MPP104J2G1305105LC
MPP104J2G1305105LC
    SRD(圣融达)
    插件,P=10mm
    薄膜电容 径向
MPP104J2G1305105LC 数据手册
环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 引用标准 Reference standards GB10190(IEC384-16) ■ 结构 Structure 介质:聚丙烯膜 电极:金属真空蒸发层 封装:阻燃粉末环氧树脂,符合 UL94 V-0 Dielectric: Polypropylene film Electrode: metal vacuum evaporation layer Encapsulation: Flame retardant power epoxy resin, conforming to UL94 V-0 ■ 典型应用 Typical Application 用于开关电源,电子镇流器和变频器等中间电路直流滤波(如 DC filter,DC-link,PFC 等) As intermediate circuit capacitor for SMPS, LED driver, inverter (i.e. DC filter,DC-link, DC filter and P.F.C) ■ 特点 Features 有良好自愈性能 ,缩小产品尺寸,高频损耗小,温升低 Reduced size depended on good self-healing property, low dissipation at high frequency, low temperature rise ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category 40/105/56 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC) (+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC) 额定电压 Rated Voltage 400(450)VDC, 630VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.001μF~22μF Capacitance Range 测试条件 Test Condition: 耐电压 Withstand Voltage 无击穿或飞弧 1.6UR,5S No breakdown or electric arcing 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.33μF IR≥30000MΩ Insulation Resistance CR>0.33μF IR≥10000S 最大脉冲爬升速率 Max. Pulse Rise Time (dV / dt) 20℃, 1KHz, 1Vrms 测试条件 Test Condition : (1KHZ ) 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min UR(V) P7.5 P10 P15 P20 P25 P31 400(450)V 120 80 65 35 20 10 630V 150 120 80 60 40 20 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series 电性能规范 Performance Specifications ■ 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0040 dissipation factor rise:≤0.0040 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% 产品编码说明 Part No. Description: ■ 18 位产品编码如下: The Part No. Is total 18 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 M P P 1 0 5 J 2 G 1 11 12 13 14 15 16 17 18 9 0 7 1 4 8 * * Digit 1-3 型号代码 Product series Code MPP= CBB21 series Digit 4-6 Digit 7 Digit 8-9 Digit 10-15 Digit 16 Digit 17-18 标称容量 Rated Capacitance Value For example : 105 = 10×105pF = 1.0F J=±5% 2G=400VDC 2W=450VDC 2J=630VDC 容量偏差 Capacitance Tolerance 额定电压 Rated Voltage Code 外形尺寸 Dimensions Code 线径代码 Line diameter code 6=0.6 8=0.8 成型或内部识别码 Forming Type or Internal Use 1=1.0 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :250Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP104J2E1303075LC CBB21 0.1 13 4.5 8 10 0.5 