SY0603JN100RP
SY0603JN100RP
    SANYEAR(叁叶源)
    贴片电阻 0603
SY0603JN100RP 数据手册
2018 产品说明书 PRODUCT MANUAL 深圳市叁叶源主要生产被动元器件 SMD R‐Chip 电阻,产品尺寸:0402‐ 1206,阻值范围:1‐22 兆欧姆,产品具有高可靠性电极设计、兼容所有焊 接制程等特点。 Administrator 深圳市叁叶源电子有限公司 2018/6/1 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR 目录 Contents ● 特点 Features 3 ● 品名构成 Type Designation 3 ● 结构 Construction 4 ● 规格尺寸 Dimensions 4 ● 负荷下降曲线 Derating Curve 4 ● 额定值 Ratings 5 ● 常规 TCR 值 5 ● 高精度 TCR±50 额定值 6 ● 特性 Characteristics 6 ● 推荐焊盘尺寸 Recommend Solder Pad Size 9 ● 包装 Packaging 9 ● IEC E-24、E-96 系列电阻值代码对照表 12 ● 厚膜电阻阻值代码及标记规则 14 ● 片式电阻器使用说明 16 ● 焊接 Soldering 17 2 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ■常规厚膜片式固定电阻器 General Thick Film Chip Fixed Resistor ● 特 点 Features 体积小、重量轻 Miniature and light weight 适应再流焊与波峰焊 Suit for reflow and wave flow solder 电性能稳定,可靠性高 Stable electrical capability, high reliability 装配成本低,并与自动贴装设备匹配 Low assembly cost, suit for automatic SMT equipment 机械强度高,高频特性优越 Superior mechanical and frequency characteristics 符合 RoHS 指令要求 Compliant with RoHS directive 符合无卤素 Halogen free requirement ● 品名构成 Type Designation Single Chip Resistor SY (1) (1) Series SY Thinck Film ST Thinck Film SA Atuomotive Garde 0402 (2) (2) Size 0402 0603 0805 1206 J (3) N (4) (3) Reslstance Toleiance (4) TCR N=Base on Spc E=±50ppm/℃ B=±0.1% D=±0.5% F=±1% J=±5% D=±25ppm/℃ F=±100ppm/℃ G=±200ppm/℃ 3 / 17 100R (5) (5) Resistance 1K 100K 10R 4K7 1M P (6) (6) Packing style P=Pager Tape B=Embossed Plastic 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 结 构 Construction ①陶瓷基板Ceramic Substrate ②背电极Bottom Electrode ③面电极Top Electrode ④电阻体Resistor Layer ⑤一次保护Primary Overcoat ⑥二次保护 Secondary Overcoat ⑦端电极Edge Electrode ⑧中间电极 Barrier Layer ⑨外部电极External Electrode ● 规格尺寸Dimensions 尺寸 Dimensions(mm) 型号 Type L W t a b 0402 1.00±0.10 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 0603 1.60±0.10 0.45±0.10 0.30±0.20 0.30±0.20 0805 2.00±0.15 0.55±0.10 0.40±0.20 0.40±0.20 1206 3.10±0.15 0.80±0.10 +0.15 1.25 -0.10 +0.15 1.55 -0.10 0.55±0.10 0.45±0.20 0.45±0.20 ● 负荷下降曲线 Derating Curve 使用温度范围: Operating Temperature Range: 额定负荷百分比 Percent Rated Load ①-55℃~125℃ ②-55℃~155℃ 环境温度Ambient temperature( ℃) 注 1:图中曲线适用于适用于 0402、0603、0805、1206。 Note 1: 0402 、0603 、0805、1206be the same with curve . 注 2:当电阻使用的环境温度超过 70℃时,其额定负荷(额定功率)按上述曲线下降。 Note 2: For resistors operated in ambient over 70℃ ,rated load (rated power) shall be derated in accordance with the above figure. 