信 昌 電 子 陶 瓷 股 份 有 限 公 司
PROSPERITY DIELECTRICS CO., LTD.
SPECIFICATION FOR APPROVAL
CUSTOMER
CUST. PART NO.
CUST. DOC. REV.
DESCRIPTION
SAMPLE LOT NO.
PART NO.
DOC. REV.
DATE
HIGH CURRENT POWER CHOKE (ROHS+H.F.)
MCS1040-XXXMXX
ORIG
Once you approve this part, please sign and return this page to the following marked location.
Customer Signature:___________________
Date:_________________
□This part currently development section.
□Production line can produce this series of products.
■Sales Office-Headquarter
No. 566-1, Kao-Shi Rd., Yangmei, Taoyuan 32668,
Taiwan
TEL: +886-3-475-3355
FAX: +886-3-485-4959
□Yong Zhou Plant
Tao-Yuan Rd., Fenghuang Park, Lengshuitan
District, Yongzhou, Hunan 425000, P.R.C.
TEL: +86-746-8610-180
FAX: +86-746-8610-181
□Sales Office-Dong Guan,China
No.638,Mei Jing West Road Xiniupo Administrative
Zone Dalang Town,Dong Guan City,GuangDong
Province,China.
TEL: +86-769-8555-0979
FAX: +86-769-8555-0972
TESTED BY
CHECKED BY
APPROVED BY
TABLE OF CONTENTS
INDEX
Page
■ Engineering Change Notice – Record ….………..…………..
2
■ Product Identification ………….…………….………………….
3
■ Product Dimension ……….…………….……….……………….
3
■ Marking and Date code …….…………….……………………...
3
■ Electrical Spec. ……………………………………………...……
4
■ Reliability Performance
5
6
■ Package Form …………………………………………………….
7
■ Reflow Chart
■ Test Report ………………………………………………………..
Rev.G
P1
CUSTOMER P/N
CUSTOMER
REV.
SPL. LOT NO.
PART NAME
PART NO.
HIGH CURRENT POWER
CHOKE (ROHS+H.F.)
REV.
MCS1040-XXXMXX
DATE OF ISSUE
Q'TY
ORIG
0 PCS
ENGINEERING CHANGE NOTICE – RECORD
REVISION
NO.
ORIG
Rev.G
REVISION DESCRIPTION
AUTHOR
Gary Chang
P2
DATE
REMARK
※This is a RoHS and REACH compliant product whose related documents are available on request.
※Graphic is only for dimensionally application.
1. PRODUCT IDENTIFICATION
2. PRODUCT DIMENSION
UNIT: mm
3. MARKING AND DATE CODE
Marking ex:1.0uH 1R0
Date code
XX XXyear and weekly
Rev.G
ex:1033
P3
DIM.
TOL.
M1
11.15
±0.35
M2
10.0
±0.3
M3
4.0
MAX.
M4
3.0
±0.5
M5
2.0
±0.5
4. ELECTRICAL SPEC.
DCR
DCR
Inductance
Rated Current
I sat
(mΩ)
(mΩ)
(uH)
(A)
(A)
Typical 25℃
MAX.25℃
±20%
Typical
Typical
0.22
0.80
1.0
30.0
50.0
MCS1040-R22MN1
0.36
1.1
1.2
34.0
40.0
MCS1040-R36MN1
0.47
1.3
1.55
25.0
35.0
MCS1040-R47MN1
0.56
1.6
1.8
25.0
32.0
MCS1040-R56MN1
0.68
2.4
2.7
22.0
30.0
MCS1040-R68MN1
1.0
3.0
3.3
18.0
28.0
MCS1040-1R0MN1
1.5
3.8
4.2
16.0
21.0
MCS1040-1R5MN1
2.2
6.7
7.0
12.0
18.0
MCS1040-2R2MN1
3.3
10.8
11.8
10.0
16.0
MCS1040-3R3MN1
4.7
17.0
20.0
8.5
15.0
MCS1040-4R7MN1
6.8
22.5
25.0
6.5
9.0
MCS1040-6R8MN1
8.2
26.0
29.0
7.0
9.0
MCS1040-8R2MN2
10
27.0
30.0
7.5
8.5
MCS1040-100MN1
15
40.0
45.0
6.25
7.0
MCS1040-150MCC
22
60.0
66.0
5.0
5.5
MCS1040-220MCC
33
85.0
92.0
4.4
5.0
MCS1040-330MCC
47
130.0
145.0
3.3
3.5
MCS1040-470MCC
TEST INSTRUMENT: CHROMA 16502 、Zentech1320+Zentech3305
(1). Test Freq : 100KHz , 1.0V
(2). All test data is referenced to 25℃ ambient.
