MCF-1335-R68-N2
MCF-1335-R68-N2
    HOTLAND(合泰盟方)
    IND_12.6X13.5MM_SM
    680NH ±20%
MCF-1335-R68-N2 数据手册
MCW-1335-XXX-N2 Series www.sz-hotland.com ※ Features High performance (Isat) realizde by metal dust core. Low profile:Thickness max.3.5mm Low loss and low resistance Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standards ※ Application DC/DC converters for laptop motherboards/CPU Thin type of on-board power supply module for Voltage regulator VRM for server ※ Dimensions in inches (unit:mm) (E)0~0.15 (C)4.0±0.5 (D)3.5Max (C)3.0±0.5 (D)3.5Max (E)0~0.15 (B)12.6±0.3 (A)13.45±0.35 (B)12.6±0.3 (A)13.45±0.35 ※Note: All test data is reference to 25℃ ambient. Test Condition:100KHz,1.0Vrms Idc: DC current (A) that will cause an approximate △T of 40℃ Isat :DC current (A) that will cause L0 to drop approximately 30% (F)2.0±0.5 (F)2.0±0.5 Operat between temperature range -55℃ to +125℃ 8 5 125℃ under the worst case operating conditions.Circuit design, component.PWB trace size and thickness, airflow and other 14.5 cooling provision all affect the part temperature.Part temperature The rated current as listed is either the saturation current or the heating current depending on which value is lower. MC F ① ② - 14.5 Suggested pad layout Dimensions are in mm Suggested pad layout Dimensions are in mm the diagram above applies to values 1.0uH and above the diagram above applies to values 1.0uH and below should be verified in the end application. ※ Regulation of Part number 5 8 The part temperature (ambient + temp rise ) should not exceed 1335 - 2R2 ③   ④ - N 2   ⑤ ⑥ ① Molding Choke; ④ Inductance Value:2R2=2.2µH; ② Mold Categories:F; ⑤ The Material Code; ③ Dimensions(unit:mm):13.0x13.0x3.5; ⑥ Material Type; 11
MCF-1335-R68-N2 价格&库存
很抱歉,暂时无法提供与“MCF-1335-R68-N2”相匹配的价格&库存,您可以联系我们找货