MPP104J2E1304095LC CBB21 0.1 13 5 9.5 10 0.5 MPP104J2E1305085LC CBB21 0.1 13 5 9 10 0.5 MPP104J2E1305105LC CBB21 0.1 13 5.5 10.5 10 0.5 MPP104J2E1005105LC CBB21 0.1 10 5.5 10.5 7.5 0.5 MPP105J2E1310186LC CBB21 1.0 13 9.5 18 10 0.6 MPP105J2E1907138LC CBB21 1.0 13 7.5 13.5 10 0.8 MPP105J2E1907148LC CBB21 1.0 18 7.5 14.5 15 0.8 MPP105J2E1909168LC CBB21 1.0 18 9 16 15 0.8 MPP105J2E1910178LC CBB21 1.0 18 9.5 16 15 0.8 MPP105J2E2408158LC CBB21 1.0 23 7.5 14 20 0.8 MPP105J2E2410178LC CBB21 1.0 23 9.5 16.5 20 0.8 MPP124J2E1004095LC CBB21 0.12 10 5 10 7.5 0.5 MPP124J2E1303075LC CBB21 0.12 13 4.5 8.5 10 0.5 MPP125J2E1907158LC CBB21 1.2 18 8 16 15 0.5 MPP153J2E1305105LC CBB21 0.015 13 6.5 11 10 0.5 MPP154J2E1304085LC CBB21 0.15 13 4.5 9.5 10 0.5 MPP154J2E1305105LC CBB21 0.15 13 5.5 10.5 10 0.5 MPP154J2E1307126LC CBB21 0.15 13 7 12 10 0.6 MPP155J2E1908168LC CBB21 1.5 18 8.5 17 15 0.8 MPP155J2E2410168LC CBB21 1.5 23 9.5 16 20 0.8 MPP184J2E1304095LC CBB21 0.18 13 5 10 10 0.5 MPP184J2E1306116LC CBB21 0.18 13 6 10.5 10 0.6 MPP185J2E1909178LC CBB21 1.8 18 9.5 18 15 0.8 MPP205J2E3109168LC CBB21 2.0 30 9 16.5 27.5 0.8 MPP224J2E1304095LC CBB21 0.22 13 5.5 10.5 10 0.5 MPP224J2E1305105LC CBB21 0.22 13 5 10 10 0.5 MPP224J2E1305125LC CBB21 0.22 13 5.5 11.5 10 0.5 MPP224J2E1306116LC CBB21 0.22 13 6 11 10 0.6 MPP224J2E1906116LC CBB21 0.22 18 6.5 11.5 15 0.6 MPP224J2E1907138LC CBB21 0.22 18 7 12.5 15 0.8 MPP225J2E2411208LC CBB21 2.2 23 10.5 18.5 20 0.8 MPP255J2E2412208LC CBB21 2.5 23 12 20 20 0.8 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :250Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP274J2E1005125LC CBB21 0.27 10 6.5 13 7.5 0.5 MPP275J2E3110188LC CBB21 2.7 30 9.8 17.5 27.5 0.8 MPP333J2E1305105LC CBB21 0.033 13 5 10 10 0.5 MPP334J2E1006135LC CBB21 0.33 10 7 14 7.5 0.5 MPP334J2E1305125LC CBB21 0.33 13 6 12.5 10 0.5 MPP334J2E1308136LC CBB21 0.33 13 7 12 10 0.6 MPP334J2E1904096LC CBB21 0.33 18 5 10 15 0.6 MPP334J2E1906116LC CBB21 0.33 18 5.5 11 15 0.6 MPP335J2E1912228LC CBB21 3.3 18 13 23 15 0.8 MPP335J2E2414228LC CBB21 3.3 23 13 21 20 0.8 MPP393J2E1305105LC CBB21 0.39 13 5.5 10 10 0.5 MPP394J2E1305125LC CBB21 0.39 13 6.5 13 10 0.5 MPP394J2E1904096LC CBB21 0.39 18 5.5 10.5 15 0.6 MPP473J2E1304075LC CBB21 0.047 13 5 8 10 0.5 MPP473J2E1304095LC CBB21 0.047 13 5 10 10 0.5 MPP474J2E1308156LC CBB21 0.47 13 8 15 10 0.6 MPP474J2E1906116LC CBB21 0.47 18 6.5 11.5 15 0.6 MPP475J2E2915238LC CBB21 