(3). Operating Temperature Range -55℃ to +125℃.
(4). Rated Current: DC current(A)that will cause an approximateᇞT of 40℃.
(5). I sat: DC current(A)that will cause Lo to drop approximately 30%.
(6). The part temperature(ambient +temp rise)should not exceed
125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness,
airflow and other cooling provisions all affect the part temperature Part temperature should be verified
PART NO.
Rev.G
P4
5. RELIABILITY PERFORMANCE
Reliability Experiment For Electrical
Test Item
Test Condition
Standard Source
Humidity Test
+40℃±2℃, humidity of 90%±5% (total 96 hours).
MIL-STD-202G
Method 103B
Test Condition B
High Temperature Test
1.Temperature: +125℃±2℃.
2.Test time: 48±2hrs.
IEC 68-2
Test Condition B
Low Temperature Test
1.Temperature: -40℃±2℃.
IEC 68-2
Test Condition A
Thermal Shock
+125℃±5℃ (30 minutes) ~ -40±5℃ (30 minutes),
temperature switch time: 5 minutes (total 50 cycles) Wind
speeds 10m/sec.
Life Test
+70℃±5℃ (300Hours).
Reference
MIL-STD-202G
Method 107G
Test Condition B-2
Reference
MIL-STD-202G
Method 108A
Test Condition B
Reliability Experiment For Physical
Test Item
Rev.G
Test Condition
Standard Source
Vibration Test
10-55-10HZ, amplitude: 1.5mm, direction: X, Y, Z axes,
each axis 2 hours (total 6 hours).
Solder Heat Resistance
Test
Reference
IR/convection reflow: Peak Temp 255℃~260℃ for 3~5 Sec. MIL-STD-202G
Method 210F
in air, Through 2 Cycle. Temperature Ramp:+1~4°C/sec.;
Test Condition K
Above 217°C, must keep 90 s - 120 s.
(Reflow)
Solder Ability Test
Soak in 245℃ solder pot of 3~5 Sec., PAD must have 95%
above coverage.
P5
MIL-STD-202G
Method 201A
Reference
J-STD-002D
6. TYPICAL RoHS REFLOW PROFILE
(3~5
Rev.G
P6
7. PACKAGING
THE FORCE FOR TEARING OFF
130 GRAMS IN THE ARROW
THICKNESS (t)
0.10 MAX
165 TO 180°
TOP COVER TAPE
EMBOSSED CAVITY
BASE TAPE
EMBOSSED CARRIER
START
END
NO COMPONENTS
NO COMPONENTS
COMPONENTS
160 (mm) MIN
MIN. 390 (mm)
MAX. 560 (mm)
COVER TAPE
USER DIRECTION OF FEED
DIMENSIONS OF CARRIER TAPE (mm)
CARRIER TAPE REELS (mm)
MATERIAL:
PLASTIC
E
2.0±0.1
4.0±0.1
1.75±0.1
A
B
1.5 +0.1-0
W
N
C
P
C
※ 10 sprocket hole pitch cumulative tolerance ±0.20
500 Parts per Reel
UNIT: mm
Rev.G
A
B
C
E
N
P
W
t
A0
B0
K0
DIM.
330
25.0
13.0
24.6
100
16.0
24.0
0.4
10.6
11.7
4.25
TOL.
0.2
0.5
0.5
0.5
MIN
0.1
0.3
0.05
0.1
0.1
0.1
P7
很抱歉,暂时无法提供与“MCS1040-1R0MN1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+1.18304
- 20+0.93809
- 60+0.83312
- 200+0.63234
- 1000+0.57402
- 2000+0.53903