4 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 额定值Ratings 型号 70℃下额定功率 组件极限电压 最大过负荷电压 Rated Power at 70℃ Limiting Element Voltage Max. Overload Voltage (W) (V) (V) 常规功率系列 提升功率系列 常规功率系列 提升功率系列 常规功率系列 提升功率系列 Normal Upgraded Normal Upgraded Normal Upgraded Power Power Power Power Power Power Series Series Series Series Series Series 0402 1/16 / 50 / 100 / 0603 1/16 1/10 50 50 100 100 0805 1/10 1/8 100 150 200 300 1/8 1/4 200 200 1、电压为直流或交流有效值 Voltage of DC or AC RMS value 2、E=√P×R 或元件极限电压两者中的较小值 E=√P×R or Limiting element voltage whichever is lower. E:额定电压 Rated voltage(V) P:额定功率 Rated power(W) R: 标称阻值 Normal resistance( Ω) 400 400 Type 1206 注 Note ● 常 规 TCR 值 电阻温度系数 T.C.R(ppm/ ℃) 型号 阻值范围 Type Resistance Range 0402 0603 0805 1206 标称阻值允许偏差 Resistance Tolerance ±0.5% ±1% ±2% ±5% 1Ω<R<10Ω / ±400 ±400 ±400 10Ω<R ±100 ±100 ±100 ±100 1Ω<R<10Ω ±400 ±400 ±400 ±400 10Ω<R<100Ω ±200 ±200 ±200 ±200 100Ω<R ±100 ±100 ±100 ±100 1Ω<R<10Ω ±400 ±400 ±400 ±400 10Ω<R ±100 ±100 ±100 ±100 5 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 高精度 TCR±50 额定值 电阻温度系数 T.C.R(ppm/ ℃) 型号 阻值范围 Type Resistance 标称阻值允许偏差 Resistance Tolerance Range ±0.1% ±0.25% ±0.5% ±1% 0402 100Ω<R<1MΩ / / ±50 ±50 0603 10Ω<R<1MΩ ±50 ±50 ±50 ±50 1MΩ<R<10MΩ / ±50 ±50 ±50 0805 1206 ● 特 性 Characteristics 项目 标准 测试方法(IEC 60115-1) Item Specifications Test Methods (IEC 60115-1) 可焊性 可焊面积≥95% Solderability 95% Cover Min IEC 60115-1 4.17 245℃±5℃ 锡槽,保持 2~3s. Lead-free solder bath at 245℃±5℃ for2~3s. 耐焊接热 Resistance 无可见损伤 to No mechanical damage Soldering Heat 基板弯曲试验 Substrate △R≤± (1.0%R+0.05 Ω) 无可见损伤 Bending No mechanical damage Test △R≤± (1.0%R+0.05 Ω) 电阻温度系数 在规定值内 T.C.R Within specified T.C.R IEC 60115-1 4.18 260℃±5℃ 锡槽,保持 10s±1s. Lead-free solder bath at 260℃±5℃ for10s±1s. IEC 60115-1 4.33 弯 曲 距 离 (Bending distance): 0402、0603、0805 、1206: 5mm; 保持时间(Duration):60s±5s. IEC 60115-1 4.8 +20℃/-55℃/+20℃/+125℃/+20℃ 6 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 特 性 Characteristics 接上页Continue 项目 标准 测试方法(IEC 60115-1) Item Specifications Test Methods (IEC 60115-1) 无可见损伤 温度循环 Temperature cycling No mechanical damage 0.5%、1% IEC 60115-1 4.19 0402、0603、0805、1206:-55±3℃(30 分钟)--常温(10~15 分 钟)--155±2℃(30 分钟)--常温(10~15 分钟),1000 个循环. △R≤± (0.5%R+0.05 Ω) 0402、0603、0805、1206: -55±3℃(30min)--normal 2%、5% temperature(10~15min)--155±2℃(30min)--normal △R≤± (1.0%R+0.05 Ω) temperature(10~15min),1000 cycles. 无可见损伤 短时间过负载 Short Time Overload No mechanical damage 0.5%、1% △R≤± (1.0%R+0.1Ω) 2%、5% IEC 60115-1 4.13 2.5 倍额定电压或最大过负荷电压(取较小值),保持 5 秒 2.5 times rated voltage or max. overload voltage whichever is lower for 5 s. △R≤± (2.0%R+0.1 Ω) IEC 60115-1 4.39 断续过负载 无可见损伤 Intermittent No mechanical damage Overload △R≤± (5.0%R+0.05 Ω) 2.5 倍额定电压或最大过负荷电压(取较小值),通 1 秒/断 25 秒, 10000 个循环. 2.5 times rated voltage or max. overload voltage whichever is lower for 1s ON/ 25s OFF ,10000 cycles. 