RN 1/4W 3K3 F T/B A1
    TYOHM(幸亚电阻)
    插件,D2.4xL6.4mm
    插件电阻 3.3KΩ ±1% 250mW ±50ppm/℃
RN 1/4W 3K3 F T/B A1 数据手册
RN series PRECISION METAL FILM RESISTORS Features 1. Low T.C. 25ppm 50ppm 100ppm. 2. High precision 0.25% 0.5% 1% 5%. 3. Temperature stable, low noise, good reliability. 4. 0.1% / 25ppm case by case. 1. 2. 3. 4. 25ppm 0.25% 50ppm 0.5% 100ppm 1% 5% 0.1% / 25ppm ELECTRICAL AND MECHANICAL PERFORMANCE Characteristics Resistance Tolerance Resistance Temp. Coeff. Power Rating Load Short Time Overload Dielectric Withstanding Voltage Insulation Resistance Terminal Strength Test Methods Standards 1% ( F ) or - 0.5% ( D ) 25 ppm / 100 ppm / 50 ppm / Surface temp. 175 Max. 175 , R/R 1% -65 ~ 175 Rated voltage for 30 minutes / 30 2.5 times of rated valtage for 5 seconds. 2.5 /5 0.5% No evidence of mechanical damage or insulation breakdown. 10,000MÙ Max. Overload Voltage for 1 min. 1 ( RN 1 W & 1 WL AC 350V RN 1/4 WS AC 300V ) DC 100V or 500V megger No evidence of mechanical damage. Minimum 95% coverage 95% No evidence of mechanical damage. Resistance to Soldering Heat , R/R 1% Solder-ability 1 kg 235 5 for 2 seconds 270 5 for 10 1 seconds 350 10 for 3.5 0.5 seconds ENVIRONMENTAL CHARACTERISTICS Characteristics Standards Temp. Cycle R/R 0.25% Load Life R/R 2% Moisture-proof Load Life R/R 1.5% Nonflammability Reference Standards IEC 60115-1 JIS C 5201-1 not flamed 21 Test Methods -65 ( 30 min.) Room Temp.( 3 min.) +175 ( 30 min.) Room Temp.( 3 min.) / ( 5 cycles) Rated power load 90 minutes ON 30 minutes OFF 70 1000 hours Rated power load 90 minutes ON 30 minutes OFF 40 95% RH 1000 hours 16 times of rated wattage for 5 min. (RN 1W & RN 1WL) RN series Unit mm Dimensions Rated Wattage 1/8W 1/4WS 1/4W 1/2WS 0.6W 1/2W 1W 1WL d H L H D Resistance H 3 d 0.1 Range(Ù) 1.7 0.2 3.7max. 28 0.45 10~1M 0.45 1.7 0.2 3.7max. 28 10~1M 28 0.6 2.4 0.5 6.4 10~2M 28 0.6 2.4 0.5 6.4 10~2M 28 0.6 2.4 0.5 6.4 10~2M 9 0.65 28 3.5 10~2M 11 0.8 28 4.5 10~2M 15 0.8 28 5.0 10~2M D 1 60 40 20 -40 0 40 80 120 140 160 175 Surface Temperature Rise (OC) Rated Load (%) 150 1WL 70 80 0 150V 200V 250V 300V 350V 350V 500V 500V Surface Temperature Rise For resistors operated in ambient temperatures above 70 , power rating must be derated in accordance with the curve below. -65 Max. Working Voltage Note: 1. To prevent electric corrosion, the resistance over 100KÙ should be limited at 50V. 2. Too low or too high ohmic values can be supplied only case by case. 3. Max. Overload Voltage is 2 times of Max. Working Voltage. 4. RN 1W & RN 1WL is coated by flameproof paint. Derating Curve 100 L 1 Ambient Temp. (OC) 100 1W 0.6W 1/2WS 1/2W 50 1/4WS 1/4W 1/8W 0 0 How to order 20 40 60 80 100 Rated Load (%) It is composed by Type, Rated Wattage, Nominal Resistance, Tolerance ,Temperature Coefficient and Package. e.g. RN a. 1/4W b. 10Ù c. F d. 50ppm e. T/B f. a. Type( ): Precision Metal Film Resistohrs are Called "RN". b. Rated Wattage( ) : Shown by "W", such as 1/8W,1/4WS, 1/4W,1/2WS,0.6W,1/2W,1W,1WL. c. Nominal Resistance( ) : 10Ù. d. Tolerance( ): 0.5%(D), 1%(F) . e. Temperature Coefficient ( ): 25ppm/OC, 50ppm/OC, Nil f . Package ( ): T/R tape & reel ( ); T/B tape in box( ); Nil Bulk( ). 22 100ppm/OC
物料型号:TXOHM RN系列
器件简介: - 低温度系数:25ppm、50ppm、100ppm - 高精度:0.25%、0.5%、1%、5% - 温度稳定,低噪音,高可靠性 - 个别情况下精度可达0.1%/25ppm
电气及机械特性: - 阻值容差:±1%(F)或±0.5%(D) - 温度系数:±25ppm/°C、±50ppm/°C、±100ppm/°C - 额定负载:最高表面温度175°C,额定电压30分钟 - 短时间过负载:±0.5%,2.5倍额定电压5秒 - 耐电压:无机械损坏或绝缘击穿现象 - 绝缘电阻:10^10 MΩ - 端子强度:无机械损坏现象 - 焊锡性:焊锡面积≥95% - 浸锡耐热性:无机械损坏现象,R/R≤±1%
环境特性: - 温度循环:R/R≤±0.25% - 负载寿命:R/R≤±2% - 耐湿寿命:R/R≤±1.5% - 不燃性:不燃烧
尺寸信息:提供了不同额定功率的尺寸数据,包括直径(D)、长度(L)、高度(H)和端子直径(d)。
功能详解:文档提供了电阻器的详细电气特性和环境测试标准。
应用信息:适用于需要高精度和稳定性的应用。
封装信息:提供了不同额定功率的封装类型和最大工作电压。
RN 1/4W 3K3 F T/B A1 价格&库存
很抱歉,暂时无法提供与“RN 1/4W 3K3 F T/B A1”相匹配的价格&库存,您可以联系我们找货
  • 50+0.09018
  • 500+0.07010
  • 1500+0.05886
库存:1517
    • 5000+0.05930
    库存:850