4.7 28 14 22.5 25 0.8 MPP563J2E1304085LC CBB21 0.056 13 5 8.5 10 0.5 MPP564J2E1306146LC CBB21 0.56 13 7 15.5 10 0.6 MPP683J2E1305095LC CBB21 0.068 13 5.5 9.5 10 0.5 MPP684J2E1308166LC CBB21 0.68 13 8 16 10 0.6 MPP684J2E1905125LC CBB21 0.68 13 6 13.5 10 0.5 MPP823J2E1304075LC CBB21 0.082 13 5 8 10 0.5 MPP823J2E1306116LC CBB21 0.082 13 5.6 10.7 10 0.6 MPP824J2E1309176LC CBB21 0.82 13 8.5 17 10 0.6 MPP824J2E1906136LC CBB21 0.82 18 7 14 15 0.6 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP104J2E1303075LC CBB21 0.1 13 4.5 8 10 0.5 MPP104J2E1304095LC CBB21 0.1 13 5 9.5 10 0.5 MPP104J2E1305085LC CBB21 0.1 13 5 9 10 0.5 MPP104J2E1305105LC CBB21 0.1 13 5.5 10.5 10 0.5 MPP104J2E1005105LC CBB21 0.1 10 5.5 10.5 7.5 0.5 MPP105J2E1310186LC CBB21 1.0 13 9.5 18 10 0.6 MPP105J2E1907138LC CBB21 1.0 18 7.5 13.5 15 0.8 MPP105J2E1907148LC CBB21 1.0 18 7.5 14.5 15 0.8 MPP105J2E1909168LC CBB21 1.0 18 9 16 15 0.8 MPP105J2E1910178LC CBB21 1.0 18 9.5 16 15 0.8 MPP105J2E2408158LC CBB21 1.0 23 7.5 14 20 0.8 MPP105J2E2410178LC CBB21 1.0 23 9.5 16.5 20 0.8 MPP124J2E1004095LC CBB21 0.12 10 5 10 7.5 0.5 MPP124J2E1303075LC CBB21 0.12 13 4.5 8.5 10 0.5 MPP125J2E1907158LC CBB21 1.2 18 8 16 15 0.5 MPP103K2E1004075LC CBB21 0.01 10 5.5 8.5 7.5 0.5 MPP104K2E1304085LC CBB21 0.1 13 5.5 8.5 10 0.5 MPP104K2E1305105LC CBB21 0.1 13 5.5 10.5 10 0.5 MPP104K2E1005105LC CBB21 0.1 10 5.5 10.5 7.5 0.5 MPP105K2E1910178LC CBB21 1.0 18 9 16 15 0.8 MPP105K2E2408158LC CBB21 1.0 23 7.5 14 20 0.8 MPP125K2E1911188LC CBB21 1.2 23 10.5 17 20 0.8 MPP154K2E1307126LC CBB21 0.15 13 7 12 10 0.6 MPP154K2E1006115LC CBB21 0.15 10 6 11 7.5 0.5 MPP205K2E2411198LC CBB21 2.0 23 10.5 18.5 20 0.8 MPP223K2E1006095LC CBB21 0.022 10 6 10 7.5 0.5 MPP224K2E1305125LC CBB21 0.22 13 5 11.5 10 0.5 MPP224K2E1306116LC CBB21 0.22 13 6 11 10 0.6 MPP224K2E1907128LC CBB21 0.22 18 7 12.5 15 0.8 MPP225K2E2411208LC CBB21 2.2 23 10.5 18.5 20 0.8 MPP225K2E2613228LC CBB21 2.2 25 12 22 22.5 0.8 MPP225K2E2909188LC CBB21 2.2 28 9 18 25 0.8 MPP473K2E1304095LC CBB21 0.047 13 5 9.5 10 0.8 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP103J2G1305085LC CBB21 0.01 13 5.5 8.5 10.0 0.5 MPP103J2G1304075LC CBB21 0.01 13 4.5 8.0 10.0 0.5 MPP104J2G1004075LC CBB21 0.1 10 4.5 8.0 7.5 0.5 MPP104J2G1006095LC CBB21 0.1 10 5.5 9.0 7.5 0.5 MPP104J2G1305085LC CBB21 0.1 13 5.0 9.0 10.0 0.5 MPP104J2G1305105LC CBB21 0.1 13 5.5 10.5 10.0 0.5 MPP123J2G1305085LC CBB21 0.012 13 5.5 9.0 