无可见损伤 湿度寿命 Load life in humidity No mechanical damage 0.5%、1% △R≤± (0.5%R+0.1 Ω) 2%、5% △R≤± (3.0%R+0.1 Ω) 耐溶剂 Component 无可见损伤 Solvent No mechanical damage Resistance △R≤± (1.0%R+0.05 Ω) IEC 60115-1 4.24 40℃±2℃,90~95%RH,1000 小时,额定电压或元件极限电压 (取较小值),通 1.5 小时/断 0.5 小时. 40℃±2℃,90~95%RH,1000h,rated voltage or limiting element voltage whichever is lower for 1.5h ON/0.5h OFF. IEC 60115-1 4.29 浸入异丙醇(IPA),超声波清洗 3 分钟 Specimens shall be immersed in a bath of alcohol completely for a 3 minutes using ultrasonic test equipment 7 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 特 性 Characteristics 项目 标准 测试方法(IEC 60115-1) Item Specifications Test Methods (IEC 60115-1) 无可见损伤 No mechanical damage 负载寿命 0.5%、1% Load life △R≤± (1.0%R+0.1 Ω) 2%、5% △R≤± (3.0%R+0.1 Ω) IEC 60115-1 4.25.1 70℃±2℃,1000 小时,额定电压或元件极限电压(取较小值),通 1.5 小时/断 0.5 小时. 70℃±2℃,1000h,rated voltage or limiting element voltage whichever is lower for 1.5h ON/0.5h OFF. IEC 60115-1 4.6 绝缘电阻 Insulation 在电极与基片间施加 100V 直流电压,保持 60~70s,然后测绝缘电 ≥1000MΩ Min Resistance 阻值。 Apply DC 100V between substrate and terminations for 1min, then check insulation resistance IEC 60115-1 4.7 电阻固定在90˚C 的V 型槽中, 根椐不同产品规定交流电压, 持续 耐电压 无击穿或飞弧 Voltage No breakdown or Proof flashover 60~70 秒 Resistor shall be clamped in the trough of 90˚C metallic V block and shall be tested at AC potential respectively specified in the given list ofeach product type for 60-70 seconds. For Cement Fixed Resistors 0402、0603、0805、1206:125℃, 1000h. ■ 推荐焊盘尺寸 Recommend Solder Pad Size ● 片式固定电阻器 Chip fixed resistor 单位unit: mm 厚膜电阻及薄膜电阻 Thick Film Resistor and Thin Film Resistor 8 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR 型号 A B C 0402 0.45 1.45 0.60 0603 0.80 2.50 0.95 0805 1.05 3.25 1.40 1206 1.90 4.50 1.75 Type ■ 包装 Packaging ● 纸带编带-1 Paper Taping-1 适用于 0402、 For 0402 单位unit: mm 型号 Type A±0.2 B±0.2 W±0.2 F±0.05 E±0.1 0402 1.15 0.65 8.00 3.50 1.75 单位 unit: mm 型号 Type P±0.05 P0±0.1 P1±0.05 ΦD0+0.1 T1 T±0.1 0402 2.00 4.00 2.00 1.50 / 0.45 ● 纸带编带-2 Paper Taping-2 适用于 0603、0805、1206: For 0603、0805、1206: 9 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR 单 位 unit: mm 型号 Type A±0.2 B±0.2 W±0.2 F±0.05 E±0.1 0603 1.90 1.10 8.00 3.50 1.75 0805 2.40 1.65 8.00 3.50 1.75 1206 3.60 2.00 8.00 3.50 1.75 单 位 unit: mm 型号 Type T±0.1 P±0.05 P0±0.1 P1±0.05 ΦD0+0.1 厚膜电阻及薄膜电阻 Thick Film Resistor and Thin Film Resistor 0603 2.00 4.00 2.00 1.50 0.67 0805 2.00 4.00 2.00 1.50 0.81 1206 2.00 4.00 2.00 1.50 0.81 10 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● 卷盘 Reel 单位unit: mm 型号 Type M W T A B C D 178±2.0 10±1.0 12.5±1.5 2.0±0.5 13.0±0.5 21.0±0.5 58.0±2.0 01005、0201 0402、0603 0805、1206 ● 包装数量 Packaging Quantity 包装方法 编带 Packaging style Tape & reel 型号 Type 数量 Quantity(pcs) 0402 0603、0805、1206 10000 5000 11 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ■ IEC E-24、E-96 系列电阻值代码对照表 IEC E-24、E-96 Series Resistance Cross-reference