.039 18 10 15.8 15 0.8 C82473J3AD8R8** MMKP82 0.047 18 11.2 19.2 15 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc(600Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82273J3AE1R8** MMKP82 0.027 26.5 6 15 22.5 0.8 C82333J3AE1R8** MMKP82 0.033 26.5 6 15 22.5 0.8 C82393J3AE1R8** MMKP82 0.039 26.5 6 15 22.5 0.8 C82473J3AE2R8** MMKP82 0.047 26.5 7 16.5 22.5 0.8 C82563J3AE2R8** MMKP82 0.056 26.5 7 16.5 22.5 0.8 C82683J3AE3R8** MMKP82 0.068 26.5 8.5 17 22.5 0.8 C82823J3AE4R8** MMKP82 0.082 26.5 10 19 22.5 0.8 C82104J3AE4R8** MMKP82 0.1 26.5 10 19 22.5 0.8 C82124J3AE5R8** MMKP82 0.12 26.5 11 20 22.5 0.8 C82154J3AE6R8** MMKP82 0.15 26.5 12 21.5 22.5 0.8 C82104J3AF1R8** MMKP82 0.1 31.5 10.8 19.5 27.5 0.8 C82124J3AF1R8** MMKP82 0.12 31.5 10.8 19.5 27.5 0.8 C82154J3AF1R8** MMKP82 0.15 31.5 10.8 19.5 27.5 0.8 C82184J3AF2R8** MMKP82 0.18 31.5 13 21.6 27.5 0.8 C82224J3AF2R8** MMKP82 0.22 31.5 13 21.6 27.5 0.8 C82274J3AF3R8** MMKP82 0.27 31 14 25 27.5 0.8 C82334J3AF4R8** MMKP82 0.33 31.5 16 25.5 27.5 0.8 C82394J3AF5R8** MMKP82 0.39 31.5 16 30 27.5 0.8 C82474J3AF9R8** MMKP82 0.47 31.5 18 28 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :1600Vdc(650Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82332J3CD2R8** MMKP82 0.0033 18 6 12 15 0.8 C82472J3CD2R8** MMKP82 0.0047 18 6 12 15 0.8 C82562J3CD2R8** MMKP82 0.0056 18 6 12 15 0.8 C82682J3CD2R8** MMKP82 0.0068 18 6 12 15 0.8 C82822J3CD2R8** MMKP82 0.0082 18 6 12 15 0.8 C82103J3CD2R8** MMKP82 0.01 18 6 12 15 0.8 C82123J3CD3R8** MMKP82 0.012 18 7.5 13.5 15 0.8 C82153J3CD3R8** MMKP82 0.015 18 7.5 13.5 15 0.8 C82183J3CD4R8** MMKP82 0.018 18 8.4 14.5 15 0.8 C82223J3CD4R8** MMKP82 0.022 18 8.4 14.5 15 0.8 C82273J3CD6R8** MMKP82 0.027 18 10 15.8 15 0.8 C82333J3CD8R8** MMKP82 0.033 18 11.2 19.2 15 0.8 C82153J3CE1R8** MMKP82 0.015 26.5 6 15 22.5 0.8 C82183J3CE1R8** MMKP82 0.018 26.5 6 15 22.5 0.8 C82223J3CE1R8** MMKP82 0.022 26.5 6 15 22.5 0.8 C82273J3CE2R8** MMKP82 0.027 26.5 7 16.5 22.5 0.8 C82333J3CE2R8** MMKP82 0.033 26.5 7 16.5 22.5 0.8 C82393J3CE3R8** MMKP82 0.039 26.5 8.5 17 22.5 0.8 C82473J3CE4R8** MMKP82 0.047 26.5 10 19 22.5 0.8 C82563J3CE4R8** MMKP82 0.056 26.5 10 19 22.5 0.8 C82683J3CE5R8** MMKP82 0.068 26.5 11 20 22.5 0.8 C82823J3CE6R8** MMKP82 0.082 26.5 12 21.5 22.5 0.8 C82823J3CF1R8** MMKP82 0.082 31.5 10.8 19.5 27.5 0.8 C82104J3CF1R8** MMKP82 0.1 31.5 10.8 19.5 27.5 0.8 C82124J3CF2R8** MMKP82 0.12 31.5 13 21.6 27.5 0.8 C82154J3CF3R8** MMKP82 0.15 31 14 25 27.5 0.8 C82184J3CF3R8** MMKP82 0.18 31 14 25 27.5 0.8 C82224J3CF5R8** MMKP82 0.22 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series 料号明细及尺寸 Part No. List and Dimensions UR :2000Vdc(700Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82102J3DD2R8** MMKP82 0.001 18 6 12 15 0.8 C82122J3DD2R8** MMKP82 0.0012 18 6 12 15 0.8 C82152J3DD2R8** MMKP82 0.0015 18 6 12 15 0.8 C82182J3DD2R8** MMKP82 0.0018 18 6 12 15 0.8 C82222J3DD2R8** MMKP82 0.0022 18 6 12 15 0.8 C82272J3DD2R8** MMKP82 