CMLW252012S100MST
CMLW252012S100MST
    CYBERMAX(思博)
    SMD,2.5x2mm
    功率电感 SMD
CMLW252012S100MST 数据手册
CMLW252012S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems CMLW (1) (1) (2) (3) (4) 252012 S (2) (3) 2R2 M S T (4) (5) (6) (7) Series Type Dimension:L ×W× H(2.5×2.0×1.2mm) Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. CMLW252012S 2.5±0.2 2.0±0.2 1.2Max. 1.5±0.2 0.80±0.2 0.80±0.2 0.8 0.85 2.0 Rev.01 Page 1 of 3 www.cybermaxtech.com CMLW252012S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 3 www.cybermaxtech.com CMLW252012S Series ◆ Specification Inductance Part Number Ω DC Resistance( ) Saturation Current(A) Heat Rating Current (A) Typ. @100KHz,1V ( H) Max. CMLW252012SR24NST 0.24±30% 0.036 0.029 4.50 5.40 3.90 CMLW252012SR47MST 0.47±20% 0.045 0.041 4.03 4.51 3.70 CMLW252012SR68MST 0.68±20% 0.079 0.072 3.43 3.84 3.30 CMLW252012S1R0MST 1.0 ±20% 0.092 0.083 3.00 3.36 2.60 CMLW252012S1R5MST 1.5±20% 0.122 0.110 2.51 2.81 2.20 CMLW252012S2R2MST 2.2±20% 0.158 0.130 2.07 2.32 1.85 CMLW252012S3R3MST 3.3±20% 0.216 0.196 1.80 2.02 1.45 CMLW252012S4R7MST 4.7±20% 0.341 0.299 1.32 1.48 1.20 CMLW252012S6R8MST 6.8±20% 0.482 0.438 1.10 1.22 1.00 CMLW252012S100MST 10±20% 0.621 0.564 0.99 1.09 0.75 CMLW252012S150MST 15±20% 0.132 1.200 0.76 0.85 0.60 CMLW252012S220MST 22±20% 1.640 1.480 0.59 0.66 0.50 μ Typ. Min. DCR Typ. Isat Irms CMLW252012 Series ◆ Note :All test data is referenced to 20°C ambient; :Rated current: Isat or Irms, whichever is smaller; :Isat: DC current at which the inductance drops approximate 30% from its value without current; :Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. 1 2 3 4 ◆ Standard Packing Quantity: :2000 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW252012 Series Rev.01 Page 3 of 3 www.cybermaxtech.com