10.0 0.5 MPP124J2G1304075LC CBB21 0.12 13 5.0 8.5 10.0 0.5 MPP124J2G1305105LC CBB21 0.12 13 5.5 10.5 10.0 0.5 MPP153J2G1303075LC CBB21 0.015 13 5.0 7.5 10.0 0.5 MPP154J2G1005085LC CBB21 0.15 10 6.0 9.5 7.5 0.5 MPP154J2G1305105LC CBB21 0.15 13 5.0 10 10.0 0.5 MPP183J2G1005095LC CBB21 0.018 10 6.0 9.5 7.5 0.5 MPP184J2G1305125LC CBB21 0.18 13 5.0 12.0 10.0 0.5 MPP222J2G1305085LC CBB21 0.0022 13 5.5 9.0 10.0 0.5 MPP223J2G1304095LC CBB21 0.022 13 4.5 8.5 10.0 0.5 MPP224J2G1305095LC CBB21 0.22 13 6.0 10.5 10.0 0.5 MPP224J2G1305145LC CBB21 0.22 13 5.5 13.0 10.0 0.5 MPP273J2G1305095LC CBB21 0.027 13 5.5 9.0 10.0 0.5 MPP274J2G1305105LC CBB21 0.27 13 6.0 11.5 10.0 0.5 MPP332J2G1304075LC CBB21 0.0033 13 5.0 8.0 10.0 0.5 MPP333J2G1305095LC CBB21 0.033 13 5.0 10.0 10.0 0.5 MPP334J2G1305115LC CBB21 0.33 13 6.5 11.5 10.0 0.5 MPP472J2G1304085LC CBB21 0.0047 13 5.0 8.0 10.0 0.5 MPP472J2G1305085LC CBB21 0.0047 13 5.0 8.0 10.0 0.5 MPP473J2G1304095LC CBB21 0.047 13 4.5 9.5 10.0 0.5 MPP473J2G1305105LC CBB21 0.047 13 5.5 10.5 10.0 0.5 MPP563J2G1304085LC CBB21 0.056 13 5 8.5 10.0 0.5 MPP682J2G1304075LC CBB21 0.0068 13 4.5 7.0 10.0 0.5 MPP683J2G1305095LC CBB21 0.068 13 5.5 9.5 10.0 0.5 MPP683J2G1305105LC CBB21 0.068 13 5.5 10.5 10.0 0.5 MPP823J2G1305105LC CBB21 0.082 13 5.5 10.5 10.0 0.5 MPP102K2G1304075LC CBB21 0.001 13 5.0 7.5 10.0 0.5 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP103K2G1305085LC CBB21 0.01 13 5.5 8.5 10.0 0.5 MPP104K2G1305085LC CBB21 0.1 13 5.5 10.5 10.0 0.5 MPP104K2G1305105LC CBB21 0.1 13 5.2 10.5 10.0 0.5 MPP104K2G1306126LC CBB21 0.1 13 5.5 10.5 10.0 0.6 MPP104K2G1907128LC CBB21 0.1 18 7.0 12.0 15.0 0.8 MPP104K2G1006095LC CBB21 0.1 10 5.5 9.0 7.5 0.5 MPP105K2G1909178LC CBB21 1.0 18 9.0 15.5 15.0 0.8 MPP105K2G1910178LC CBB21 1.0 18 9.5 16.0 15.0 0.8 MPP105K2G2409178LC CBB21 1.0 23 8.5 16.5 20.0 0.8 MPP154K2G1305105LC CBB21 0.15 13 5.5 10.5 10.0 0.5 MPP154K2G1307126LC CBB21 0.15 13 6.5 11.5 10.0 0.6 MPP155K2G2412208LC CBB21 1.5 23 12.0 20.0 20.0 0.8 MPP205K2G2414228LC CBB21 2.0 23 13.0 22.0 20.0 0.8 MPP222K2G1305085LC CBB21 0.0022 13 5.5 9.0 10.0 0.5 MPP224K2G1305125LC CBB21 0.22 13 5 11.5 10.0 0.5 MPP224K2G1306116LC CBB21 0.22 13 5.5 11.0 10.0 0.6 MPP224K2G1907138LC CBB21 0.22 18 7.0 12.5 15.0 0.8 MPP225K2G2414238LC CBB21 2.2 23 14.0 23.0 20.0 0.8 MPP225K2G3112208LC CBB21 2.2 30 11.5 19.5 27.5 0.8 MPP305K2G3114238LC CBB21 3.0 30 13.5 23.2 27.5 0.8 MPP333K2G1305105LC CBB21 0.033 