CMLW3010S100MST
CMLW3010S100MST
    CYBERMAX(思博)
    SMD,3x3mm
    功率电感 SMD
CMLW3010S100MST 数据手册
CMLW3010S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems CMLW (1) (1) (2) (3) (4) 3010 (2) S (3) 100 M (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. CMLW3010S 3.0±0.2 3.0±0.2 1.0Max. 2.5±0.2 0.75±0.2 1.50±0.2 1.5 0.8 2.7 Rev.01 Page 1 of 3 www.cybermaxtech.com CMLW3010S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 3 www.cybermaxtech.com CMLW3010S Series ◆ Specification Inductance Part Number @100KHz, 1V (µH) Frequency MHz Saturation Current(A) Heat Rating Current (A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant ( ) CMLW3010S Series CMLW3010S1R0MST 1.0±30% 0.056 180 1.89 1.81 CMLW3010S1R5MST 1.5±30% 0.068 120 1.71 1.63 CMLW3010S2R2MST 2.2±30% 0.095 100 1.55 1.36 CMLW3010S3R3MST 3.3±30% 0.124 74 1.31 1.20 CMLW3010S4R7MST 4.7±20% 0.193 59 1.03 0.96 CMLW3010S6R8MST 6.8±20% 0.261 42 0.89 0.83 CMLW3010S100MST 10±20% 0.342 39 0.78 0.73 CMLW3010S120MST 12±20% 0.432 36 0.69 0.65 CMLW3010S150MST 15±20% 0.522 30 0.61 0.59 CMLW3010S220MST 22±20% 0.796 28 0.48 0.48 CMLW3010S330MST 33±20% 1.326 18 0.39 0.38 CMLW3010S390MST 39±20% 1.497 18 0.38 0.35 CMLW3010S470MST 47±20% 1.668 18 0.30 0.33 CMLW3010S510MST 51±20% 1.881 18 0.29 0.31 CMLW3010S560MST 56±20% 1.984 16 0.29 0.30 ◆ Note :All test data is referenced to 20°C ambient; :Rated current: Isat or Irms, whichever is smaller; :Isat: DC current at which the inductance drops approximate 30% from its value without current; :Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. 1 2 3 4 ◆ Standard Packing Quantity: :2000 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW3010S Series Rev.01 Page 3 of 3 www.cybermaxtech.com
