MCW-0650-470-N2
MCW-0650-470-N2
    HOTLAND(合泰盟方)
    IND_6.6X7MM_SM
    47UH ±20%
MCW-0650-470-N2 数据手册
    方         合 Low profile:Thickness max.5.0mm 盟 合 泰   泰 盟 方   合   盟 方 泰 合 方 盟 泰 合     N 2 ④ Inductance Value:2R2=2.2µH; 方 合 泰 盟 盟 ⑥ Material Type; 方 ⑤ The Material Code; 泰   7     ⑤ ⑥ 盟 泰 合   合 -   2R2 方   方 盟 -   ④   合     0650   ③ ③ Dimensions(unit:mm):6.0x6.0x5.0; 泰     3,5 泰 泰 盟 泰 heating current depending on which value is lower. 合   方 盟 盟 Suggested pad layout Dimensions are in mm The rated current as listed is either the saturation current or the   (C)3.0±0.3   泰 合       8,4 合 方 should be verified in the end application.   3,7 方 cooling provision all affect the part temperature.Part temperature - (E)0~0.15 盟 盟 泰 合       component.PWB trace size and thickness, airflow and other           MC W    ① ② 方   (B)6,6±0.2 泰 方 盟 方 方   盟 泰 合   The part temperature (ambient + temp rise ) should not exceed   (D)5.0Max 合               合 合 泰 泰 盟 盟 方 方   (A)6.95±0.35 (F)1,6±0.3 125℃ under the worst case operating conditions.Circuit design,           ※ Dimensions in inches (unit:mm) Operat between temperature range -55℃ to +125℃       合 合 Voltage regulator VRM for server 泰 盟 泰 DC/DC converters for laptop motherboards/CPU Isat :DC current (A) that will cause L0 to drop approximately 30% ② Mold Categories:W;   ※ Application Idc: DC current (A) that will cause an approximate △T of 40℃ ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards Thin type of on-board power supply module for Test Condition:100KHz,1.0Vrms         Low loss and low resistance All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (1MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-0650-XXX-N2 Series
MCW-0650-470-N2 价格&库存
很抱歉,暂时无法提供与“MCW-0650-470-N2”相匹配的价格&库存,您可以联系我们找货