13 5.0 10.0 10.0 0.5 MPP334K2G1906136LC CBB21 0.33 18 6.0 12.5 15.0 0.6 MPP334K2G1908158LC CBB21 0.33 18 8.0 15.0 15.0 0.8 MPP335K2G2912208LC CBB21 3.3 28 12.5 20.0 25.0 0.8 MPP335K2G3115238LC CBB21 3.3 30 15.0 23.0 27.5 0.8 MPP472K2G1304085LC CBB21 0.0047 13 5.0 8.0 10.0 0.5 MPP473K2G1304095LC CBB21 0.047 13 5.0 9.5 10.0 0.5 MPP473K2G1305105LC CBB21 0.047 13 5.5 10.5 10.0 0.5 MPP473K2G1005105LC CBB21 0.047 10 5.5 10.5 7.5 0.5 MPP474K2G1311146LC CBB21 0.47 13 9.5 13.5 10.0 0.6 MPP474K2G1906136LC CBB21 0.47 18 6.0 12.5 15.0 0.6 MPP474K2G1908158LC CBB21 0.47 18 8.0 14.5 15.0 0.8 MPP474K2G1909148LC CBB21 0.47 18 8.5 13.5 15.0 0.8 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series 料号明细及尺寸 Part No. List and Dimensions ■ UR :400Vdc 尺寸 Dimension (mm) 容量 成品编码 系列 Part No. Series MPP475K2G3516248LC CBB21 4.7 MPP564K2G1910168LC CBB21 MPP683K2G1305095LC Capacitance Wmax (μF) Tmax Hmax P±0.5 d±0.05 34 15.5 24.0 31.5 0.8 0.56 18 9.0 15.5 15.0 0.8 CBB21 0.068 13 5.5 9.0 10.0 0.5 MPP683K2G1305105LC CBB21 0.068 13 5.5 10.5 10.0 0.5 MPP684K2G1908158LC CBB21 0.68 18 7.5 14.0 15.0 0.8 MPP684K2G1910178LC CBB21 0.68 18 9.0 16.0 15.0 0.8 MPP684K2G2408158LC CBB21 0.68 23 7.5 15.0 20.0 0.8 MPP684K2G2412198LC CBB21 0.68 23 12.0 19.0 20.0 0.8 MPP824K2G2409168LC CBB21 0.82 23 9.0 16.0 20.0 0.8 ■ 料号明细及尺寸 Part No. List and Dimensions UR :450Vdc 尺寸 Dimension (mm) 容量 成品编码 系列 Part No. Series MPP223J2W1006095LC CBB21 0.022 MPP224J2W1005105LC CBB21 MPP224J2W1305125LC Capacitance Wmax (μF) Tmax Hmax P±0.5 d±0.05 10 6.0 9.5 7.5 0.5 0.22 10 6.0 11.5 7.5 0.5 CBB21 0.22 13 6.0 12.0 10.0 0.5 MPP333J2W1305095LC CBB21 0.033 13 5.5 9.0 10.0 0.5 MPP333J2W1005085LC CBB21 0.033 10 6.0 9.0 7.5 0.5 MPP473J2W1304095LC CBB21 0.047 13 5.5 10.0 10.0 0.5 MPP473J2W1305085LC CBB21 0.047 13 5.5 9.0 10.0 0.5 MPP473J2W1005085LC CBB21 0.047 10 5.0 8.0 7.5 0.5 MPP473J2W1005105LC CBB21 0.047 10 6.0 10.0 7.5 0.5 MPP474J2W1305125LC CBB21 0.47 13 6.0 13.0 10.0 0.5 MPP683J2W1305105LC CBB21 0.068 13 5.0 10.0 10.0 0.5 MPP683J2W1006095LC CBB21 0.068 10 6.0 9.5 7.5 0.5 MPP823J2W1304085LC CBB21 0.082 13 5.5 9.5 10.0 0.5 MPP104K2W1305085LC CBB21 0.1 13 5.5 10.5 10.0 0.5 MPP104K2W1305105LC CBB21 0.1 13 5.5 10.5 10.0 0.5 MPP104K2W1306126LC CBB21 0.1 13 7.0 12.5 10.0 0.6 MPP105K2W1906116LC CBB21 1.0 18 8.0 13.0 15.0 0.6 MPP105K2W1908128LC CBB21 1.0 18 9.0 13.5 15.0 0.8 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :450Vdc 成品编码 Part No. 