PPS203J3C2911178LC
PPS203J3C2911178LC
    SRD(圣融达)
    插件
    薄膜电容 径向
PPS203J3C2911178LC 数据手册
金属化丙烯膜箔式高压电容器---CBB81(PPS)系列 Metallized Polypropylene Film And Foil Capacitors---CBB81(PPS)series ■ 引用标准 Reference standards GB10188(IEC384-13) ■ 结构 Structure 介质:聚丙烯膜 电极:金属真空蒸发层和铝箔 封装:阻燃粉末环氧树脂,符合 UL94V-0 Dielectric: Polypropylene film Electrode: Metal vacuum evaporation layer and aluminum foil Encapsulation: inflame retardant power epoxy resin, conforming to UL94 V-0 ■ 典型应用 Typical Application 高频、直流、交流及脉冲大电流场合 如:灯具、电源,显示器及彩电行逆程线路等 电子整流器,节能灯等 high frequency, direct current, alternating current or large pulse current occasion For example damp, power supply, display and colorful TV lines retrace circuits, electronic rectifier, energy-saving lamps etc ■ 特点 Features 有良如自愈性能。高频损耗小,温升低,高冲击强度。内部串联结构,电压高,过电流大等 Small volume with good self-healing property, low dissipation at high frequency, low temperature rise High impact strength. Internal series structure, high voltage, large current passage etc. ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category 40/105/56 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC) 额定电压 Rated Voltage 630VDC, 1000VDC, 1250VDC, 1600VDC, 2000VDC, 3000VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.001μF~22μF Capacitance Range 测试条件 Test Condition: (+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC) 耐电压 Withstand Voltage 20℃, 1KHz, 1Vrms 无击穿或飞弧 2.0UR,5S No breakdown or electric arcing 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.1μF IR≥30000MΩ Insulation Resistance CR>0.1μF IR≥10000S (1KHZ ) 测试条件 Test Condition : 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min 最大脉冲爬升速率 P=10 P=15 P=20 P=22.2 P=25 P=27.5 P=31.5 Max. Pulse Rise Time (dV / dt) 1000 1500 1000 500 500 500 500 金属化丙烯膜箔式高压电容器---CBB81(PPS)系列 Metallized Polypropylene Film And Foil Capacitors---CBB81(PPS)series 电性能规范 Performance Specifications ■ 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0040 dissipation factor rise:≤0.0040 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% 产品编码说明 Part No. Description: ■ 18 位产品编码如下: The Part No. Is total 18 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 P P S 1 0 4 J 3 C Digit 1-3 型号代码 Product series Code Digit 4-6 Digit 7 Digit 8-9 Digit 10-15 Digit 16 Digit 17-18 标称容量 Rated Capacitance Value 容量偏差 Capacitance Tolerance 额定电压 Rated Voltage Code 2 11 12 13 14 15 16 17 18 9 1 5 2 3 8 * * PPS= CBB81 series For example : 104 = 10×104pF = 0.1F J=±5% K=±10% 2J=630VDC 3A=1000VDC 3C=1600VDC 3D=2000VDC 外形尺寸 Dimensions Code 线径代码 Line diameter code 6=0.6 8=0.8 成型或内部识别码 Forming Type or Internal Use 1=1.0 金属化丙烯膜箔式高压电容器---CBB81(PPS)系列 Metallized Polypropylene Film And Foil Capacitors---CBB81(PPS)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS104J3A2608158LC PPS 0.1 25 8 15 22.5 0.8 PPS104J3A2612198LC PPS 0.1 25 12 19.5 22.5 0.8 PPS332J3A1307126LC PPS 0.0033 13 6 11 10.0 0.6 PPS473J3A1913208LC PPS 0.047 18 11.5 19 15.0 0.8 UR :1250Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS102J3B1909148LC PPS 0.001 18 9.5 14.5 15.0 0.8 PPS104J3B2914218LC PPS 0.1 28 12 19 25.0 0.8 PPS153J3B1908138LC PPS 0.015 18 7.5 12.5 15.0 0.8 PPS154J3B2914208LC PPS 0.15 28 12.5 18 25.0 0.8 PPS203J3B2408148LC PPS 0.02 23 7.5 13.5 20.0 0.8 PPS224J3B2922278LC PPS 0.2 28 18 26 25.0 0.8 PPS472J3B1309136LC PPS 0.0047 13 5.5 9.5 10.0 0.6 PPS562J3B1307136LC PPS 0.0056 13 6 12 10.0 0.6 UR :1600Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS103J3C1908158LC PPS 0.01 18 8 14.5 15.0 0.8 PPS104J3C2914218LC PPS 0.1 28 12.5 19.5 25.0 0.8 PPS203J3C2911178LC PPS 0.02 28 9.5 16.5 25.0 0.8 PPS822K3C2408158LC PPS 0.0082 23 8 15 20.0 0.8 UR :2000Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS151K3D1905106LC PPS 0.00015 18 7.0 10.5 15.0 0.6 PPS223J3D2409148LC PPS 0.022 23 9 14 20.0 0.8 PPS332J3D2408148LC PPS 0.0033 23 8 13.5 20.0 0.8 PPS472J3D2410158LC PPS 0.0047 23 8.5 15 20.0 0.8 PPS562J3D2407138LC PPS 0.0056 23 8 12.5 20.0 0.8 PPS822J3D1911188LC PPS 0.0082 18 9.5 16.5 15.0 0.8 UR :2500Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS102J3E1909148LC PPS 0.001 18 10 15 15.0 0.8 PPS103J3E3509168LC PPS 0.01 34 10 17 31.5 0.8 金属化丙烯膜箔式高压电容器---CBB81(PPS)系列 Metallized Polypropylene Film And Foil Capacitors---CBB81(PPS)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :3000Vdc 成品编码 系列 Part No. PPS682J3F2415228LC 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 Φd±0.05 PPS 0.0068 24 15 22 20.0 0.8 Note: We can customize the capacitors according to customers special requirements.
PPS203J3C2911178LC 价格&库存
很抱歉,暂时无法提供与“PPS203J3C2911178LC”相匹配的价格&库存,您可以联系我们找货