0.0027 18 6 12 15 0.8 C82332J3DD2R8** MMKP82 0.0033 18 6 12 15 0.8 C82392J3DD2R8** MMKP82 0.0039 18 6 12 15 0.8 C82472J3DD2R8** MMKP82 0.0047 18 6 12 15 0.8 C82562J3DD3R8** MMKP82 0.0056 18 7.5 13.5 15 0.8 C82682J3DD3R8** MMKP82 0.0068 18 7.5 13.5 15 0.8 C82822J3DD4R8** MMKP82 0.0082 18 8.4 14.5 15 0.8 C82103J3DD6R8** MMKP82 0.01 18 10 15.8 15 0.8 C82123J3DD6J8** MMKP82 0.012 18 10 15.8 15 0.8 C82153J3DD8R8** MMKP82 0.015 18 11.2 19.2 15 0.8 C82103J3DE1R8** MMKP82 0.01 26.5 6 15 22.5 0.8 C82123J3DE1R8** MMKP82 0.012 26.5 6 15 22.5 0.8 C82153J3DE2R8** MMKP82 0.015 26.5 7 16.5 22.5 0.8 C82183J3DE2R8** MMKP82 0.018 26.5 7 16.5 22.5 0.8 C82223J3DE3R8** MMKP82 0.022 26.5 8.5 17 22.5 0.8 C82273J3DE4R8** MMKP82 0.027 26.5 10 19 22.5 0.8 C82333J3DE4R8** MMKP82 0.033 26.5 10 19 22.5 0.8 C82393J3DE5R8** MMKP82 0.039 26.5 11 20 22.5 0.8 C82473J3DE6R8** MMKP82 0.047 26.5 12 21.5 22.5 0.8 C82393J3DF1R8** MMKP82 0.039 31.5 10.8 19.5 27.5 0.8 C82473J3DF1R8** MMKP82 0.047 31.5 10.8 19.5 27.5 0.8 C82563J3DF2R8** MMKP82 0.056 31.5 13 21.6 27.5 0.8 C82683J3DF2R8** MMKP82 0.068 31.5 13 21.6 27.5 0.8 C82823J3DF3R8** MMKP82 0.082 31 14 25 27.5 0.8 C82104J3DF4R8** MMKP82 0.1 31.5 16 25.5 27.5 0.8 C82124J3DF4R8** MMKP82 0.12 31.5 16 25.5 27.5 0.8 C82154J3DF5R8** MMKP82 0.15 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. 盒装型双面金属化聚丙烯膜电容器---MMKP82(C82)系列 Double sided metallized polypropylene film capacitor(Box )---MMKP82(C82)series ■ 料号明细及尺寸 Part No. List and Dimensions UR 3000Vdc(750Vac) 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) W±0.5 T±0.5 H±0.5 P±0.5 d±0.05 C82102J3ED2R8** MMKP82 0.001 18.0 6.0 12.0 15.0 0.8 C82122J3ED2R8** MMKP82 0.0012 18.0 6.0 12.0 15.0 0.8 C82152J3ED2R8** MMKP82 0.0015 18.0 6.0 12.0 15.0 0.8 C82182J3ED2R8** MMKP82 0.0018 18.0 6.0 12.0 15.0 0.8 C82222J3ED2R8** MMKP82 0.0022 18.0 6.0 12.0 15.0 0.8 C82272J3ED2R8** MMKP82 0.0027 18.0 6.0 12.0 15.0 0.8 C82332J3ED3R8** MMKP82 0.0033 18.0 7.5 13.5 15.0 0.8 C82392J3ED3R8** MMKP82 0.0039 18.0 7.5 13.5 15.0 0.8 C82472J3ED4R8** MMKP82 0.0047 18.0 8.4 14.5 15.0 0.8 C82562J3ED5R8** MMKP82 0.0056 18.0 9.5 15.5 15.0 0.8 C82682J3ED6R8** MMKP82 0.0068 18.0 9.5 15.5 15.0 0.8 C82822J3ED8R8** MMKP82 0.0082 18.0 11.2 19.2 15.0 0.8 C82442J3EE2R8** MMKP82 0.0044 26.5 7.0 16.5 22.5 0.8 C82472J3EE2R8** MMKP82 0.0047 26.5 7.0 16.5 22.5 0.8 C82562J3EE2R8** MMKP82 0.0056 26.5 7.0 16.5 22.5 0.8 C82682J3EE2R8** MMKP82 0.0068 26.5 7.0 16.5 22.5 0.8 C82822J3EE3R8** MMKP82 0.0082 26.5 8.5 17.0 22.5 0.8 C82103J3EE3R8** MMKP82 0.01 26.5 8.5 17.0 22.5 0.8 C82123J3EE4R8** MMKP82 0.012 26.5 10.0 19.0 22.5 0.8 C82153J3EE5R8** MMKP82 0.015 26.5 11.0 20.0 22.5 0.8 C82183J3EE6R8** MMKP82 0.018 26.5 12.0 21.5 22.5 0.8 C82223J3EE7R8** MMKP82 0.022 26.5 13.0 23.0 22.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. Note: We can customize the capacitors according to customers special requirements.
C82222J3DD2R8LC 价格&库存
很抱歉,暂时无法提供与“C82222J3DD2R8LC”相匹配的价格&库存,您可以联系我们找货
