SLW5012S150MST
SLW5012S150MST
    SUNLTECH(顺磁)
    SMD,5x5mm
    功率电感 SMD
SLW5012S150MST 数据手册
SLW5012S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excelleNST shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic INSTerference (EMI); 4、30% higher curreNST rating than conveNSTional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW (1) (1) (2) (3) (4) 5012 (2) S 100 M (3) (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series SLW5012S Rev.01 A B C D E F a Typ. b Typ. c Typ. 5.0±0.2 5.0±0.2 1.2Max. 4.0±0.2 1.25±0.2 2.50±0.2 2.3 1.4 4.2 Page 1 of 3 www.Sunltech.com SLW5012S Series ◆ Electrical Characteristics 1) Operating and storage temperature range (individual chip without packing): cking): -25 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ℃ ℃ ℃ ~ +125℃ ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 3 www.Sunltech.com SLW5012S Series ◆ Specification Inductance Part Number @100KHz,1 V (µH) Saturation CurreNST(A) Heat Rating CurreNST (A) S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonaNST DCR ( ) Frequency MHz SLW5012 Series SLW5012S1R0MST 1.0±20% 0.057 103 4.40 2.90 SLW5012S1R5MST 1.5±20% 0.072 68 3.70 2.50 SLW5012S2R2MST 2.2±20% 0.085 50 3.10 2.10 SLW5012S3R3MST 3.3±20% 0.126 34 2.40 1.80 SLW5012S4R7MST 4.7±20% 0.164 31 2.20 1.65 SLW5012S6R8MST 6.8±20% 0.245 22 1.70 1.30 SLW5012S100MST 10±20% 0.344 17 1.40 1.10 SLW5012S150MST 15±20% 0.436 13 1.20 0.90 ◆ Note :All test data is referenced to 20°C ambieNST; 2:Rated curreNST: Isat or Irms, whichever is smaller; 3:Isat: DC curreNST at which the inductance drops approximate 30% from its value without curreNST; 4:Irms: DC curreNST that causes the temperature rise (△T =40°C) from 20°C ambieNST. 1 ◆ Standard Packing Quantity: :1000 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW5012 Series Rev.01 Page 3 of 3 www.Sunltech.com
SLW5012S150MST
PDF文档中包含了以下信息:
物料型号:STM32F103C8T6 器件简介:STM32F103C8T6是一款基于ARM Cortex-M3内核的高性能微控制器。
引脚分配:该芯片有100个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压为2.05V至3.6V,工作频率为72MHz,内置64KB的Flash存储器和20KB的RAM。
功能详解:该MCU包含多种外设,如ADC、定时器、通信接口等。
应用信息:适用于工业控制、医疗设备、消费电子等领域。
封装信息:采用LQFP100封装。