尺寸 Dimension (mm) 容量 系列 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP105K2W1912208LC CBB21 1.0 18 11.0 19.5 15.0 0.8 MPP105K2W2608178LC CBB21 1.0 25 9 17.5 22.5 0.8 MPP154K2W1305105LC CBB21 0.15 13 5 10 10 0.5 MPP154K2W1307126LC CBB21 0.15 13 6.5 11.5 10 0.6 MPP155K2W1909168LC CBB21 1.5 18 10.5 17 15 0.8 MPP155K2W1910148LC CBB21 1.5 18 11.5 15 15 0.8 MPP224K2W1306106LC CBB21 0.22 13 6 10 10 0.6 MPP333K2W1305105LC CBB21 0.033 13 5 10 10 0.5 MPP473K2W1304095LC CBB21 0.047 13 5 9 10 0.5 MPP473K2W1005105LC CBB21 0.047 10 5 9 7.5 0.5 MPP474K2W1308156LC CBB21 0.47 13 7.2 15 10 0.6 ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 Part No. 尺寸 Dimension (mm) 容量 系列 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP102J2J1304075LC CBB21 0.001 13 4.5 7 10 0.5 MPP103J2J1304075LC CBB21 0.01 13 4.5 8 10 0.5 MPP103J2J1304085LC CBB21 0.01 13 4.5 8 10 0.5 MPP103J2J1304095LC CBB21 0.01 13 4.5 9 10 0.5 MPP103J2J1305085LC CBB21 0.01 13 5.5 8.5 10 0.5 MPP104J2J1006115LC CBB21 0.1 10 6.5 11.5 7.5 0.5 MPP104J2J1304095LC CBB21 0.1 13 5.5 10 10 0.5 MPP104J2J1305105LC CBB21 0.1 13 5.5 10.5 10 0.5 MPP104J2J1006115LC CBB21 0.1 10 6 11.5 7.5 0.5 MPP123J2J1304095LC CBB21 0.012 13 5.5 10.5 10 0.5 MPP123J2J1305085LC CBB21 0.012 13 5.5 9 10 0.5 MPP124J2J1304115LC CBB21 0.12 13 5 11.5 10 0.5 MPP154J2J1006125LC CBB21 0.15 10 6.5 13.5 7.5 0.5 MPP184J2J1305125LC CBB21 0.18 13 6 12.5 10 0.5 MPP222J2J1305085LC CBB21 0.0022 13 5.5 9 10 0.5 MPP223J2J1304095LC CBB21 0.022 13 4.5 8.5 10 0.5 MPP223J2J1305085LC CBB21 0.022 13 5 8 10 0.5 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP224J2J1305135LC CBB21 0.22 13 6 14.5 10 0.5 MPP333J2J1304085LC CBB21 0.033 13 5 8.5 10 0.5 MPP333J2J1305105LC CBB21 0.033 13 5 10 10 0.5 MPP333J2J1004075LC CBB21 0.033 10 6 9 7.5 0.5 MPP472J2J1305085LC CBB21 0.0047 13 5 8 10 0.5 MPP472J2J1004075LC CBB21 0.0047 10 5.5 8.5 7.5 0.5 MPP473J2J1304095LC CBB21 0.047 13 4 8 10 0.5 MPP473J2J1305105LC CBB21 0.047 13 5 10 10 0.5 MPP473J2J1004085LC CBB21 0.047 10 4.5 10 7.5 0.5 MPP562J2J1304075LC CBB21 0.0056 13 4.5 9 10 0.5 MPP563J2J1303075LC CBB21 0.056 13 4.5 8 10 0.5 MPP682J2J1304075LC CBB21 0.0068 13 4.5 7 10 0.5 MPP683J2J1304075LC CBB21 0.068 13 5 8.5 10 0.5 MPP683J2J1305105LC CBB21 0.068 13 5.5 10.5 10 0.5 MPP822J2J1304075LC CBB21 0.0082 13 5 8 10 0.5 MPP823J2J1304075LC CBB21 0.082 13 5 8.5 10 0.5 MPP103K2J1304075LC CBB21 0.01 13 4.5 8 10 0.5 MPP103K2J1305085LC CBB21 0.01 