List ● E-24 系 列 E-24 series( ×10ⁿΩ ) (单位 unit: 0.001Ω、0.01Ω、0.1Ω、1Ω、10Ω、100Ω、1kΩ、10kΩ、100kΩ、1MΩ、10MΩ、100MΩ、1000MΩ) 1.0 1.5 2.2 3.3 4.7 6.8 1.1 1.6 2.4 3.6 5.1 7.5 1.2 1.8 2.7 3.9 5.6 8.2 1.3 2.0 3.0 4.3 6.2 9.1 ● E-96 系 列 E-96 series( ×10ⁿΩ ) (单位 unit: 0.001Ω、0.01Ω、0.1Ω、1Ω、10Ω、100Ω、1kΩ、10kΩ、100kΩ、1MΩ、10MΩ、100MΩ、1000MΩ) 1.00 1.33 1.78 2.37 3.16 4.22 5.62 7.50 1.02 1.37 1.82 2.43 3.24 4.32 5.76 7.68 1.05 1.40 1.87 2.49 3.32 4.42 5.90 7.87 1.07 1.43 1.91 2.55 3.40 4.53 6.04 8.06 1.10 1.47 1.96 2.61 3.48 4.64 6.19 8.25 1.13 1.50 2.00 2.67 3.57 4.75 6.34 8.45 1.15 1.54 2.05 2.74 3.65 4.87 6.49 8.66 1.18 1.58 2.10 2.80 3.74 4.99 6.65 8.87 1.21 1.62 2.15 2.87 3.83 5.11 6.81 9.09 1.24 1.65 2.21 2.94 3.92 5.23 6.98 9.31 1.27 1.69 2.26 3.01 4.02 5.36 7.15 9.53 1.30 1.74 2.32 3.09 4.12 5.49 7.32 9.76 ● E-96 系列 0603 型号《乘数代码对照表》 E-96 series(0603) 《multiplied Cross-reference List》 乘数 multiplied 代码 code ×10º ×10¹ ×10² ×10³ ×104 ×105 ×106 ×107 ×10-1 ×10-2 ×10-3 A B C D E F G H X Y Z 12 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● E-96 系列 0603 型号《电阻值代码对照表》 E-96 series(0603) 《 Resistance Cross-reference List》 代号 Code E-96 系列电阻 E-96 resistance 代号 Code E-96 系列电阻 E-96 resistance 代号 Code E-96 系列电阻 E-96 resistance 代号 Code E-96 系列电阻 E-96 resistance 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 13 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ■ 厚膜电阻阻值代码及标记规则 Description for Resistance Value Code and Marking of Thick Film Chip Resistor ● 阻值代码 Resistance Value Code 所有厚膜电阻的阻值代码与其标记是相对应的 All the resistance value code of thick film chip resistor is corresponding with the marking . ● 标 记 Marking ▪ E-24 系列(0603、±5%):采用三位数表示,前二位表示电阻值有效数字,第三位表示乘以 10 的次方数。 E-24 series: Express resistance value on the glass side with three digits, the first tow digits should be significant and the third one denote number of zeros. 例 For example: ▪ E-24 系列(0603、±1%&±0.5%):在三位数字标记下方增加下划线识别 E-24 series(0603 、 ±1%&± 0.5%): One short bar under marking letter. 例 For example: ▪ E-96 系列和 E24 系列(±1%&±0.5%): △ 0805、1206 采用四位数字表示,前三位表示电阻值有效数字,第四位表示乘以 10 的次方数。 E-96 series & E-24 series: For the dimension type of 0805、1206、1210、2010、2512、4R02 、4R03 express the resistance value with four digits, the first three digits are significant figures and the fourth denotes the number of zeros. 例 For example: 14 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ▪ E-96 系列 △ 0603 用三位代码表示,前二位表示 E-96 系列阻值代码,后一位字母表示乘数代码。 For the dimension type of 0603, express the resistance value with three code, the first two digit code denote the resistance of E-96 series, and the third code of letter denote the multiplier. 例 For example: ▪ 小数点以“R”表示 The decimal point should be expressed by “R” . 例 For example: ▪ 跨接电阻以“0”表示 The jumper should be expressed by “0”. 