RTO3943392MA3SI
RTO3943392MA3SI
    YXC(扬兴科技)
    TO39
    SAW声表面谐振器 TO39
RTO3943392MA3SI 数据手册
此商品对应的规格参数是: R 433A T039/T039 R433 433.92MHZ One-port SAW Resonator For Wireless Remote Controller     Ideal for 433.92MHZ Remote-control and WirelessSecurity Transmitters Very Low Series Resistance Quartz Stability Rugged, Hermetic, Low-Profile TO-39 0r F-11 Case Pin No. 1 2 3 1. Function Input or Output Output or Input Ground Absolute Maximum Rating Rating CW RF Power Dissipation DC Voltage between Any Two Pins Case Temperature 2. Marking: R433.92M Value +0 ±10 -40 to +85 Units dbm V ℃ Electrical Characteristics Characteristic Center Frequency Absolute Frequency (25℃) Tolerance from 433.92MHZ Insertion Loss Quality Factor Unloaded Q 50Ωloaded Q Temperature Turnover Temperature Stability Turnover Frequency Frequency Temperature Coefficient Frequency Aging (Value during the First Year) RF Equivalent Motional Resistance RLC Model Motional Inductance Motional Capacitance Pin1 to Pin2 Static Capacitance Transducer Static Capacitance DC Insulation Resistance between Any Two Pins Sym. fc Δfc IL QU QL TO fO FTC fA RM LM CM CO CP Min. 433.845 - 1.7 1.0 come visit our site http://www.yxc.hk Typ. 433.92 ±75 1.2 11000 2000 39 fc+8.4 0.032 18 86 1.56 2.0 1.8 Max. 433.995 2.5 - 10 26 2.3 Unit MHz KHz dB ℃ KHz ppm/℃2 ppm/yr Ω μH pF pF pF MΩ R433 433.92MHZ One-port SAW Resonator For Wireless Remote Controller NOTES: 1) Unless noted otherwise, case temperature Tc=+25±2℃. 2) The center frequency fc is measured at the minimum insertion loss point, ILMin, with the resonator in the 50Ω test system (VSWR≤1.2:1). The shunt inductance, Ltest, is tuned for parallel resonance with Co at fc. Typically, fOSCILLATOR or fTRANSMITTER is approximately equal to the resonator fc. 3) Turnover temperature, To, is the temperature of maximum (or turnover) frequency, fo. The nominal frequency at any case temperature, Tc, may be calculated from: f = fo(1-FTC(To-Tc)2). Typically oscillator To is 20℃ less than the specified resonator To. 4) Frequency aging is the change in fc with time and is specified at +65℃ or less. Aging may exceed the specification for prolonged temperatures above +65℃. Typically aging is greatest the first year after manufacture, decreasing in subsequent years. 5) This equivalent RLC model approximates resonator performance near the resonant frequency and is provided for reference only. The capacitance Co is the static (nonmotional) capacitance between pin1 and pin2 measured at low frequency (10MHZ) with a capacitance meter. The measurement includes case parasitic capacitance with a floating case. For usual grounded case applications (with ground connected to either pin 1 or pin 2and to the case), add approximately 0.25pF to Co. 6) Derived mathematically from one or more of the following directly measured parameters: fc, IL, 3dB bandwidth, fc versus T 3. Others 1) Typically, equipment utilizing this device requires emissions testing and government approval, which 2) 3) is the responsibility of the equipment manufacturer. Electrostatic Sensitive Device, observe precautions for handing. According to the different request of customer, we can supply the different Frequency precision, for example, ±75KHZ, ±150KHZ, ±250KHZ, etc. come visit our site http://www.yxc.hk
RTO3943392MA3SI 价格&库存
很抱歉,暂时无法提供与“RTO3943392MA3SI”相匹配的价格&库存,您可以联系我们找货