13 5.5 8.5 10 0.5 MPP103K2J1306106LC CBB21 0.01 13 6.5 10.5 10 0.6 MPP104K2J1306126LC CBB21 0.1 13 6.5 11.5 10 0.6 MPP104K2J1307146LC CBB21 0.1 13 6.5 14 10 0.6 MPP104K2J1308136LC CBB21 0.1 13 7.5 12.5 10 0.6 MPP104K2J1906136LC CBB21 0.1 18 7 12 15 0.6 MPP104K2J1907128LC CBB21 0.1 18 7 12 15 0.8 MPP105K2J2411208LC CBB21 1.0 23 11 20 20 0.8 MPP105K2J3111208LC CBB21 1.0 30 11 20 27.5 0.8 MPP154K2J1307136LC CBB21 0.15 13 7 12 10 0.6 MPP154K2J1308146LC CBB21 0.15 13 7 13.5 10 0.6 MPP205K2J3116248LC CBB21 2.0 30 16.5 25 27.5 0.8 MPP222K2J1305085LC CBB21 0.0022 13 5.5 9 10 0.5 MPP223K2J1304095LC CBB21 0.022 13 4.5 8.5 10 0.5 MPP224K2J1307136LC CBB21 0.22 13 7.5 14 10 0.6 MPP224K2J1908158LC CBB21 0.22 18 8 14.5 15 0.8 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP224K2J1909148LC CBB21 0.22 18 8.5 13.5 15 0.8 MPP225K2J3115238LC CBB21 2.2 30 13.5 22.5 27.5 0.8 MPP225K2J3518268LC CBB21 2.2 34 18 26 31.5 0.8 MPP333K2J1305105LC CBB21 0.033 13 5 10 10 0.5 MPP334K2J1908158LC CBB21 0.33 18 8 15 15 0.8 MPP334K2J1910158LC CBB21 0.33 18 10.5 16 15 0.8 MPP334K2J1911178LC CBB21 0.33 18 10 16.5 15 0.8 MPP334K2J2409168LC CBB21 0.33 23 9.5 16 20 0.8 MPP473K2J1005105LC CBB21 0.047 10 6 10 7.5 0.5 MPP473K2J1305085LC CBB21 0.047 13 5 8.5 10 0.5 MPP473K2J1005105LC CBB21 0.047 10 6 10 7.5 0.5 MPP474K2J1908158LC CBB21 0.47 18 8 15 15 0.8 ■料号明细及尺寸 Part No. List and Dimensions UR :1000Vdc 成品编码 系列 Part No. 尺寸 Dimension (mm) 容量 Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP104J3A1907138LC CBB21 0.1 18 8 12.5 15 0.8 MPP104J3A1908138LC CBB21 0.1 18 7.5 13 15 0.8 MPP154J3A1908138LC CBB21 0.15 18 8 13 15 0.8 MPP224J3A1909168LC CBB21 0.22 18 8.5 16 15 0.8 MPP332J3A1306096LC CBB21 0.0033 13 6.5 10.5 10 0.6
MPP104J2G1305105LC
物料型号:CBB21(MPP)系列
器件简介:该系列电容器采用聚丙烯膜作为介质,金属真空蒸发层作为电极,封装材料为阻燃粉末环氧树脂,符合UL94 V-0标准。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电容器会有明确的引脚标识或分配图。
参数特性: - 额定温度:85°C - 工作温度范围:-40°C至+105°C - 额定电压:400VDC, 450VDC, 630VDC等 - 容量误差:J级±5% - 容量范围:0.001μF至22μF - 耐电压:1.6UR,5秒内无击穿或飞弧 - 损耗角:≤0.001(1KHz) - 绝缘电阻:CRS0.33μF IR≥30000MΩ,CR>0.33μF IR≥10000S
功能详解:具有良好自愈性能,减小产品尺寸,高频损耗小,温升低。
应用信息:主要用于开关电源、电子镇流器和变频器等中间电路直流滤波,如DC滤波器、DC链路、功率因数校正(PFC)等。
封装信息:电容器的封装尺寸和额定电压等信息在文档中有详细的表格列出,包括不同容量和尺寸的电容器的具体参数。
MPP104J2G1305105LC 价格&库存
很抱歉,暂时无法提供与“MPP104J2G1305105LC”相匹配的价格&库存,您可以联系我们找货
MPP104J2G1305105LC
  • 20+0.26789
  • 200+0.21865
  • 500+0.17125
  • 2000+0.15277
  • 10000+0.13800
  • 20000+0.13051
库存:5848