例 For example: ▪ 0402 不作标记 For the dimension type of 0201、0402 there is no mark on the glass side. 例 For example: ▪ 非 IEC 标准系列的电阻值标记表示方法:一般以最接近 IEC E24 系列标称阻值的标记表示方法。 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. ▪ 客户对标记有特殊要求时,则按照协商的结果印刷标记。 To get agreement by both party if there special requirement for the marking. 15 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ■ 片式电阻器使用说明 Chip Resistor Instructions for Use ● 本产品在以下特殊环境下应用,性能可能会受到影响: 1、在各种类型的液体,包括水、油、化学品、有机溶剂的使用。 2、在户外直接暴露在阳光的地方,或在灰尘多的地方使用。 3、在产品暴露的地方,有海风或腐蚀性气体,包括氯气、硫化氢、氨气、二氧化硫、二氧化氮等。 4、在产品暴露于静电或电磁波的地方使用。 5、在产生热量的部件、塑料线或其它易燃物品附近使用。 6、在用树脂或其他涂层材料密封产品的情况下使用。 7、焊接后使用不洁焊料或使用水或水溶性清洗剂清洗产品。 ● Application of the products in a special environment can deteriorate product performance: 1 、Use in various types of liquid, including water, oils, chemicals, and organic solvents. 2 、Use outdoors where the products are exposed to direct sunlight, or in dusty places. 3 、Use in places where the products are exposed to sea winds or corrosive gases, including Cl2 , H2S, Nh3 , SO2, and No2 etc. 4 、Use in places where the products are exposed to static electricity or electromagnetic waves. 5 、Use in proximity to heat-producing components, plastic cords, or other flammable items. 6、 Use involving sealing or coating the products with resin or other coating materials. 7 、Use involving unclean solder or use of water or water-soluble cleaning agents for cleaning after soldering. ● 产品使用注意事项 1、避免采用超过正常额定功率的功率,超过额定功率的稳能负载条件下可能会对产品性 能和可靠性产生负面影响。 2、用镊子拿起产品时要小心,有可能会将保护或电阻体夹碎。 3、手动安装产品时,烙铁头勿触碰产品。 4、储存条件:温度 5℃~30℃,相对湿度 30%~70%。 16 / 17 常规厚膜片式固定电阻 GENERAL THICK FILM CHIP FIXED RESISTOR ● Precautions on use of products 1、 Avoid applying power exceeding normal rated power, exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 2 、Be careful when pick up the products with tweezers. There may be a care that the overcoat or the body can be chipped. 3 、Soldering tip shall not touch the product when install product manually. 4 、Storage conditions: T: 5℃~30℃ , RH:30% ~70%. ■ 焊接 Soldering ● 推荐的回流焊曲线 Recommended reflow profile ● 推荐的波峰焊曲线 Recommended wave solder profile ● 推荐的焊膏类型 Recommended solder alloy:96.5 Sn/3.0 Ag/0.5Cu 17 / 17
SY0603JN100RP
- 物料型号:文档中提到了多种型号的电阻器,包括0402、0603、0805、1206等。 - 器件简介:这些电阻器具有体积小、重量轻、适应再流焊与波峰焊、电性能稳定、可靠性高等特点。 - 引脚分配:文档中提供了电阻器的结构图,包括陶瓷基板、背电极、面电极、电阻体、一次保护、二次保护、端电极、中间电极和外部电极。 - 参数特性:包括额定功率、组件极限电压、最大过负荷电压、电阻温度系数T.C.R等。 - 功能详解:文档详细描述了电阻器的特性,如可焊性、耐焊接热、基板弯曲试验、电阻温度系数、温度循环、短时间过负载、断续过负载、湿度寿命、耐溶剂、负载寿命、绝缘电阻和耐电压等。 - 应用信息:文档指出产品在特定环境下使用可能会影响性能,例如液体、户外阳光直射、腐蚀性气体、静电或电磁波、热量产生部件附近、用树脂或其他涂层材料密封产品、焊接后使用不洁焊料或水溶性清洗剂清洗产品。 - 封装信息:提供了推荐焊盘尺寸、包装方式和包装数量等信息。
SY0603JN100RP 价格&库存
很抱歉,暂时无法提供与“SY0603JN100RP”相匹配的价格&库存,您可以联系我们找货
